Question about Refrigerators
Summing fridge model number Rl40pgmh is flashing E 3 on temp what dose this mean and how do I get it off
3 Suggested Answers
SOURCE: samsung side by side fridge/ freezer model number
Hi, there is a known fault with the Samsung RS21 units. If you unit is less than 5 years in luck, it is covered by the Extended warranty they have put in place. Apparantly this was featured on BBC watchdog!. i've had the same problem and had it fixed free of charge by Samung. Either raise a service request on the Samsung uk web site, www.samung.com/uk or call the customer services on 0845 7267864 and explain you description. the noise is an ice build up which stops the internal fan pushing cold air around the fridge. the bootom of the fridge , in the drawers is cold?
Posted on Sep 04, 2009
richroth
  • 9472 Answers
SOURCE: my refrigerator a model ffhs232mwo frigidaire has two temp controls, the freezer is holding a solid number, but the fridge number is flashing 4 any ideas
The Flashing #4 occurs when power is applied to the fridge and the control board goes through it's cycles and didn't detect a damper connection.
So its your air damper that's bad.
Here is the part to order.
Posted on Dec 02, 2012
I have frensh door kenmore elite fridge model number 795.72053.110 display error code if someone cane please help me ? ER F5 WHATS THE MEAN .... THANK YOU SO MUCH
faulty cercit board is what you have there sorry to say but it dose happen every so often get in touch with the poeple who you got it off and have the engineer look at it
Jan 22, 2015 | Kenmore Refrigerators
Fridge temperature shown is +14. Unsure how to set temp to say +6
Usually the model number and info is on a sticker on the back of the fridge , you will more than sertainly have to move your fridge to find this info.
Feb 08, 2013 | Refrigerators
My refrigerator a model ffhs232mwo frigidaire has two temp controls, the freezer is holding a solid number, but the fridge number is flashing 4 any ideas
Dec 02, 2012 | Refrigerators
Fridge too cold!
don't forget that just turning down your fridge temp dose not mean your problem might be over yet. the freezer setting may also be too high & that will affect your fridge temp as well. i set both my control settings to around 50% of what is on the scale & that works perfect for my 7 yr old fridge. also, very important, is make sure the freezer portion is going through it's full defrost cycles, or it will freeze the upper portion inside the fridge. you should not have any frost build up in your fridge, nor should you have any in your freezer. that's why they call them FROST FREE. try the slow temp decrease over a period of a few days & hopefully that will work for you. good luck.
Dec 01, 2011 | Refrigerators
My fridge keeps freezing how do i change the temp settings
Hi!!
You didn't mentioned brand and model of your fridge, so I will give you a general answer.
Usually the controls are in the fridge compartment, either on the right or back upper wall. Usually is one control for the freezer and another for the fridge. The normal settings should be about 1/3 of the dial's range, ie. If dial have 9 numbers, the setting should be between 3 and 4, depending on use and outside temp.
Wait 24 hrs. between adjustments to allow the system to stabilize.
.NOTE:
The Freezer Temp. Dial is the main temp. controller, if you set it too low, it may not have time to cool fridge side properly.
Good Luck!! Don't forget to rate this post!!!
Aug 03, 2010 | Refrigerators
The control panel flashes "EC" where the fridge temp is displayed. The word "service" is also flashing.
"EC 50" means excessive refrigerator compressor run time. What is the serial number? Is the condenser fan running? Can you feel airflow from the left side up top? Is the strip between the fridge and freezer hot to the touch?
Mar 10, 2010 | Sub-Zero 680 / F
FLASHING E8 (WARNING) ON MY FRIDGE FREEZER
A model number and serial number would help in any diagnosis.
May 04, 2008 | Freezers
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
