Question about Exercise & Fitness
How to remove error 2 on a cybex trotter treadmill
    Novelist:
  • 145 Answers
Hi There,
This error leads to excessive current according to this .pdf.....
http://gymstore.info/manuals/upload/Cybex/cybex_error_codes.pdf
This mentions checking the motor, and certainly could be generated from the lower control board. I recall these controllers as quite large with maybe 4 to 8 large storage capacitors on them, which do fail over the years, and could cause this. Does the tread run at all? Error right away or move the belt then error? You can contact jatinah@rocketmail.com for more help if needed. Good Luck.
Posted on Apr 18, 2017
  • dave anderrson
    dave anderrson Mar 01, 2018
    can run 45 mins, then shuts down code 2
Cybex 520t error 6
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Error 6 is a motor over voltage error. Motor voltage exceeded 200 VDC for 200 milliseconds. This can be caused by a worn deck and belt due to a lack of routine maintenance. AKA adding wax between your deck an belt. You might be able to wax your machine and make the error go away. More than likely a new deck and belt will be needed. Using the link below and your model and serial number, you can find the needed items. In worse case scenario, you may also need a new motor control board.
Repair Parts for Trotter Cybex Treadmill 400T 410T 500 Series SPORTSMITH...
Apr 07, 2014 | RTO Cybex 520T Remanufactured Treadmill
Cybex 530t error 6
Jan 20, 2014 | Exercise & Fitness
Key pad enter + numbers not working trotter 685
adjust the reed switch, test for open or faulty, clean it, and tight the connector fery weel , see the diagram attached
2) replace the batteries old by new ones, and clean the contacts batteries.
3) tight the ribbon cables for keypads, clean it too.
God bless you
Feb 22, 2013 | Treadmill Doctor Cybex Trotter685 900t By...
Error 3
Test the speed sensor by continuity with DVOM and replace, and RUN the software calibration.
see the block diagram.
God bless you
Nov 26, 2012 | Treadmill Doctor Trotter Cybex 450t Deck...
I bought a used Cybex Trotter 700 T treadmill that works fine except the increase speed (+) does not work. I tried to fix it and now all of the buttons don't work. Any sugestions?
Dear Sir:
This is probably a 1(faulty speed sensor or the 2( speed sensor is not plugged in properly. Its also possibly a 3(faulty motor control board or lower board+ 4( Main motor faulty. Adjust the speed sensor see the diagram.
Run the software calibration for easy diagnose and troubleshooting.
See my personal TIPS for HELP
sincerley. God bless you.
ernesto cuadra
managua, nicaragua.
Mar 10, 2012 | Exercise & Fitness
I have a Trotter 535 treadmill. I need to turn
visit wefixfitnessequipment.com and I will tell you how to flip the deck, tighten the belt and where to get lube. If you are planning on flipping the deck make sure you lube it with the right kind of lube!
B. Clark
Trotter/Cybex certified technician
15 years exp.
Dec 12, 2009 | Endurance T3 Treadmill
Exercise & Fitness Logo
47 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
