Question about Ariens Garden
Ariens 1640 zero turn will not turn over. Replaced the solenoid. Not the battery and not the starter. Help!
SOURCE: starter will not engage-soleniod just clicks-
I had this problem last year. I was told by a reputable Yamaha service technician that I could "jump" the leads on the solenoid to unstick it. It worked. However, in retrospect, I wish I would have just replaced the solenoid, given that it is a relatively cheap component (~$40 new). Since then, I had the sticking and clicking problem again this past March right at the beginning of the season, and during my attempt to repeat the success, I shorted out the bike because I got careless about what my disconnected wires touched on the bike. Shame on me. So I'd recommend replacing the solenoid.
Posted on May 24, 2009
  • 59 Answers
SOURCE: briggs & stratton 18 HP intek ohv won't start
check the safety switches one of them are bad
Posted on Jun 27, 2009
panilling9
  • 284 Answers
SOURCE: Cub Cadet zero turn will not start with the key
basically you fixed it youself
if your solenoid is engageing and your wiring is clean and tight from the battery positive to one side of the solenoid and from the other side of the solenoid to the starter?
then you need to replace your solenoid.
Posted on Jul 07, 2009
wd4ity
  • 4565 Answers
SOURCE: bike wont start replace start solenoid.when
You didn't mention what year model your bike is so I'll just generalize my response. Since you said that you replaced the solenoid, I'll assume that your bike is a 1988 model or earlier.
Your bike has a starter relay if it still has the stock wiring on it. Harley has used a starter relay since 1965 on the first model of ElectraGlide. Usually, it's underneath the battery tray or the seat or around that area.
On the back of your solenoid, you have three wire connections. Two very large connectors and one small connector. Make sure your bike is out of gear (in neutral) and use an old screwdriver to short between the large connector that comes from the battery and the small wire connection. The starter should engage and try to start the engine. If the ignition switch is on, it will start the engine. The starter will turn using this method with or without the switch being in the "on" position. If the starter works using this method, the problem is in either the relay or the neutral switch. If the starter does not turn the engine over, the problem is in the solenoid.
Now, let's check a few things. The small connector on the back of the solenoid should have a green or pink (depending on year) wire on it. Using a voltmeter or a test light, make sure you have voltage at the connector when you press the starter button with the switch in the "ON' position. If not, follow the wire to it's source, the relay.
The starter relay can be one of several different designs used throughout the years. It could be a small plastic cube, a small metal can, or a round phonelic relay. The relay should have four connections on it. A "hot" wire, a wire from the handlebar switch, the wire going to the starter, and a ground. The ground may be through the case itself. On the older Shovelhead bikes (1984 and earlier) there was a small short black wire that ran from the starter relay to the transmission for the ground. This wire must be intact or the relay would not work due to lack of a ground.
When you turn the switch on, one of the wires to the starter relay should become "hot". When you press the start button, you should hear a slight click and another of the smaller wires should now be "hot" as well, the one going to the starter.
On some year (1972 and later) models, the neutral switch was wired in with the starter relay. This was to prevent the bike from starting while "in gear" by disabling the relay. You'll have to figure this one out for yourself since I don't know what year model your bike is.
Now, you said you had power to the solenoid when you pushed the starter switch. So, let's assume that the starter failed the first test to told you aboue. If so, the problem is still most likely in the solenoid. Inside the solenoid, there is a large plunger with a copper disc on it. When you depress the starter switch, the coil in the solenoid becomes magnetized and pulls the plunger towards the back of the solenoid. This does two things, it engages the starter drive with the ring gear on the outer clutch drum and makes a high current electrical connection. The copper disc makes contact between the two large connections on the back of the solenoid from the inside. This connects the battery to the starter motor through the solenoid. If the black phonelic plate on the back of the solenoid is cracked or the contacts inside of it are badly burned, it will not work.
Now, if the solenoid is working correctly and you are getting voltage to your starter, it could be the brushes or something inside the starter. This is indicated if the starter trys to turn the engine over but just can't. It won't have enough power if the starter field windings are bad.
I hope I've given you something here that will help you solve your problem. This is basically the electrical part of the starter system. There are mechanical parts as well. If you hear the starter turning but the engine doesn't turn over, you have a mechanical problem. You can either repost or you can contact me directly at wd4ity@bellsouth.net I'll help if I can. Good Luck!
