Question about Hard Computers & Internet
Not booting from cd/dvs drive, hard drive. - Hard Computers & Internet
    New Friend:
  • 14 Answers
Go into the BIOS: depending on your computer has soon as you press the power button press either del, f1 or f2 it normally tells you at the bottom of the screen. once in the BIOS change the boot settings, at the moment it's probable set to boot from the harddrive first. so you have to change it to boot from the cd/dve first
Posted on Apr 18, 2017
Trying to put win 7 on hard drive says no bootable device insert boot disk and press any key put in boot disk and nothing
if you have win 7 on a disc and you want to put it on the hard drive , try this
on start up hold down alt+ delete to get into bios
change the boot up from hard drive to cd as primary start up boot up
put the disc in a cd and close it down
restart and the pc should then boot from the disc in the cd drive
you should be able also to simply put the disc in the cd, go to computer , click on the cd drive and run and that should put the win 7 on the hard drive
talk with a computer shop for other ideas as to how to do it if that doesn't work
Nov 29, 2016 | Cell Phones
Does not boot, is not seen by my computer, neither Mac nor Windows PC
go into the bios on start up (alt+control+ delete) buttons all down together
find the boot section and turn on boot from cd
allow all cd units and it will find a cd ( external hard drive ) and boot up
take it to a computer shop and have them set it up
or
If your computer is working and you want an external hard drive to save to-- open the computer and with the external hard drive switched off, plug in the usb cables. turn on the hard drive and the computer will recognize it as a plug in unit and search for the correct driver
it may ask for a disc for installation or search on line ( use the disc in the cd drive in the computer)
from there the wizard will install the external hard drive
May 06, 2016 | HGST LifeStudio Desk 2TB USB 2.0 External...
How do I unlock the Bios on an Acer ES-1 111M Laptop
To boot from a CD, DVD or USB device, make sure that the device has boot sequence priority over the hard drive.
BIOS Boot
BIOS (Basic Input Output Subsystem) is a programmable chip that controls how information is passed to various devices in the computer system. A typical method to access the BIOS settings screen is to press ESC, F1, F2, F8 or F10 during the boot sequence.
BIOS settings allow you to run a boot sequence from a floppy drive, a hard drive, a CD-ROM drive or an external device. You may configure the order that your computer searches these physical devices for the boot sequence.
The first device in the order list has the first boot priority. For example, to boot from a CD-ROM drive instead of a hard drive, place the CD-ROM drive ahead of the hard drive in priority.
Before you set boot priority for a USB device, plug the device into a USB port.
To specify the boot sequence:
  1. Start the computer and press ESC, F1, F2, F8 or F10 during the initial startup screen. Depending on the BIOS manufacturer, a menu may appear.
  2. Choose to enter BIOS setup. The BIOS setup utility page appears.
  3. Use the arrow keys to select the BOOT tab. System devices appear in order of priority.
  4. To give a CD or DVD drive boot sequence priority over the hard drive, move it to the first position in the list.
  5. To give a USB device boot sequence priority over the hard drive, do the following:
    • Move the hard drive device to the top of the boot sequence list.
    • Expand the hard drive device to display all hard drives.
    • Move the USB device to the top of the list of hard drives.
  6. Save and exit the BIOS setup utility.
  7. The computer will restart with the changed settings.
Boot Priority Options
Some computer manufacturers allow you to select the device that contains the boot sequence from a special device selection menu. The example below uses a Dell system board.
To set boot priority using a device selection menu:
  1. When the computer starts to boot up, after the manufacturer's ID screen, press F12 several times. The device selection menu appears.
  2. Use the up and down arrows to select CD-ROM or
May 04, 2015 | Acer Aspire Computers & Internet
Ntlrd missing xp tablet on my hp tc1000 with no cd rom
Causes
  1. Computer is booting from a non-bootable source.
  2. Computer hard disk drive is not properly setup in BIOS.
  3. Corrupt NTLDR and NTDETECT.COM file.
  4. Misconfiguration with the boot.ini file.
  5. Attempting to upgrade from a Windows 95, 98, or ME computer that is using FAT32.
  6. New hard disk drive being added.
  7. Corrupt boot sector / master boot record.
  8. Seriously corrupted version of Windows 2000 or Windows XP.
  9. Loose or Faulty IDE/EIDE hard disk drive cable.
  10. Failing to enable USB keyboard support in the BIOS.
Solutions
Many times this error is caused when the computer is attempting to boot from a non-bootable floppy disk or CD-ROM. First verify that no floppy diskette or CD is in the computer, unless you are attempting to boot from a diskette.
Note: This error has also been known to occur when a memory stick is in a card reader and the computer is attempting to boot from it. If you have any card reader or flash reader make sure that no memory stick is inside the computer. Additionally disconnect all USB drives, cameras, ipods, iphones, etc. from the computer.
