Lipi t2250 hardware alarm error +0002 +000---- 000032 0017 Paper pulls via single path.but not pulls via tractor
  • 169 Answers
SOURCE: Tally T2250 Matrix Printer does not pull up paper to be printed
I would guess you are getting error messages on the diplay to tell you what the bleeping noise is about....Please read this message.....
I would guess the message is something like LOAD SINGLE, and you are using tractor feed paper. If this is the case the paper path on the pritner has changed and needs to be changed to Tractor 1 again.
To do this;
  • Stop any prin jobs gong to the pritner
  • If the printer has data in its buffer, power the printer off and back on again to clear this data
  • Ensure the printer is OFFLINE
  • Press the SETUP button
  • Press the button under ADJUST
  • Press the button under PAPER WAY
  • Use button 2 or 3 to change this to TRACTOR 1
  • Press SET
  • Place the pritner ONLINE
You should be back in action, if not post the message you see on the printers LCD display.
Posted on Oct 02, 2009
  • 150 Answers
SOURCE: HPLJ 4350 paper jam
First you need to clean the machine. Next you need to try a nother toner cartridge. If it still does it you mite need a fuser.
Also does the paper reach the fuser?
Posted on Jan 22, 2010
SOURCE: my lipi 6306 line printer showing error "paper
Dear Sir,
Problem in paper calibration, u can go through given details 1) Offline, Test, Daig, Calib, Paper out, Enter, then u see Remove paper. then press enter. sum reading will come (4.something). After insert paper, (2.something). And Save == Offline enter, config enter, configuration enter, save enter, Power up. enter.
Next option 2) U can check the paper out sensor front one black sticker missing.
Parashuram Patil
Posted on Jul 01, 2010
SOURCE: T2250 giving error in harware alarm code
Check whether AGA Gear working Proper or not OR giving noise after power on printer
If AGA Gear not working proper insert the steel rod in AGA gear properly
Posted on Oct 31, 2010
SOURCE: Tally 2250 Matrix printer
tally printer give hardware alarm on every problem gear aliment is very important in tally cheak for function sensor
Posted on Dec 24, 2011
Tally 2250 gives eject error single
The paper path on the 2250 has changed to the single sheet feeder, I guess you are using tractor fed paper loaded into the standard front tractors, if this is the case you can change the paper path to Tractor 1 in the following way;
1.Power the printer off and disconnect the printer from the computer system.
2.Press and hold down the SETUP button, and power the printer on. Keep the SETUP button held down whilst the printer initialises (this unlocks the printer menu)
3.When the printer has finished initialising release the SETUP button.
4.Make sure that the printer is in Offline mode; press the Online key, if necessary.
5.Remove any paper that may be loaded into the printer.
6.Press the SETUP button
7.Press the button under PAPERPATH (button 3)
8.Press the button under TRACTOR 1 to select the tractor feed
9.Press the ONLUE button to exit the menu.
Dec 13, 2011 | Tally T2250 Matrix Printer
How to run tractor1 and tractor 2 Tally T2250 ?
The first thing you would need to do would be to ensure you have two sets of tractors. The second set of tractors is an option not on the standard printer.
You can fit the second set of tractors to the front or rear of the printer
You can select either of the two tractors in the following ways;
  1. Via the control pannel menu
  2. If printing from Windows by selecting the appropriate paper path when printing
  3. If you are able to insert control codes into your data stream you can use escape commands to change the paper path
Nov 30, 2011 | Tally T2245 Matrix Printer
How to install paper in oki microline 320 turbo printer
Paper Loading
Rear Feed, Continuous Forms
Use the rear-feed path for printing on single-thickness,
continuous-form paper.
Use the single-sheet path (top feed) for graphics or charts.
! If you have paper in the paper path, be sure to remove it
before installing rear-feed paper.
