Question about Wagner Air Tools & Compressors
Remove and Install prime/spray valve Wagner paint crew airless paint sprayer?
  • Wagner Master
  • 1,899 Answers
Was the unit purchased new or used? The price of a new is about $125-170. This unit is for homeowner occasional use, not for large jobs.Was the unit working on the previous use? If so were the cleaning instructions followed and not shortcut. If paint is failed to be totally removed on cleanup it will dry inside unit.There are very few replacement parts for this unit. If the unit is not working take wrench and try to remove prime/spray valve. You will have to remove knob to access this part.
Posted on Apr 19, 2017
What cain of oil a cant uuse for wagner 1250 hp
Your Wagner 1250 is a diaphragm airless sprayer, which uses hydraulic oil to push the diaphragm, so the oil must be hydraulic quality as it gets quite hot; don't use any other type. The Wagner part number for their quart size is 0088009
Jun 15, 2015 | Wagner SprayTech Wagner Airless Paint...
Does a Wagner Paint Crew sprayer take lubricant?
The Wagner Paint Crew airless sprayer does not require oil for its operation like full professional sprayers. The piston is off-set from the pump chamber with the inlet and outlet valves opposite each other, however you need to protect the parts from corrosion between use and Wagner recommend running some light oil through it after cleaning. If you will be using it in a day or so for water based paint, you could run a 10% solution of their EasyGlide through it.
Sep 30, 2014 | Wagner Spray Tech Wagner Paint Crew 2750...
Won't prime
You either have a stuck ball valve, or a leak in the paint suction
Feb 09, 2014 | Wagner SprayTech Wagner Airless Paint...
Unit won't prime,
YOU HAVE A STUCK INLET BALL
Have the unit in water, pressure relief valve turn the machine on and tap with a hammer at the inlet ball, This frees it up 90 of the time.
Otherwise the machine need to be disassemble
Jan 29, 2014 | Wagner SprayTech Wagner Airless Paint...
Will not prime
Most of the time when a unit will not prime it is because of a stuck inlet ball, I would put the intake in water turn the machine on to bleed. Then tap the machine where the paint comes in. 90% of the time this will get it going. Sometime you can stick a screw driver into the inlet ball and free it up. If this doe not work you need to take the machine apart and cleanor you have worn out packing.
Joe
Jan 23, 2014 | Wagner SprayTech Wagner Airless Paint...
Shoots drips
Most airless spray guns spit a bit when you pull or release the trigger because the paint between the spray tip and the paint valve is under pressure but not enough to atomise the paint. If you increase the pressure you may reduce the spit to a point when you don't notice it. A blocked filter could slow the paint getting through to the tip cause lower pressure.
Jan 03, 2014 | Wagner SprayTech Wagner Airless Paint...
Old Wangner Cap Sprayer & Compressor
The Wagner Capspray 9000 HVLP is about 20 years old, but you should be able to find parts, at least for the HVLP gun. The manual for the turbine is #0276989. If you are in the US try Scott at American Airless Wagner Titan Graco Paint Sprayers or in Europe try us at:
Home Lion Industries
Jul 28, 2013 | Wagner Spray Tech Cap Spray Paint Sprayer,...
Wagner 404 Plus Airless motor stops.
All airless sprayers are on-demand pumps. The two settings are prime and spray. When it is set to prime, the pump will draw liquid from the bucket below and pump it out the side tube and will never stop until you switch it back to spray. When set to spray, the pump will run until the pre-set pressure is reached, then stop. As soon as you start spraying, the pump will run until a few seconds after you stop spraying. Tip size and pressure setting will affect how long after you stop spraying the pump will run. A large tip and high pressure will cause the pump to run longer after you stop spraying.
Sep 02, 2017 | Wagner Air Tools & Compressors
AL2340 will not prime. Motor runs but cannot get it to prime
I worked at a tool rental center when I was going to college and learned many useful tips / tricks about airless sprayers. Airless sprayers have two check valves/balls that can stick on their seats or stay open due to chips of paint on seat. Easy method to prime is to remove intake filter from machine, tilt the machine back far enough so that the pick-up tube is pointing up high enough to pour water in tube until full; hold in this position and turn on machine. If water is sucked in turn off machine and tilt machine into pail of water and restart to check for prime. If it still will not prime remove water from pickup tube and use air pressure into tube with bypass valve open. Air pressure will attempt to release the stuck lower check ball. If air pressure does not release stuck ball you may have to use physical pressure against ball. If lower check ball was stuck you can assume that the upper check ball is probably stuck also. An aid to loosen stickey valves is to pour solvent into pickup tube with machine tilted back as before leave overnite. Enjoy
Dec 09, 2008 | Campbell Hausfeld Airless Spray Guns &...
Air Tools & Compressors Logo
186 people viewed this question
Top Wagner Air Tools & Compressors Experts
Jim Parker
Jim Parker
JOHN LAPIER
ray gallant
Are you a Wagner Air Tool and Compressor Expert? Answer questions, earn points and help others
