Question about Dryers
Homemaker dryer 4088 timer problem - Dryers
Where would I find a manual for a Homemaker Dryer HMCD50Y.
Search the internet for:
Make + Model + the word "Manual"
or contact Manufacturer Support.
Oct 29, 2016 | Sewing Machines
Homemaker 5kg dryer cant locate heating reset button
Most dryers have sensors that fail, and can not be reset. These need to be replaced. They are used to prevent fires and fail primarily from build-up of lint and heat. Make and model numbers are essential in solving any appliance repair issue.
Feb 04, 2016 | Dryers
How do I use the timer on Homemaker microwave EM930ASC
Go to the manufactures web site & look up the answer
or Google your question
I’m happy to help further over the phone at https://www.6ya.com/expert/wynn_5ba0205233ebfc15
Dec 14, 2014 | Office Equipment & Supplies
Location of circuit breaker for Homemaker 80 litre upright freezer
ernie.awa.com.au/.../Homemaker%20HMTF-10Q%2080L%20Upright%..
Aug 26, 2014 | Dryers
I need a belt and filter for homemaker hmd35 clothesdryer bbut cant find them anywhere
Doug Smith Spares can supply virtually all parts for these dryers. We keep the belts in stock. Call us on 02 8868 6700. Thanks
Jun 30, 2011 | Dryers
Do homemaker dryers (kmart brand) have the same filters as any other brand of dryer, or is there somewhere to buy replacements thanks
never heard of it before but i do know that sears owns kmart, so if i had the model number perhaps i can try
Jun 24, 2009 | Whirlpool LER7646E Dryer
Homemaker Dryer
You should have a warranty for this. Check with the store that sold it and see if they service what they sell.
Jun 22, 2009 | Whirlpool LER7646E Dryer
Homemaker HMCD50Y dryer
Because the dryer is running, but not heating, it sounds like the element. The rattling could be a part of the element that was weak and then broken during the move.
Inspect the element by taking off the back cover [unplug first] and remove the section of the flue-like piece that goes from bottom toward top at angle. The element is the spiral wire that runs inside that larger aluminum section.
Be sure to remeber where the 6 or 8 wires were connected. Grab a digital camera before removing the wires.
If you need an element, it comes with that aluminum section in a large box--not just the curly wires.
I've seen bad elements with breaks that could only be found by continuity testing and some that are obviously burnt in 2 or more places. I've also seen them ground out by a metal bone from a woman's bra. The move and the rattling--I'd check the element.
You have to remove the vent hose before removing the back cover. Be careful not to damage it. The cover can be a pain to reseat and fit around the vent housing at the same time--depending on work space. With part and tools in hand, 1 1/2 hours for a casual DIYer.
Aug 31, 2008 | Whirlpool LER7646E Dryer
Dryers Logo
Top Dryers Experts