If you are attempting to boot from a floppy diskette and are receiving this error message it is likely that the diskette does not have all the necessary files or is corrupt.
If you are attempting to install Windows XP or Windows 2000 and are receiving this error message as the computer is booting verify that your computer BIOS has the proper boot settings. For example, if you are attempting to run the install from the CD-ROM make sure the CD-ROM is the first boot device, and not the hard disk drive.
Second, when the computer is booting you should receive the below prompt.
Press any key to boot from the CD
Important: When you see this message press any key such as the Enter key immediately, otherwise it will try booting from the hard drive and likely get the NTLDR error again.
Note: If you are not receiving the above message and your BIOS boot options are set properly it's also possible that your CD-ROM drive may not be booting from the CD-ROM properly. Verify the jumpers are set properly on the CD-ROM drive.
Verify that your computer hard disk drive is properly setup in the CMOS setup. Improper settings can cause this error.
Corrupt NTLDR or NTDETECT.COM file
Windows 2000 users
Windows XP users
Sep 24, 2011 | Computers & Internet
Starts with disk drive 0 seek failure. hit f1to continue then blue screen with stop: 0X0000007E (0XC0000005, 0X83AF9630, 0X8A6BC7B4, 0X8A6BC4B0) appears. Any help?
Your computer is not able to boot from your hard drive. That means that:
1) Your hard drive is defective
2) Your software on the hard drive is corrupted and needs to be reloaded
To determine if your hard drive is bad, you will need a bootableCD, you can use your "Dell Resource" CD or any other bootable CD disk. Power on the laptop and tapthe F12 key to get to the "Boot Selection Menu". Insert the "Resource CD" intothe CD-ROM drive. Select "Boot from CD/DVD drive" from the selection menu. If it boots from the CD you have a problem with the hard drive.
Feb 18, 2011 | Dell Inspiron 530 Desktop Computer
My laptop wont boot. It makes a loud whirring
take whatever CD you have out of the CD/DVD drive. You might have the boot order set to CD first. If that's the case, it's trying to boot from your CD drive instead of your hard drive.
Feb 19, 2010 | Toshiba Computers & Internet
Can not boot from cd rom...bios boot order is set
Set all in Boot priorty to CDROM
Set Other Boot Device to No.
Jan 07, 2010 | EliteGroup NFORCE 570 SLIT-A Motherboard
I want to istall a new Hard drive, and I want to
Assuming you don't already have a second drive with an OS loaded then you will just need a boot disk or a Windows XP installation disc. Install the drive and then insert the CD. Power the PC on with the disk in the drive an you should get a message to boot from CD, just answer yes (note: the PC may boot automatically off the CD). If this doesn't work then you will probably have to go into the bios and change the boot order to make the CD as the first boot source. Entering the bios is different on each PC so, you will just have to find out the key sequence, usual buttons are ESC, F2, or CTRL+DEL.
Nov 17, 2009 | HP Pavilion Elite M9400F PC Desktop
Thinkpad 390x 2626, won't boot from cd drive
Try pressing F12 at startup, you should get a boot option.
Nov 19, 2008 | Computers & Internet
Os instalation will not load
Hi Dobssand, the most common reason for a CD-ROM (With a Windows CD in it) does not start to load is the motherboard's bios is not set correctly. While in the bios go to the title Boot & enter boot order. This is a common boot order for a PC.
1st boot device = [Floppy disk drive]
2nd boot device = [CD-ROM drive] (Model number of the CD-ROM drive).
3rd boot device = [Primary Hard Disk Drive] (Model number of drive).
Second most common reason is the data cable to the CD-ROM drive is loose or not fully connected either at the CD-ROM or at the motherboard. (Check it).
If you choose not to enter your bios, you can still get the CD-ROM drive to boot the Win CD in this fashion. Load the Win CD into the CD-ROM drive. Power off the system. Than power on the system & start to press the F8 key once every two seconds. Windows "Please select boot device:" window will open. Using your keyboards up & down arrow keys high-light the CD-ROM drive that has the win CD in it & press the enter key. Windows should start to load. If you receive an error message stating windows can not find your hard disk drive. Than you must enter your bios & go to the title Boot. Your hard disk drive is not listed in the boot order section. Worst case! Your hard disk drive may be faulty. Find the manufactures name printed on a large white sticker on once side of the HDD. Go to the manufactures web site & download their drive setup software so you can create a bootable floppy disk. This will allow you to check/test the HDD & format it for a windows installation.
Or is this not the issue you are having?
Mike
Sep 26, 2008 | Computers & Internet
Computers & Internet Logo
32 people viewed this question
Top Hard Computers & Internet Experts
john smith
Nyte_Ryder
gbob59
Are you a Hard Computer and Internet Expert? Answer questions, earn points and help others
