Question about Ford Computers & Internet
My Ford Focus 2006 2.0LTDCI start up but died in 2-3 sec and did not ref up when started. When accelerator are pushed down it smoke a white smoke without reffing up.The car was standing for 10 min.
Braam Labuschagne
    Top Expert:
  • Ford Master
  • 24,773 Answers
White smoke is usually water in the block and can be caused by a blown head gasket.
Posted on Apr 18, 2017
My car won't start in a very frosty mornings
The heavy smoke is from all the fuel dumping in to the cylinders without enough heat. Can you plug the car in at might if not glow the plugs sevral times befor turning the engine over.key on few sec then off then on several times. Hope this atleast helps your cold start problem.
Feb 21, 2015 | Ford Cars & Trucks
My 2003 Ford Focus would not accelerate, and kept dying on me, now wont start, do you know what could be wrong?
A strong possibility of a defective Throttle Positioning Sensor (TPS)...It can be tested with a volt meter...TPS is located on the throttle body (see diagram below) & has a three pin connector with following wire colors; Brown (ground)...Yellow (+5 volts)...And White (TPS output)...Set meter to 5 volt dc...Push point,of safety pins into the Yellow and Brown wire at rear of connector...Do not disconnect connector...connect + lead to Yellow pin and - lead to Brown pin...Turn key on...Meter must read at least .08 volts...Open throttle full...Meter must read at least 4 volts...If not TPS is defective...Send results...NOTE>>>Diagram is based on a 2.0L Single Overhead Cam Engine, if your vehicle is different let me know...saailer
c39c38e9-1e2b-4d1e-b695-576183306462.jpgCost about $30
Jun 25, 2014 | 2003 Ford Focus
2003 ford focus died
hi there.
see if this link helps you out.
2003 ford focus died Google Search
Nov 10, 2017 | Cars & Trucks
Ford focus tdci not starting and white smoke coming out of the exhaust
It is a clear case of the glow plugs malfunction. It had happened with my neighbor who tried to start his diesel focus one day.
Even jump starting with another battery didn't solve the starting problem.
You could also check the EGR valve for damages and if you want to save a couple of bucks, then go in for used parts for the focus from Good used Focus Stuff
Mar 29, 2013 | 2001 Ford Focus
Ford focus tdci white smoke problems
What happening is you have a bad head gasket or its starting to go bad. As long a little oil is getting in to cylinders causing that smoke once it warms up that gasket is expanding thus the smoke stops. I would keep an eye on oil levels if it gets milky replace gasket asap. Could also be intake gasket but highly doubt it this sounds like a worn head gasket.
Nov 27, 2012 | 2006 Ford Focus
Ford Focus Deisel chokes on acceleration
Hi mate.
This sounds like a fuel problem.
Some one may have have filled up with petrol. If so you will have to drain the feul tank and change your feul filter.
If only diesel has been put into the tank then carry on as follows until you solve the problem.
Change your fuel filter and air cleaner for a start.
Check your timing.
If you still have the problem, then have your injectors cleaned and reset.
If the problem is still there then you will have to have the fuel pump reconditioned.
You can also check your leak off pipes between the injectors to see if they are in good condition.
I trust this will help you.
Sep 01, 2009 | 2004 Ford Focus
CAr starts fine, but will not accelearate
check butterfly valve if it is opening wide maybe accelerator cable is not pulling enough or it's sticking
May 14, 2009 | 2000 Ford Focus
Ford accereration problem
sounds like you egr valve is faulty does your eng light come on.
Apr 10, 2009 | 2004 Ford Focus
Sounds as if you are running extremely lean.Has EGR been bypassed maybe?
What is fuel pressure,on that vehicle the fuel pressure regulator may be adjustable.Some of these had an allen screw inside the vacuum port where you could richen the mixture some.Also try backing down on the timing a few degrees.
Mar 03, 2009 | 1991 Ford F150
Computers & Internet Logo
Top Ford Computers & Internet Experts
Lawrence Oravetz
Vladimir Frolov
Are you a Ford Computer and Internet Expert? Answer questions, earn points and help others
