Question about LG Refrigerators
I have a problem with my "1 door LG fridge, model GN-B331SLZ". The defrost button have been stucked for almost 24hrs. Is it normal? If not, what should i do? Thanks"
watugot
  • 290 Answers
SOURCE: hot areas around doors on LG fridge
This is usually caused by a dirty condenser coil or a stalled condenser fan.
Remove the cover from the rear of the fridge and see if the fan is running. If not, make sure nothing is stuck in the blades keeping it from turning. If it turns freely you probably need a new fan motor but you would need to check the voltage to be sure.
Post back if you have any questions.
Posted on Nov 18, 2007
MNTECH
  • 1543 Answers
SOURCE: LG fridge model LRDN22724SW.
Still can not find that exact model number. Similar numbers I found were:
LRDC22743SW, LRDC22744SW, LRDN20724WW, LRDN20725SW, LRDN22712SW, LRDN22720WW, LRDN22725SW, LRDN22734WW
Posted on Oct 06, 2008
MNTECH
  • 1543 Answers
SOURCE: HAVE AN LG FRIDGE MODEL LRFC22750. THE LIGHT
EFFECTIVE FROM(SERIAL NO.) from 704MR***** to 801MR***** Subject Lamp Cover Melting Improvement (LG 3D Basic) / 2nd No. Loc No. Before Change After Change Note K-Code Remark Part No DESC./SPEC. Part No DESC./SPEC. 1 501A 6871JK1011A PCB Assembly,Main /
6871JK1011D PCB Assembly,Main /
WINNER1 DISPENSER ENERGY STAR '08 C 3 Change Relay SPEC. 2 503F 3111JJ1001X Case Assembly,Display /
WINNER1 BASIC BRAND ABQ33905315 Case Assembly,Display /
SOLO PARA SERVICIO, NO PARA PRODUCCION C 3 Thermoprotector addition. 3 503F ABQ33905304 Case Assembly,Display /
SOLO PARA SERVICIO, NO PARA PRODUCCION C 3 Thermoprotector addition. 4 409B 6912JK2002C Lamp,Incandescent /
60W 120VAC 0.40A 480LM - WHITE 6912JK2002E Lamp,Incandescent /
C 3 60W to 40W
Posted on Jun 12, 2009
  • 2468 Answers
SOURCE: Side by side Admiral freezer freezes but fridge
check the damper vent door between the refrige and freezer and make sure its opening up to let cold air from freezer into the refrige,sometimes they freeze up and cant open and close when called upon to do so,if so deice it with a hair dryer,the side being hot is good telling you the compressor is operating correctly
Posted on Jul 28, 2010
heatman101
  • 43501 Answers
SOURCE: my Lg Gn-205SQA refridgerator
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Mar 15, 2011
Hi I have an lg fridge gn 422fw and it has had freezer motor replaced it was fine for a few days now it is freezing ok bu not cooling in the bottom can you give me an answer to this
Could not locate model no. So could give you no part numbers. But would check defrost control board, defrost thermostat or most likely defrost heaters. Also would check wiring as tech who installed motor may have loosened a wire.
Jul 13, 2017 | LG Refrigerators
When i press defrost button it stucks inside it, is it normal???
Hi
If it is a manual defrost fridge with a push button defrost then yes the button stays in until it has finished the defrost cycle.
But as no model & make have been provided this is just a in principle answer.
Bryan
Apr 29, 2015 | Refrigerators
My LG refrigerator GN-V191RLZ defrost button got stuck
Lg refrigrator model GL -195/2008. The defrost button not work after the ice will melt
Aug 03, 2013 | LG Refrigerators
LG refrigerator noise sound.
This is under warranty call for repairs.
Jul 10, 2013 | Refrigerators
Defrost Timer
Probably a control Board problem. Without model #, I can't say for sure, but your fridge probably has a defrost board and not a timer.
Sep 05, 2017 | LG LRFC22750ST French Door 22.4 Cu. Ft....
My Lg Gn-205SQA refridgerator has a problem: the freezer is ok, but hte fridge is not cool
heatman101
Mar 15, 2011 | LG Refrigerators
Its a LG GN-466FW after looking at it it was iced up & the fan wasnt working
We have the same problem and the same model fridge/freezer LG GN-466FW. Can you tell me if you got your problem fixed with no cooling in the fridge compartment ?
Feb 11, 2011 | Refrigerators
Motor noisy, stops when open refrigerator door
i had this problem then turned off fridge freezer for 24hrs and it was gone it was more or less needing defrosted
Apr 29, 2010 | Samsung Refrigerators
Refrigerators Logo
81 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Mike
Mike
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
