Question about Panasonic Kitchen Ranges
Hi dear experts . I have a problem with a Panasonic KX-MB772 multifunction product . There is paper jammed when machine starts to copy or print .
At first seems pick up sensor failure but when we check the sensor by ohm meter , it has correct function and pick up rubber and pad rubber are okay also . What do you think ? Thank you .
Kindly help me to down load install this machine
P K Kutty
Posted on Apr 01, 2009
  • 87 Answers
SOURCE: I have Panasonic KX-FL612 fax machine , the paper gets jammed and the fax is saved in memory . when i release the jammed paper I can not print the fax in memory . How can I print the fax in memory ?
when fax gives msg ,fax in memory,just remove jammed paper .put fresh papers in tray.if the msg is coming on screen that fax in memory just press START key.there is a green button labeled as fax start .u will receive all faxes in memory.MIAN AKHLAQ .do not forget to rate the solution.
Posted on May 19, 2009
  • 13433 Answers
SOURCE: paper jam ,no paper jam found Dell 1815dn
give this a try
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Posted on Jun 12, 2009
  • 2306 Answers
SOURCE: paper feed problem
You can try to clean the rollers with alcohol, usually it's just the paper dust and ink that makes them lose traction. With the back door open you can clean the roller with alcohol on a Q-tip.
Posted on Jan 10, 2010
Testimonial: "After getting your answere,it did fix that problem. thank you v"
SOURCE: How to get the Panasonic KX-MB772 DRIVER
i have having a problem panasonic kx mb772 call service 3 can i fix it.
Posted on Jan 29, 2010
I have panasonic kxmb 772 all in one printer and it show drum replaced error so i have find problem help plz..........
I have Panasonic MFP KX-MB772, but I have a trouble to print many page in one time, after one sheet out/printed, than the monitor seem paper jammed. I need the solution to solve this problem. Thamk for help...
Jun 24, 2011 | Office Equipment & Supplies
How to download free Panasonic Kx Mb772 Printer Driver..
Go thru the below Link and download.
Hope this helps. If it does, pleaseaccept and rate the solution! Contact me with any more questions you may have.Thanks for using FixYa!
May 26, 2011 | Panasonic Computers & Internet
Dec 14, 2009 | Panasonic KX-MB271 All-In-One Laser...
Kitchen Ranges Logo
24 people viewed this question
Top Panasonic Kitchen Ranges Experts
ray gallant
Are you a Panasonic Kitchen Range Expert? Answer questions, earn points and help others
