Question about Samsung Washing Machines
Why Samsung washer WF457ARG has no hot water when washing, but when we run pure cycle, the machine has hot water
faggly
  • 74 Answers
SOURCE: Maytag performa washer hot water runs continuously
Littleone.. please check your instructions.. some washers now dont need Hot water connection to them...they heat their own as part of the efficiency settings on the wash programmes themselves!
Regards Faggly
Posted on Mar 19, 2008
  • 177 Answers
SOURCE: water in my washing machine
it sounds like you have a leaking water valve, you will have to replace the mixing valve, For now turn the water off at the wall suppling water to the machine. When you want to use the washer turn on water, when its done with the cycle turn the water off.
Note: unplugging the machine will not stop the water from running
Posted on May 13, 2008
SOURCE: washer won't run through a complete cycle-stops at 29 minutes
There is a service manual behind the control panel it will show you how to test the door locks. If might have a bad lock solenoid.
Posted on Aug 18, 2008
IrishDruid
  • 2712 Answers
SOURCE: Washer will won't run cold water cycle
Some washing machines allow cold water to enter only during certain cycles. Others intermittently allow hot and cold to enter, to temper the temperature of the water. Consult your owner's manual if you are unsure about whether the machine is acting abnormally.
If you're sure the machine is not working the way it used to--or should--check the following.
  • Is the cold water turned on? If not, turn it on.
  • Is the washer getting hot water but no cold water? If so, check to see if the control panel settings are correct.
  • Is there cold water coming through the proper hose? If not, check to see if the screen inside the water-inlet valve is clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If it's clean, you probably have a defective water-inlet valve. If so, you need to replace the valve.
  • Hope that helps! Should you have any further questions, please feel free to post them here.
    P.S. – I would greatly appreciate a FixYa! rating if the solution I provided fixed or helped you fix your problem.
    Thank you for using FIXYA!
    Cheers!
    IrishDruid
    Posted on Oct 12, 2008
    • 51 Answers
    SOURCE: machine will only allow very hot water to enter machine
    the cold water solenoid may need to be replaced
    Posted on Jun 12, 2009
    Even in pure cycle setting we frequently get an E8 error. just now, it did it while filling with water for pure cycle. this machine is less than 4 years old and is costing me a fortune in repairs and costs...
    An E8 code indicates a water cooldown issue. You might check to be sure the hot and cold water connections are not reversed
    As for the clothing destruction issue, you might check back with test results for your machine when new. It could be a persistent problem.
    Feb 26, 2015 | Samsung 4.0 cu.ft. VRT Top Load...
    Kenmore Elite HE3 does not work with Pure Wash system
    One of the things to try is get a Y connector for the machine. Hook both ends of the Y to the washer at the hot and cold, then connect the last part to the pure wash. The HF error is HOT FLOW so it is not seeing any hot water pressure. The actual temperature should not be an issue. Also if you have too much water pressure you wont see the bubbles. If that happens just start turning down the cold water valve on the connection to the pure water unit until you see bubbles in the viewing window. I ams sceptical about these machines because you have to reduce the surface tension of water in order for it to clean, that is partly the job of heated water and laundry soap. Also if there is an ozone generator in that unit, there is a consumable part because ozone needs electrolysis to be generated. I cant help but wonder where the hydrogen goes when it is generated.
    Feb 26, 2014 | Kenmore Elite Washing Machines
    Hot water keeps filling tub and does not quit
    the washing machine is designed with a timer limit switch have the switch checked.
    Oct 19, 2012 | Samsung WF448AAW 4.5 cu. ft. Front Load...
    Washer only washes with hot water
    consult your owner manual about you are unsure about if the machine is acting anormally
    Some machines, is running hot water during cycles, other cold water during cycles.
    God bless you
    Jul 18, 2012 | Washing Machines
    Admiral washing machine water not hot enough during all cycles.
    newer washers have a temp sensor and the washer is programed for around a 100 to 110 degrees F, depending on manufacturer, so if your washer is new it is doing what it is supposed to do, sorry.
    Jan 03, 2012 | Washing Machines
    My samsung frontload washer stopped steaming at the end of cycle
    Is your hot water valve open all the way? If you run the washer on a hot cycle only, does it fill up?
    Nov 17, 2011 | Washing Machines
    Regards Faggly
    Mar 19, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
    Washing Machines Logo
    32 people viewed this question
    Top Samsung Washing Machines Experts
    Jaime Hernandez
    shaun taylor
    Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
