How to reset visio42 inch tv - Televison & Video
  • 604 Answers
Unplug for 10 minutes
Posted on Apr 18, 2017
Testimonial: "Rebel tryed first now have back off no power through power cord keep trying bro"
  • johnny rebel Apr 18, 2017
    Power Cycle
    To power cycle your TV, power it down and remove it from electricity for a short time to reset it, similar to selecting the Restart option on your computer to reboot it. A power cycle is usually the best choice for minor issues like the occasional frozen TV or slow performance from the TV's menu.
    Power off the TV by pressing the Power button on the remote or on the side or back panel of the TV.
    Unplug the TV from the power outlet. If you use a power strip, you can switch off the strip's power switch or disconnect the power strip from the power outlet.
    Press and hold the Power button on the side or back panel of the TV for 10 to 15 seconds to drain residual power.
    Plug the TV back in to the power outlet. If you're using a power strip, switch the strip back on or reconnect the strip to the power outlet.
    Power the TV on using the Power button on the remote control or the TV's back or side panel.
    Restore Factory Defaults
    If a power cycle doesn't resolve the problem, restore the TV to factory defaults, but jot down your picture settings and other personal settings first -- including app and wireless network passwords -- so you can quickly reset your personal preferences. When you restore the TV to defaults, your TV returns to the state in which it came out of the box.
    Press the Menu button on the remote control.
    For Vizio VIA models, select Help followed by Reset and Admin and then Clear Memory. Some Via models don't have the Reset and Admin menu, only Clear Memory.
    For Vizio VIA Plus models, select System followed by Reset & Admin and then Clear Memory.
    Select Clear Memory/Factory Defaults or Reset TV to Factory Defaults -- depending on your TV model and current firmware version -- and press OK on the remote.
    Enter the Parental Control PIN code when prompted. If you never configured a PIN, the default code is 0000.
    Select Yes when prompted. At this point, the TV restarts and runs through the factory reset process. Leave the TV alone during this process.
    Run through the initial setup when the setup prompt appears on the screen.
I have fussion led 32 inch tv i pressed reset it turned picture upside down how can i fix it
Go to service mode and there should be an option to flip the picture, not sure why this should happen when selecting reset as its more common when replacing the main board
Nov 08, 2017 | Televison & Video
I would like to know on how to reset a 32 inch chinese made samsung plasma tv from burning mode
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Jul 06, 2016 | Samsung UN32EH4000 32-inch LED TV
How do I reset my Samsung 40" TV uversion no: TS02
you have to go to menue and reset as manual of tv telles you
Oct 13, 2014 | Samsung 40-inch LED TV - UN40EH5000FXZA...
You would need to do a factory reset
From the Sony Forums:
factory reset to your Television.
  1. Turn on the TV.
  2. Wait approximately 40 seconds for the TV to completely start up.
  3. On the TV remote control, press and hold the UP ARROW button.
  4. While holding the UP ARROW button, with your other hand reach around the side of the TV and press and release the POWER button on the TV set.( not the power button on the remote) it should be the top button along the side panel.
Sep 06, 2014 | Sony BRAVIA KDL46EX720 46 Inch 3D 1080p...
Devant lcd tv 40 inches
Unplug the TV from AC mains wall socket, and re-plug it back after 10 minutes or so. This will make it a hard reset. If you wish to do a system reset, you should enter its service mode option.
Dec 02, 2013 | Televison & Video
27 inch sansui tv is there a reset button
reset button have desapear on tv sets 20 years ago
Sep 28, 2010 | Sansui 27 inch TV
Used insignia 32 inch with DVD. want to reset
most manafactors codes are 1234 or 0000 or 5555 or 8888 you might have to put extra didget on EG 12345 -00000 - 55555 -88888 but if you changed it sorry dont know
Nov 10, 2009 | Insignia NS-L32Q-10A 32 in. HD-Ready LCD...
My 52 inch sanyo tv just went blank can't get it
Try unplugging it for 8 hours for reset. If this doesn't work, then fuse or power supply is faulty.
Sep 04, 2009 | Televison & Video
RCA 56 inch projection TV
six inches will just reach the bottom of the main cuircit board. Does the units green light flash? there is no reset hutton there is a fuse. but i would suspect if it got wet then something blew
Feb 17, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
