Question about Gainsborough Home
Why is my Gainsborough 2000x shower not heating the water passing through?
Shower unit and pull down cord light up as normal. Dial does not activate medium and hot levels of temperature. On the left hand side power is lit up and reduced temperature
  • 100 Answers
I sounds as if the element has failed... if you isolate the power to the shower you could test the element with a multimeter..
Posted on Apr 19, 2017
Got a gainsborough shower no water is coming out when i switch it on and the low flow light in coming on
inside the shower unit theres water connection to unit ,turn the water and power supply off and check the water conn filter its on the connection comming into the shower its most prob blocked good luck
Feb 18, 2011 | Hardware & Accessories
My Triton Millenium shower just stopped working mid shower. Power lights went off. Have checked fuse, power ok but will not switch back on. Any ideas.
there is a cut out unit on top of the element *** unit which is to prevent damage to elements if the water supply fails but i have 3 of these fail down to use have checked the triton spares and the only show it with the element unit cost over £100 you can bi pass it with out any problems just make sure always turned off at pull cord when not in use or phone to see if you can just buy the cut out if you cant its shame on them good luck spares number 08449800745
Jan 10, 2011 | Home
Hi, Advice please, my shower when on hot comes normal out of the shower head but when water temperature normal it stream out of the bottom of the wall fitting, gainsborough shower 2 years old approx....
If you are taking about then neck of the shower head this is what you must do. its no need to turn the water off to the house or to the bathroom first you will need a pair of channel locks and some Teflon tape. first remove the shower head if you dont want to scar the nut on the shower head place cloth between the pliers and the fitting, once removed (very important) turn the channel locks upside down stick one side of the blue handle up in the neck of the shower and rotate to your left to loosen if you are having a leak leak there it should already be semi loose, once removed wrap the threads with the Teflon tape and re-insert making sure it is tight, then wrap the the outer end of the neck with Teflon tape and place the head back on.The reason it leaked is because the plumber who installed it did not tighten it up completly because he wanted it to look straight coming out of the wall and the additional water pressure causes it to leak wheras the hot water causes it to expand and seal
Jul 08, 2009 | Water Pik Wall Mount Shower Head
No water coming out of shower
First you should check the screens st the ends of the hose to be sure they are not clogged. The shower head as well. Otherwise it could be the water control valve, solenoid or thermal cut off.
Mar 02, 2009 | Home
Gainsborough Shower Running Cold
It sounds like you have a faulty thermostat or broken heater element.
Oct 08, 2008 | Home
TRITON Trance electric shower
I have a triton trance shower not working with power and water both connected properly! low pressure light coming on and nothing happening????
Mar 27, 2008 | Dishwashers
Home Logo
Top Gainsborough Home Experts
john h
Tom Chichester
Are you a Gainsborough Home Expert? Answer questions, earn points and help others
