Where is thermostat located air conditioner in Toyota hylux 1 KD DIESEL
    Problem Solver:
  • 20 Answers
Bottom radiator hose try there
Posted on Apr 18, 2017
Red engen light came on 2008 d4d Toyota hylux pickup
run the fault codes to find the fault that put the light on
Nov 28, 2015 | Toyota Cars & Trucks
2008 Ram Mega Cab with a 6.7 liter diesel. Where is the air conditioner fuse?
Usually not a fuse, but rather a circuit breaker--small metal can 1/4" by about 1" located in main fuse block.
Jun 09, 2015 | Dodge Ram Cars & Trucks
Toyota hylux 2014 radio keeps loosing signal
Hi glen when did this thing happen? Did u put an after market radio? Whatever the case is try to check the antenna located behind the radio itself it may came loose or u have a broken wire somewhere hope this help
Jan 23, 2015 | Toyota Cars & Trucks
Duo therm ac in my rv quit when the converter burned up does the ac need 12v to work?
there is a fuse located under the shroud on the roof AC on a circuit board that controls the thermostat to turn on the power to the Air Conditioner replace it it is marked F-1 or, on some F-2 etc.
the air conditioner works on both DC voltage for the thermostat and AC voltage for the compressor
Sep 08, 2013 | Dometic 3312024.015 Duo Therm Comfort...
Toyota Avensis heater problem
check for clogged cabin air filter, located behind the glove box. See owners manual for directions on how to remove the filter.
Feb 09, 2010 | 2004 Toyota Corolla
230/208 Volt Built-In Room Air Heat/Cool Unit blows cold air, not heat. Unsure if it may be thermostat, if so.. where is it? Another one blew fuse. Where is it located?
To locate the fuse;
1. Turn the power off or unplug the Room Air Heat/Cool unit.
2.Follow the power cord of the unit. This will normally
terminate at the fuse terminal/power reset button., where you can replace the fuse.
3. After the fuse/power reset button terminal the wire
go to a thermostat normally located at the air output
section at the front portion before it goes to the motor
and heating element, while the other wire may connect direct from the fuse terminal to the motor or
heating element.
This is just the basic electrical set up, it can be modi-
fied. Hope this will guide you in locating the fuse and
the thermostat.
fied
Jan 06, 2010 | GE Built-In Room Air Heat Cool Air...
No cold air.
Is the air conditioner completely dead? See section 1. Is the thermostat knob turned to the proper setting? Is the compressor motor running? The compressor is a football-sized case with no apparent moving parts. It is located inside the air conditioner at the center. Is it humming or making any kind of continuous noise or causing the lights to dim? If it is making a continuous noise, and your air conditioner is still not cooling at all, there may be a serious problem with one or more of these areas:
  • Compressor
  • Condenser
  • Evaporator
These items are not user serviceable. You will need to contact a qualified appliance repair technician to repair these components.
If the compressor is not running but you do have power to the air conditioner there may be a problem in one or more of these areas:
  • Compressor
  • Overload and/or relay
  • Thermostat (Open thermostat)
  • Burnt wiring
  • Bad selector switch
  • Capacitor
May 26, 2009 | Fedders A7D18E7B Thru-Wall/Window Air...
Heating & Cooling Logo
27 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
