Question about Measuring Tools & Sensors
I have an Ascot GT-WS-08s Weather Station. The outside sensor is showing LL for both readings. I have replaced the batteries in both units. Any manual for this model?
4 Suggested Answers
  • 474 Answers
SOURCE: not picking up outside unit
you have to have the station and the sencers close to each other when you put in the bats and then give them about ten mins
Posted on Nov 08, 2009
Testimonial: "thanks - working now! :-)"
SOURCE: Omnitech Wireless Weather Station model
Push and hold down the channel button, wait for beep, then on the sensor, push and hold the tx button, wait for beep.
Posted on Nov 16, 2010
SOURCE: Sharp Weather Station Model SPC344 The outside
After inserting the batteries, DO NOT set the time until the OUTSIDE temperature registers. That's the trick.
Posted on Nov 06, 2011
The outside temp won't show up on my new weather station
  • Remove all batteries
  • Install batteries in outside unit and wait for it to begin sending temperature signal to inside unit.
  • Install batteries in inside unit. You should see outside temperature displayed.
  • If this doesn't work, the outside unit may be defective.
Apr 04, 2018 | Measuring Tools & Sensors
I have the Atomic Clock model W86111. I had to change the batteries on the outside device. The clock outside temp just flashes 63.5 all the time. How do I make it sync to the device outside?
Remove all batteries from outdoor sensor and weather station.
Press one of the buttons on the weather station at least 20 times to clear all memory.
Verify that the weather station is blank before proceeding (there may be lines painted on
the screen that will show when power is removed).
Leave both units without power for 15 minutes (very important).
Insert fresh batteries into the clock.
Insert fresh batteries into the outdoor sensor.
Press the TX button on the outdoor sensor to transmit RF signal.
Keep the outdoor sensor 5-10 feet from the forecast station.
When RF connection is established, the temperature will appear on the station. Allow the
outdoor sensor and weather station to sit together for 15 minutes to establish a strong
connection.
Oct 14, 2017 | Home
Barolo AU9 weather station. I replaced batteries in the outside temp unit. how do I activate it to show outside temp on the main inside unit
  • Remove batteries from both units
  • Install batteries in outside transmitter and wait for it to initialize and begin sending data
  • Install batteries in inside receiver and observe temperature reading
Sep 22, 2017 | Measuring Tools & Sensors
OUTSIDE TEMP SENDING UNIT GOT WET AND WILL NOT CONNECT TO CLOCK. HOW CAN I FIX OR HOW CAN I REPLACE?
[PDF]WS-8117 ATOMIC CLOCK WITH OUTDOOR WIRELESS ...
https://www.lacrossetechnology.com/products/.../misc/8117-manual.pdf
NOTE: Do not set the clock until the outdoor temperature is displayed. .... The unit will still try and receive the signal every day despite it being manually set. ..... sunlight, extreme cold and wet/moist conditions as these will lead to rapid changes ... Beforesending the atomic clock in for repairs, contact La Crosse Technology.
La Crosse Technology Top Solutions
https://www.lacrossetechnology.com/support/top_solutions.php
A: Complete a restart for display with the temperature/humidity sensor: ... to rest for 15 minutes can result in failure to connect with the outdoor sensor or missing ... Products set outside of these time zones will not search for a WWVB signal as it is ... locate the Clock or Weather Display near an outside wall and point the unit in ...
Common issues weather stations: Click Here
www.weather-station-products.co.uk/faqs/common-issues-weather-stations
Under £30 £30-£75 £75-£125 From £125 Birdhouses/Feeders Outdoor Clocks ... I'mnot getting any outdoor readings from my outdoor sensor, what do I do? This willcure 90% of all sensor connection problems, important you must ... is the airtemperature, to get this reading you need to place the unit away from direct sun.
Replacement Temperature Sensor ' AcuRite
www.acurite.com > All products
Dec 16, 2015 | Audio Players & Recorders
Outdoor temperature on indoor station showing - -.
Check the battery in the outdoor unit, resync them per the instructions, if that does not work check for interference.
Jun 23, 2015 | Equity Time USA 31215 Wireless Outdoor...
Display station not showing outside temperature
Check battery status indicator on main weather station of remote unit. If no indication, replace battery in remote unit. If battery is good then check "channel setting" of remote unit to make sure the channel setting on remote unit matches the "channel" setting on main unit. many weather stations will take up to 3 or 4 remote units and they must use different channels to relay the remote imfo to the main weather station unit.
Jun 19, 2015 | Measuring Tools & Sensors
Auriol 4-LD3091 weather station will not pick up sensor
I had the same problem and gave up on the unit for a while, then I had another attempt and found this worked for me. Take the batteries out of both units (receiver and outside sender) then reinsert the batteries BUT put the batteries into the outside sender unit FIRST, this seems to make the difference as when you then put the batteries into the indoor base-station it detects the outside temperature signal immediately as it starts to set itself up .
Aug 18, 2012 | Measuring Tools & Sensors
The sensor from my weather station is not registering outside temperature
I've had the same problem since I bought this unit 2+ years ago; when the outside temperature moves into the freezing zone, the sensor stops transmitting. I contacted Lacrosse-- all they could suggest was change the batteries. My solution: throw it in the trash!
Aug 05, 2012 | Bushnell Measuring Tools & Sensors
Cannot get the weather station model ws-916ou-it to show outside temperature
I have three of these WS-916OU-IT units. After a few years, the outside sensor just fails. You will get dashes and a "TR" low battery signal, even if the batteries are good
just buy another whole weather station (short money) and set both the old and new weather station unit to receive from the single new outdoor sensor.
To do this - just follow the procedure for a single sensor - that is - put the batteries in the new sensor - then within 30 seconds - put the batteries in all the weather stations - they will all pick up the same outdoor sensor.
I now have three units running off of one outdoor sensor.
Seems a bit silly, but it works.
Feb 27, 2012 | Measuring Tools & Sensors
Measuring Tools & Sensors Logo
138 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
