I press and hold # START... but i can't see "service".... always display showed call service C6000.. how to maintend it???
4 Suggested Answers
  • 40 Answers
SOURCE: Error C6000 is showing, can you tell me if I can fix myself or call for service.
In some cases you can reset the C 6000 - when is a false error.
try this:
1. Go to Menu/System and browse till you see
"Service".
press and hold: # START ENTER
The "Service" will go away and browse to "Maintenance".
2. Press ENTER to go in maintenace mode - the display change to Maintenance mode.
3. browse to 0163 and press ENTER - reset fuser
4. pick EXECUTE and press ENTER
5. turn the copier OFF, wait 20 seconds and power up the machine.
If C 6000 goes away it was a false error if NO ...try again and if the C6000 persist means the thermal fuse it is blown so you have to replace the fuse = call for service.
Posted on Jan 12, 2009
rylee_smith
  • 8619 Answers
SOURCE: c6000 error code
Hi
Error C6000 is displayed when your machine fails to reach the correct temparature at a specific time.
This is a Fuser Unit Problem, try to reset it by--
First open top cover then turn on power.
press system menu/counter
arrow down to service
press and hold start, # then enter keys
arrow down to maintenance
press enter
arrow down to Sim 163
press enter
select execute
press enter
turn off power then back on
If the reset doesn't work then get your unit checked for fuser unit and fuser unit heat issues.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Posted on May 09, 2009
SOURCE: call for service C6000 has appeared due to power cut
http://www.printcopy.info/?l=en&mod=docs&brand=Kyocera-Mita&prefix=KM&gID=12830
This top one has all codes it is your service manual
http://www.retrevo.com/support/Kyocera-KM-2050-Multifunction-Printers-manual/id/529dj799/t/2/
Support above. www.kyoceramita.eu/.../usermanual/km...2050.../KM-1650-2050-25...0-OG-UK-BAS.pdf -
Also below grab the latest driver too.
http://www.kyoceramita.eu/index/service/dlc.false.driver.KM2050._.EN.html
Posted on Jun 18, 2010
ERROR COD C6000
Works with ERROR C6000, C6300, C6400
Switch off
Open Toner Cover
Switch on, holding "System Menu"
Go to "Secure Setting"
"Enter"
Hold "Start" "#" "Enter"
Scoll down to "Maintenance Mode"
"Enter"
Scoll down to "U163"
Scoll do "Execute"
"Enter"
Close Toner Cover
Leave run for a few seconds
Switch off
Switch on....
May 04, 2014 | Kyocera FS-1118 Printer
ERROR CODE C6000 ON OLIVETTI D-COPIER 200MF
C6000 is usually cause by fluctuation of current(power supply).
STEP 1:
Open top cover then turn ON the machine,press System Menu then scroll down to Service Setting,then HOLD BOTH the "Start key" and "#" and press "OK".
Scroll down to Maintenance Mode then press "OK".
press 163 on the keypad
scroll down to "Execute"
press "OK"
Turn Off/On...
If C6000 appears again..,
STEP 2:
U have to reset the fuser thermostat manually.
FUSER REMOVAL:Remove rear cover,top cover,left and right cover.
Remove two screws. Unplug two connectors. Pull out Fuser unit.
Thermostat removal:
remove two screws,separate the upper part from the lower part,,
remove separation claws (3pcs each 1 held w/ screws at the rear)
remove the heater lamp,and upper fuser roller...
remove two screws that held the thermostat (circular shape)
(reset manually)
If you touch the top of the thermostat you will notice that it is in concave form...,you have to drop it hard on the flat surface in order to bring back it\'s original form which is CONVEX.
DO THE REVERSE ORDER TO ASSEMBLE.
THEN,Repeat procedure in STEP 1.
Mar 03, 2014 | Kyocera Copystar CS-1620 Black and White...
My kyocera taskalfa 180 asking me to call service C6000. How can fix this error?
My kyocera taskalfa 180 shows an error.call service c6000.what should i do
Jun 30, 2012 | Kyocera TASKalfa 180 Copier
My KM-2035 appeared error call service C6000 on my copier.
on the nunber keys, key in 10871087 the display should blink then enter 163 then;
1. Press the start key. The screen for executing is displayed.
2. Select the EXECUTE using the up/down cursor keys. The selected item is displayed in reverse.
3. Press the start key. The fixing problem data is initialized.
Jan 16, 2011 | Kyocera Mita Office Equipment & Supplies
I replaced heaters and still get a c6000 error!!!
check the thermostat continuity. If no continuity replace the thermostat and reset by holding down Stop, start, light exposure key, then release at once and press stop. machine shows u000, enter 163 using + and - keys. press start twice
Jan 07, 2011 | Kyocera KM-1510 Copier
On the display it says call service c6000 and how to correct this error massage?
Hi
Error C6000 means Broken fixing heater wire. In fixing warm-up, the time to reach
50°C/122 °F exceeds 13.5 s, the time to reach 100°C/212 °F exceeds 10 s, the time to reach the primary stabilization exceeds 10 s or the time to reach the secondary stabilization exceeds 24 s. To resolve this try this reset procedure--
Turn off the copier by opening the top toner cover. Turn copier on, when you see message "close top cover" press "system menu" button. Scroll up to "service setting" then press the # button, green "start" button and the "enter" button all at the same time. Now scroll down to "maint mode", press "enter" then enter 163 press" enter " turn off copier then turn back on.
If this doesn't resolve your issue then you'll need to check whether heater M or S is installed correctly. If it is installed correctly then make sure that the heater M or S wire is not broken. Hope this helps...
Daniel
Oct 09, 2010 | Kyocera Office Equipment & Supplies
C6000 error code
Hi
press enter
press enter
select execute
press enter
Thanks
Rylee
May 09, 2009 | Kyocera Copystar CS-1820 Black and White...
try this:
"Service".
Sep 25, 2008 | Kyocera FS-1118MFP Laser Printer
Copystar cs1815 c6000 code
This is a fuser problem -- here is a reset method:
press enter
press enter
select execute
press enter
Aug 18, 2008 | Copystar CS-1815 Printer
Error C6000
This is a fuser problem. Try this to reset:
press enter
press enter
select execute
press enter
Jul 28, 2008 | Copystar CS-1815 Printer
21 people viewed this question
k24674
