Question about Whirlpool Dishwashers
Top rack only rolls out halfway after dishwasher "repairman"? visit, (to fix a water problem, which is now fixed..._.
I've had this Whirlpool built in for 10 years. Works like a champ. Lately the dishes were not getting as clean, so I called a repairman. He changed a valve, said the unit wasn't getting enough water. Now, that's fixed, and top rack only rolls out halfway..... very frustrating.
    Master:
  • 604 Answers
Take it out and turn it around
Posted on Apr 18, 2017
No water coming out of middle arm. top rack not getting clean
https://www.google.com/url?sa=t&source=web&rct=j&url=http://www.doityourself.com/stry/dishwasher-spray-arm-not-working-common-causes&ved=0ahUKEwjhuqfSvLnTAhUQ52MKHek2CU0QFggsMAE&usg=AFQjCNECCjLXsUCOl1f7tBZk4XKiD6-aNQ&sig2=durQuvOod-A9SNuJ5aKKCg
Apr 23, 2017 | Whirlpool Dishwashers
My Whirlpool Quiet Partner II does not clean the upper rack of dishes properly. They are greasy. I have checked the top spray arm for blockages. There were none. I am fairly certain that water is
Make sure the center loading is not obstructing the water jet to the top shelf. Top shelf is only for glasses and saucers , use Jet-Dry .Pre rinse and clean bottom pan strainer from dirt debris.
May 14, 2012 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool DU1055XTSS Quiet Partner 1 is not cleaning top rack
the sprayer is clogged with ****. I had the exact same problem. my mother-in-law gave me of some 80 year old man that has fixed appliances all his life. Ten minuets after he got to the house it was fixed. cost $70.00. He just took a couple things apart dumped out the **** inside the parts and put it back together. Hope this helps.
Jun 02, 2010 | Whirlpool 24 in. DU1055XTPS Stainless...
Top water injector not working
I had the same problem and fixed it by disassembling the lower spray arm and return filter, and cleaning all the junk out.
Most dishwashers have 'risers' that bring the water up to the top sprayer or arm located under the top rack. If the recirculating pump is plugged even a little there won't be enough volume or pressure to get the water up there.
Test this by putting a dry muffin pan in the top rack, flat, and running the dishwasher for a bit. If there is no water on the top (or the bottom) either the top sprayer or the sprayer arm underneath the top rack is not getting enough volume.
To fix this you need to clean out the screen and filter, where the water returns to be recirculated. If you don't have any confidence to remove the parts and clean it out yourself, get an appliance repair person to do the job.
Aug 24, 2009 | Frigidaire 24 in. FDB126RB Built-in...
Kenmore Dishwasher Holding Water
lost your tube that supplies water to upper spin rack? look in your strainer
Apr 14, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool Gold dishwasher
Either:
  1. not enough water gets into the dishwasher. check water valve, water level float and water pressure.
  2. the pump is clogged - there is water, the motor will run but no water is circulated. Check pump filters, check chopper and impeller.
Good luck,
Vlad
First Choice Appliance
Mar 21, 2009 | Whirlpool GU2700XTSB / GU2700XTSQ /...
Dishwasher doesn't clean the top rack whwn we riun it.
sounds like the jets are cloged you can try a small wire to try and unglog the jets that or you water does not have enoph pressuer hope this helps
Feb 12, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool built-in dishwasher - has sprayer for lower and upper racks. Have had to have repairman out to clean out dishwasher as residue blocks water from getting to upper rack - is there any way to do...
Yes, you will need to purchase a set of torx style screw drivers at your local hardware store. Remove the upper and lower spray arms and clean the debris out of the spray holes. Remove the screws that hold the filter in place and remove the gunk out of the sump. In the future stop using gels or gelpacks, just use electrasol powder or cascade powder. The gels and gelpacks clog up dishwashers like you would not believe. Run some Lemi-shine through the machine on a monthly basis, Lemi-shine is available at most walmarts.
Jan 15, 2009 | Whirlpool 24 in. GU1200XT Built-in...
My Whirlpool dishwasher is only 2 years old and I started having the same problems. I dismantled everything I could and washed and scrubbed the entire unit with EVERYTHING..to no avail, dirty dishes!! But I discovered a remedy! Try using Lemi-Shine for about a week with your regular wash-soap. If you are using the tablet form of soap, stop and try the powdered form. Follow the instructions on the Lemi-Shine container. You can find it just about anywhere for around $3.50. I was within "5 seconds" of replacing my 2 year old Whirlpool dishwasher when this caught my eye and I figured why not try it too? After the first wash I noticed a big difference the cleanliness of the dishes..and now it is running GREAT after 2 weeks!
Sep 22, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
