Question about Air Tools & Compressors
When i pull the trigger spray it spurts the paint out in blobs not a good spray mist
    Top Expert:
  • 47,657 Answers
Check the seals around the trigger shaft
have to be in good condition and tight
Posted on Apr 18, 2017
When spraying the spurts the paint in blobs when i pull the trigger
Airless or hvlp check your pressure and that the spray tip is clean if the pressure is too low the paint will gather on the tip
Apr 18, 2017 | Air Tools & Compressors
How do you take this hvlp gun apart for proper cleaning of the spray gun?
I've found over the years the least amount of times you can tear a spray gun completely apart the better. Usually a real good 'flushing' with lacquer thinner will suffice. I will take the air cap off and let it soak in thinner to dislodge any build up but other than that, I simply run thinner thru till it runs clear out the tip.
I also 'back flush' which involves having thinner in the cup and the air supply hose attached. the air pressure should be adjusted quite a bit lower than what you use for spraying paint.
Then you place a clean shop towel or rag over the air cap of the gun and pull the trigger. This forces air back into the paint cup 'back flushing' the gun. Then take the rag away from the cap and pull the trigger again to run thinner thru the gun the normal way.
IF you still want to tear the gun apart for cleaning you can hopefully get some idea with this video link;
Quick Easy Way to Clean HVLP Spray Gun
Hope this helps.
May 25, 2015 | HVLP Air Tools & Compressors
Please provide correct paint viscosity to be used for Airless Paint Sprayer (item 60600). Include the method (standard) used to measure the paint viscosity. Thank you.
I had an airless sprayer years ago. I couldn't work out how to thin the paint either. The end result was if its too thick and wouldn't spray, I added more thinners. If it sprayed blobs and ran everywhere, I added a bit more paint. Not very professional but I got it down pat after a few errors. I wrote on the paint can I was using, the mix that worked the best.
Sep 25, 2014 | Air Tools & Compressors
Shoots drips
Most airless spray guns spit a bit when you pull or release the trigger because the paint between the spray tip and the paint valve is under pressure but not enough to atomise the paint. If you increase the pressure you may reduce the spit to a point when you don't notice it. A blocked filter could slow the paint getting through to the tip cause lower pressure.
Jan 03, 2014 | Wagner SprayTech Wagner Airless Paint...
My paint dries to fast, what should I do?
Acrylic paint depends on time, temperature, humidity, paint thickness, air-flow and absorbency to dry.
Reeves Complete Acrylic Painting Set
Oil colour
paint takes long time to dry than other media and it allows to think and it also provides the flexibility for changes.
Williamsburg Handmade Oil Color Paint Alizarin Crimson 37ml Tube
Feb 03, 2013 | Crafts & Hobbies
We are having trouble getting the spray gun to pull the paint through. It will spray air but does not spray paint.
when you pull the trigger can u see the needle moving backward? if so, then it's either the paint is too thick compare to the nozzle size or the passage for paint is blocked. try to take the nozzle, needle and the cup off and give it a good clean!
Sep 05, 2011 | Campbell Hausfeld Husky Gravity Feed HVLP...
How to used the gravity type
Depends on what you want to do with a spray gun realy.
Gravity is good for easy flowing paints which can be used on things which dont require the gun angle to change much.
SOLVENT BASED PAINTS:
Thin your paint to a bit thicker than milk, fully open the fluid needle travel and without air pull the trigger and see if the paint kind of falls gracefully out of the front, if it just dribbles and rund all over the gun, its either TOO THICK or the fluid tip IS TOO SMALL.
If that works OK try introducing some air gradually and spraying test patterns, even atomisation, (regular paint particles) and a pattern of about 1.5 inches by 6 - 9 inches with every thing set to full on should look like a cigar, if its all one ended your air cap hasa blocked hole, no paint in the middle too much air.
Good luck
Jan 28, 2011 | Air Tools & Compressors
Tdwbit269@aol.commy gun will not shut off even when i pull the trigger, liquid keeps flowing out. good thing is that i am getting something through the hose so that means my machine is working right?
You need a re-build kit for your gun.
The needle that pulls back when you squeeze the trigger is no longer making a seal when you release the trigger.
The problem is worse when you spray thin oil-based paints.
Depending on the gun, Sherwin Williams has kits for the Graco gun. That's where we bought ours for years up until I retired from painting.
Home Depot and Lowes may have parts.
Oct 28, 2010 | GRACO INC 243012 Airless Spray Gun Sg3
My Kirby G3 paint attachment isn't spraying the paint. I have everything hooked up according to the manual, and it sprays a continuous stream of air, but isn't sucking up the paint to spray. Sometimes I...
mcdevito75 here, Sounds like it"s cogged with paint, the paint is not being sucked up into the Spray gun itself, the air flows thru thr spray gun thru the trigger assembly. Follow the makers cleaning of the spray section of the spray gun. Try running paint thinner thru the spray system. Hpope this helps.
Jul 19, 2010 | Kirby Generation 3 Bagged Upright Vacuum
Porter cable spray painter PSH1 it says what you can spray with it and I want to spray water base paint can I do it with this painter it is new and I didn't relize it was onl for laciur paint thank you...
Be sure to filter the paint you are trying to use so that you aren't dealing with large lumps of paint. You will need to experiment with hose pressure to get proper spray quality, and set the mixture control for a fairly fine mist as the paint is likely to be more fluid. Fan control is set so that you don't get an unpainted space in the middle of the paint swath. Make sure to wash the gun thoroughly after painting. If you are doing a lot of painting, expect some nozzle wear over time as the water base paint is somewhat gritty. Don't forget to trigger 'off' before the end of each stroke and trigger 'on' after starting the return stroke to keep running at a minimum. Good luck!
Jun 19, 2010 | Porter Cable Cable PSH1 HVLP Gravity Feed...
Air Tools & Compressors Logo
37 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