1 Lock Lever
2 Upper Tractor Cover
3 Pins
4 Lower Tractor Cover
32T-26.eps
1 Move the paper lever to the position marked "REAR."
32T-11.eps
2 Grasp the tabs lift off the paper separator.
3 Pull up on the lock levers and open the tractor covers.
Then, move the right tractor to fit the width of the paper.
32T-27.eps
4 Place the first two holes in the paper over the tractor pins
on either side. Close the tractor covers.
32T-29.eps
5 Move the left tractor to align the edge of the paper with
the appropriate reference mark (1). Then, push back the
lock lever.
32T-29A.eps
6 Adjust the position of the right tractor to center the holes
in the paper on the pins. Then, push back the right lock
lever.
32T-29.eps
7 Install the paper separator. Place the wire guide (1) on the
pull-up roller assembly (2).
32T-31.eps
8 Press FF/LOAD. The paper feeds into the printer.
! The factory default setting for the Top of Form (where
the printing should begin) is one inch down from the top
of the page. To change the setting, see "Using Your
Printer, Top of Form (TOF)."
Top Feed (Single Sheets)
Use the single-sheet path for letterhead stationery, memos,
and individual envelopes.
! If you have continuous-form paper in the path, press
PARK to remove it before loading single sheets.
1 Make sure the printer is on and deselected (SEL light off).
2 Place the paper lever in the position marked "TOP."
32T-12.eps
3 Open the carriage cover. Raise the paper separator to the
single-sheet position.
4 Make sure the wire feed guide (1) is secured in the sheet
guide.
5 Adjust the paper feed guides (1) for the width of the paper.
Place a sheet of paper in the separator. The paper will feed
into the printer.
32T-15.eps
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy New Year!
Thanks, Joe
Jan 04, 2011 | OKI MICROLINE 320 Turbo Matrix Printer
Printer is not printing with these pages alternating"online single load" and "load paper from single"
The printer is indicating that the paper path has been changed (either via the control pannel on the printer or by escape command) to the single sheet feeder.
I guess you are using Continuose Paper fed into the tractors at the front of the printer (Tractro 1), if this is the case you need to go into the menu on the printer and change the paper path back to Tractor 1.
Take the printer off-line by pressing the Online key
Press the Setup key
Press the key under "Paperway" in the display
Select Tractor 1
Press the key under "Set"
This should change the peer path to the front Tractor, if this does not work power the printer OFF and disconnect it from the computer system. Then power the printer back on again and again try changing the paper path as described above.
If you get the message LOAD SINGLE only when you send data to the pritner you need to check the paper path selected on the computer system.
Jan 25, 2010 | TallyGenicom 2280 Matrix Printer
Eject Error message
I would suspect that the paper path has been changed via the control panel. If you are using continuous paper fed in from the tractor this should be Tractor 1 (unless you have optional tractors).
If the printer shows something like SINGLE on the display, it is for sure that the paper path has been changed.
Disconect the pritner from the computer system, and power the pritner off and ofter 10-15 seconds power the printerback on again.
  • Take the printer off-line by pressing the Online key
  • Press the Setup key
  • Press the key under "Paperway" in the display
  • Select Tractor 1 (or Tractor 2 if fitted/required)
  • Press the key under "Set"
  • If the menu shows as locked power the pritner on holding down SETUP to unlock the menu.
    Nov 18, 2009 | TallyGenicom T2265 Matrix Printer
    Tally T2250 showing an error..
    when power on the printer the printer coming leftside and showing hardware alarm
    check ribbon
    +0306ne -007 000
    000000128 +0304
    error in display. how to rectifie the problem
    Jan 29, 2009 | Tally T2250 Matrix Printer
    Tally printer hardware alarm home postion
    There is a broken gear(s) in its mechanism that's why you are having this hardware alarm message.
    Dec 07, 2008 | Tally T2250 Matrix Printer
    To do this;
    • Press SET
    Dec 18, 2007 | Tally T2250 Matrix Printer
    32 people viewed this question
    k24674
