Where can i get a lid for my modele depose sgdg its a old machine but still works great the lug on the side has broken off
4 Suggested Answers
  • 619 Answers
SOURCE: Broken Lid on WelBilt Bread Machine Model ABM1H70
Hi , try to visit the web site of fixya recommended site : Alibaba.com
Posted on Mar 20, 2008
blueextc3221
  • 15935 Answers
SOURCE: Broken lid
Head over to the manufacturer's website.
Typically they have a SUPPORT section - where you enter the FULL model number, and then can get a parts breakdown and ordering information.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 16, 2010
  • 6 Answers
SOURCE: The plastic lugs to the
yep, happens to most all of them eventually. mine has broken twice. i had it repaired at the camera shop and the next time i put in new batteries it broke again. i'm sticking to a piece of tape. i've seen you can buy the replacement door online and i've seen the instructions for replacing it yourself via a google search.
Posted on Dec 04, 2011
I NEED A LID FOR THE MODEL 4259 BRAUN 550MM IT IS DUSCONTINUED
If you have broken off that little lug that activates the switch you might have to figure out a way to add a tag to your existing lid to activate that switch. Those lids have been obsolete for ages now so not a lot of hope finding one.
Dec 09, 2014 | Braun Food Processors
Any recalls on Kenmore Model # 110.20022012 Washing machine?
I think that your "LID Switch" is broken, go to www.sears.com/parts and put your model number in and you'll see the lid switch listed.
Aug 28, 2014 | Kenmore Washing Machines
How do I replace a lid switch for model # awm392w
I own 20 speed queen top loaders that the same machine as yours.
they are 19years old and have never had a lid switch go out.
the problem is the arm that activates the switch gets bent and can activate the switch. to fix take the 2 screws out of the left side of the lid hinge then tilt the lid to the side and slide the right side out. this is the arm that activates the switch . looking at the top of the lid bend the arm up just a small amount. them put it back on the machine and try it you may have to bend a little more to make it work.
Jan 18, 2013 | Speed Queen Washing Machines
Washer wont cycle
Number 11 is your lid switch. It is very easy to repair. To test it watch the video.
Older models would wash with the lid open but not spin. This later model washer won't wash or spin with the lid open so I suspect you have a broken lid switch. IF that turns out not to be the case then I would next check the motor start capacitor. When these fail the motor won't work at all.
On your machine you gotta have a long skinny screwdriver . On the back side of the washer you back out a screw on each side and then she pops up.
I gotta whole page of stuff on these washers HERE
Nov 01, 2011 | Estate TAWS850PQ
Had new timer and new water gauge and still stops between cycles and won't drain
what is the model number?if it's an older machine you could have a broken lid switch or a broken motor coupling.close the lid down and open it a few inches,do this a few times,if you don't hear a clicking sound you have a broken lid switch,if you can hear the motor running and the machine isn't moving you broke the motor coupling.let me know how old it is and the model number
Oct 02, 2010 | Whirlpool Washing Machines
How do I change the lug bolts on a 2-wheel drive 94 toyota truck
Get Hanes book on your truck might just be few screws that hold it on. There a great product its not WD it got yellow lid for rusted parts on cars buy that sutff works great to remove your Lug Bolts. Those fun i did mine on my cobra had spray the back side the bots beat the living hell out them get them out, Putting then back in no easy task either.
Jul 29, 2009 | 1994 Toyota Pickup
Washing machine not spinning
you didn't state what brand, but i'm thinking kenmore or wpl. broken lid switch. replace.
Jul 26, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Fisher & paykel machine locked but lid is up
It sounds like the lid lock is either stuck or broken,You will need to lift the top hob by removing the two plastic lugs where the lid rests & removeing the screws it will then lift up and you will be able to remove the lock to inspect it,Also you can remove the lid in the up position by pulling vertically to make it a bit easier,Hope this helps Cheers.
May 21, 2009 | Fisher and Paykel Fisher & Paykel Washer
Spin Cycle on Wash Machine does not work
You probably have a defective lid switch. If you open and close the lid, you should hear a "clicking" sound as the lid switch is activated. If you do not hear the switch, check to make sure the lid strike in still intact. This is a small plastic piece mounted on the lid that pushes down on the switch through a slot on the wash tub opening on the right hand side. If this piece breaks off, it will give the same symptoms of a broken lid switch. Next, check the two mounting screws on the right side of the wash tub opening to make sure they are tight. These are the mounting screws for the lid switch. Sometimes they come loose and the switch does not make proper contact. If you attempt all these preliminaries, and the switch still does not seem to be working properly, replace it. A replacement can be found at searspartsdirect.com. Just type in your model number and the part will be located under the "Top and Cabinet" heading. If you need assistance in determining a part number, please post back with your model number. For instructions on how to replace a lid switch, click on the following link:
http://www.fixya.com/support/r385198-replacing_lid_switch
This is a very simple and inexpensive repair. However, if you require additional assistance, please let me know. I hope this helps you.
Aug 02, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
21 people viewed this question
Top Washing Machines Experts
