Question about NAD Televison & Video
NAD T550 DVD player the picture is fine, even sound effects but convos are silent. I tried everything in the settings and the cables. So I can hear everything except convos. What can be the problem?
techman
  • 3130 Answers
SOURCE: No picture while playing DVD or VHS tape
Your unit has it seems to have developed a video problem. it could be in the video switching IC or the video processor. Its going to need a trained technician, who knows how to use an ocilliscope to find the video problem.. Good Luck
Posted on Aug 02, 2006
micromaster
  • 3614 Answers
SOURCE: PS3 been working fine over
TV Connectivity
The issue of connectivity between the PS3 and the display is very complex and depends on the type of TV (Analog, Digital or HD Ready), the maker of TV (until recently, only Toshiba TVs have component AV connections as standard in Europe, most other Euro TV sets use SCART which can not carry an HD signal) and specification of TV (the very latest HD Ready TV sets have wider connectivity options than earlier HD "capable" TVs from the same manufacturer which may have lacked HDMI), and finally the configuration of the PS3 model purchased.
Posted on Feb 18, 2008
  • 9 Answers
SOURCE: Panasonic TX32LMD70: split and green picture from DVD
Cut feed lead to pin 16 (in the scart not the equipmend!)
Does not matter which end. It just stops the TV from switching to RGB- The DVD is sending non standard RGB - PanamanNE
Posted on Jun 22, 2009
SOURCE: Sharp LC-26SH12U TV. Sound
My Sharp TV LC-26sh12U when at 50 is not good. After a hour or two I can hardly hear the program. What is happening?
Posted on Jul 09, 2009
bob_computer
  • 3153 Answers
SOURCE: I can hear everything except the voices of the
are you playing PROPER dvd's or COPIES ?
Posted on Aug 12, 2009
NAD T550 remote control
you must go to radio shack or other electronic parts electronic, or some appliance stores and search for the remote.
God bless you
Jul 13, 2012 | NAD T550 DVD Player
I have a JVC HD 52g787, the sound works but no picture, The tv comes on, but the blue light just blinks, then cuts off, I have sound no picture
The problem is usually from the power or the Y sustain at the left or right side of the display when one of the large capacitor or heat sync on the capacitor even the flat power cable connection it to a main power board needs to be checked too, if the fuses on the board are blown it will need to be replaced
But after replacingthe fuses and the capacitors and still no solution,youwill need to replace the all board ..
You can also trouble shoot first before going to the board of the TV..
How to Troubleshoot an LCD With Sound But No Picture
It can be overwhelmingly frustrating when an electronic device as expensive as an LCD television set starts having problems. Luckily many of these problems are easily troubleshot. While being able to hear sound coming from your LCD television but seeing no picture may seem serious on the surface, fixing the problem involves checking a few different settings to make sure everything is set properly
Instructions
Check the video connection of any devices plugged into the LCD television. If you can hear sound but are seeing no picture while trying to use something like a DVD player or cable box, the problem is probably that a wire is loose somewhere. Check the yellow video cables running from the DVD player to the TV and make sure everything is plugged in firmly and where it should be. Also check the coaxial cable running from the cable box (or cable outlet) to the television and make sure that wire is also screwed in securely.
Check the image settings on your television and make sure everything is set properly. Certain settings like "Picture" or "Brightness," if set to one extreme, can make the picture appear completely black. This could cause you to simply hear television shows but not be able to see them. Reset all picture settings on the TV to their original factory default settings to see if that fixes the problem.
Try another channel. If you're watching TV and not getting a picture, the first thing you should do is check a variety of random channels to make sure it is a problem with your TV and not with your television signal. If it is a problem with the television signal it is the fault of the TV station or cable service provider and there isn't anything you can do yourself to fix it.
Try the DVD on another DVD player. If you're trying to play a DVD and can't see any images, make sure the disc isn't defective. Try it on another DVD player or a computer DVD drive and make sure the disc works in the first place.
Hope it helped ..
Jul 17, 2011 | JVC HD-52G886 52" Rear Projection HDTV
Everything was working fine, then the sound quit working when we play the DVD player. Switch back to TV-DVR mode and sound is fine. Change o DVD and it goes silent. We have to turn up the volume on the...
please try to find new firmware for this model, I guess it is HDMI version compilable problem. maybe after update firmware could fix your problem
Mar 17, 2011 | Yamaha HTR-5560 Receiver
NAD C740 Chanel B Speakers not working The speaker output A is working properly, then the output B is completely silent. I install differents speakers and even the same speakers. no sound from the B...
possibly the causes are: 1. defective channel B power amp board. But try operating first with the built in tuner, if it's ok the RCA cable from your other sources(DVD player, etc...) might have broken internal conductor.
2. if it has the speaker switch(A, B, A+B) try toggling it, might also just loose contacts.
if the trouble is #1, leave everything to your trusted qualified technician, he knows what to do, unless you want to tweak/repair it by yourself...hope this helps ;-)
Feb 03, 2011 | NAD C740 Receiver
The NAD T-550 doesn't seem to be willing to play CD-Rs. Is there any update or adjustment that can be done that will allow it to do this?
Best bet to go to their website, support, enter you model number and see if a firmware update is available.
Aug 11, 2010 | NAD T550 DVD Player
My NAD T550 cannot play DVD's with a heavily painted top (i.e. newer DVD's). Older DVD's (with just text written on top) works just fine. Also, burned DVD's play fine as well. What could be the problem
The heavier paint is keeping the dvd from spinning at it's optimal speed. Not much you can do about it except get a new player that can handle it.
Oct 07, 2009 | NAD T550 DVD Player
My NAD cd/dvd T550 displays NO DISC.
I have the same problem. When I insert a disk, my NAD T 550 DVD player displays 'No Disc'. It started with new disks while still reading older disks, but at some time it stopped recognizing any disk. Did you receive any suggestion yet or has anyone a suggestion?
Jan 27, 2009 | NAD T550 DVD Player
Plays dvds on xbox 360 fine, but no picture for games/dashboard
already solved it. thanks. i couldn't see the xbox settings blade because of the blank screen so switched my component cable to the tv setting instead of the hdtv setting, then i could see the dashboard in non-hd and switched the resolution to 720p while simultaneously switching the component cable back to the hdtv setting. that worked.
Jan 02, 2009 | Sharp Televison & Video
Televison & Video Logo
24 people viewed this question
Top NAD Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Raj Patel
 Grubhead
Grubhead
Are you a NAD Televison and Video Expert? Answer questions, earn points and help others
