How does one do a burn out
In a car
Tube burning wont. however before nice like burning. hardship where?
First this is a car site. That looks like a small heater plate for cooking. It is out of gas or the valve is bad...
Nov 11, 2016 | Cars & Trucks
Does putting egg whites on burns have any effect in relieving and eventually curing the burn area?
Hi Robert:
First off, this section is about Cars and Trucks so unless you burned yourself on your vehicle, I'm not allowed to answer.
Assuming you did, I've heard that it does work. Before I tried it, I'd research it.... Google "egg whites for burn treatment" and, I'd sure discuss it with my doctor if I had a serious burn.
May 29, 2015 | Cars & Trucks
Why does fire burn u
Because its hot. Not only will fire burn you but any material or object that is hot can burn you or cause scorching or smoke. An electrical charge can burn you. Leaning against a hot car in the heat of the sun can burn you. Very hot water can burn you. A iron left on can burn you. A stove top burner or oven can burn you. If it's hot, IT BURNS! !
Mar 25, 2015 | Cars & Trucks
99 300m car is burning too much gas
I'm curious why/how you know it's burning to much gas. If your just getting bad gas mileage or smelling fuel out of the tailpipe check your plugs an possibly do a tune up. It's pretty hard to acctually burn to much gas. More info on the problem will get you better answers
Sep 22, 2014 | Cars & Trucks
Car dashboard lights wont turn on and smell of burning wires
If you're smelling insulation burning - STOP. Fuses should be blowing before insulation melts / burns.
Have the car checked my a trusted mechanic before using anything in the car that makes the wiring burn or melt.
Apr 16, 2014 | 2001 Ford Taurus
Blue smoke
Blue smoke (how many miles on engine, 50k or 500K???????
to some this means, burning oil, others steam
it that blue smoke lingers a long time that is oil burning
and smells just like oil burning.
and means 2 things,
1: engine burns oil.
2: if car had autotmatic trans the vacuum modulator love fail
and suck ATF fluid to the intake plenum and burn it, and bingo burning oil like mad.
3: PCV valve packed solid,and forces engine to leak oil or burn oil. or both. this is a 50k miles service point, skipping this?
4: gas in the oil making it thin and not sneaks past valve stems.
does oil change cure this.>?
now engines.
worn out engines smoke. (burn oil)
as do bad valve guides and seals.
and bad piston rings.
100 years same story, and miles matter. History on engine too.
matters.
Feb 26, 2014 | Geo Metro Cars & Trucks
Burning smell
If it smells like burning a burning plastic/ceramic then your brakes are locking up and burning. Next time it does it, see if the smell is coming from the rear tire. if so, its time for a brake job
Nov 11, 2013 | Acura Cars & Trucks
Pioneer mofet won't play mp3s
Well IF your player burns mp3 do a few things.
Confirm the disk plays in something else
Re-burn on the slowest setting for burning.
Try a different brand disk
Aug 20, 2012 | Pioneer DEH-2900MPB, MOSFET 4x50W Max WMA,...
I have a 2007 Mitsubishi Endeavor. In less than 1,000 miles it has burned a qt. of oil. It only has a little over 40,000 miles on the engine. This is the second oil change in a row that it was low. The...
no it should not burn oil...specially for a new car like that...the older the car gets...the more oil it burns...but you need to check the head cover gasket...
Good Luck!
Oct 11, 2010 | 2007 Mitsubishi Endeavor
Music cd burning
Burn in normal mode.
Jul 06, 2009 | 2005 Volkswagen Passat
Computers & Internet Logo
13 people viewed this question
David Payne
David Payne