Posted on Nov 05, 2009
  • 2239 Answers
SOURCE: Cub Cadet LT1050-Replaced the solenoid, had starter checked out-it's good, battery has full charge, but mower won't start. Help!!
You need to check that there is a 12volt supply from the low tention wire at the solinoid when the key is turned, if there is not either the switch is bad, or the wire from the switch is bad, or the fuse has blown.
Posted on Mar 07, 2012
I have an Ariens mower, 20 hp B + S engine. Ran 4 wks ago. Started yesterday, solenoid clicked. Recharged battery overnight. Now I hear the starter spinning but won't engage motor ...help!
sounds like the gear on top of the starter is striped.. fairly cheap and easy to fix. there are videos on you tube that show how
Nov 02, 2016 | Ariens Garden
When I try to start my 60" Ariens rider all I get is a loud clattering sound. I just replaced the battery 2 months ago. What's wrong with my mower?
Joel, Recheck battery to make sure it has good charge >12 v and all battery and starter wiring,plugs,connections are clean,tight and undamaged. If you remove spark plug and engine spins freely from the key, the engine compression release or valve clearance needs adjusted. It is probable the solenoid or starter is faulty, the starter Bendix/drive may be sticking. If you can, give the starter a couple sharp raps with a hammer or bar and then try to start.
Check the attached links,instruction and guides to help diagnose starting issue. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://troybilt.custhelp.com/app/answers/detail/a_id/86/~/clicking-sound-while-attempting-to-key-start---riding-mower
What Are the Symptoms of Bad Starter Motor on Riding Mower Engine
My Bolens lawn tractor won start It just clicks when turn the key even...
Craftsman riding mower won start Just clicks the starter motor
Aug 27, 2016 | Ariens MaxZoom60 60" 25HP Kohler Zero Turn...
Key just clicks the solenoid. bridging solenoid engages starter and turns over. new spark plugs.
Make sure the key is providing good power to the solenoid. If it is the the solenoid is bad.
Jul 31, 2016 | Ariens Garden
Need instructions on how wires attach to solenoid
One large wire to one large stud, the other large wire to the other large stud, and the small wire to the little side screw.
Jun 07, 2014 | Ariens Zoom 42 In 165 HP Briggs Stratton...
Where is solenoid
If your looking for the starter solenoid it is located by the batter... It will have 2 prongs and a thick red and black wire connected to it.
Sep 14, 2013 | Ariens Pro Zoom 60" 27HP Zero Turn Lawn...
The little red button I pull to engage the cutting blades on my Ariens 1640 zero turn is not making them engage
Make sure all safety switches are in good condition then check the switch you are talking about. If you have a multimeter you can check continuity of this switch or you can go to a local dealer and replace switch. They aren't too exspensive.
I’m happy to assist further over the phone at https://www.6ya.com/expert/layne_0fccff498c319c32
Aug 09, 2013 | Ariens Garden
BATTERY HAS FULL CHARGE WHEN I TRY TO START IT IT DOES NOT TURN OVER NO CLICKING NOTHING CAN SOMEONE HELP ME. ARIENS 1740
Check to see if the solenoid is getting power. On the solenoid there are 3 wires. Two big, one from the battery, the other going to the starter. The 3rd wire is what activates the solenoid. Using a test light or volt meter. See if its getting power on the small wire when you turn the key. If no power, ignition switch, safety switches or fuses. If you are getting power replace the solenoid. If you have 4 wires. Test the two smaller ones.
Oct 17, 2012 | Ariens Zoom 42 In 165 HP Briggs Stratton...
How do you pull the starter off of an Ariens zero turn lawnmower. I need to replace the starter.
Expose the engine and take off a few covers and you will accomplish your task young Jedi... May the force be with you................
Apr 18, 2011 | Ariens Zoom 42 In 165 HP Briggs Stratton...
Ariens Sierra 1440H Lawn Mower
the solenoid is sticking inside the housing
Apr 30, 2010 | Ariens Lawn Mower Universal Solenoid...
Ariens zero turn will not start
Have you done a load test on the battery? It may be time for a new one 300CCA. Plus the solenoid may not be working right. you will know more because of lack of information or symptoms.
Good Day.
Nov 07, 2009 | Ariens Garden
Garden Logo
112 people viewed this question
Top Ariens Garden Experts
Phil Walker
Phil Walker
Matt Olenzek
Matt Olenzek
enb54
Level 1 Expert
Are you an Ariens Garden Expert? Answer questions, earn points and help others
