Question about Exercise & Fitness
How to remove error 2 on a cybex trotter 700t treadmill
3 Suggested Answers
Benimur
  • 6966 Answers
SOURCE: 700t trotter cybex treadmill
Hi again,
Appreciate the direct "Ask Me".
To your concern:
  • Error 1 - No speed signal at startup. This indicates that the controller board did not sense that the motor is turning. Procedures call for checking of the belt, the SCR (triac) controller (with an analog continuity tester), the presence of 130VDC spike/startup supply (with a voltmeter) and the brushes. Since you have replaced the brushes, the others then.
Of course the above requires familiarity with electronic components and circuitry, the use of an analog multimeter and possibly soldering. Should you be uncomfortable, then perhaps as you posted, "send the complete printed circuit to be check".
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Aug 20, 2008
ercupa190
  • 12223 Answers
SOURCE: I bought a used Cybex Trotter 700 T treadmill that works fine except the increase speed (+) does not work. I tried to fix it and now all of the buttons don't work. Any sugestions?
Dear Sir:
This is probably a 1(faulty speed sensor or the 2( speed sensor is not plugged in properly. Its also possibly a 3(faulty motor control board or lower board+ 4( Main motor faulty. Adjust the speed sensor see the diagram.
Run the software calibration for easy diagnose and troubleshooting.
See my personal TIPS for HELP
sincerley. God bless you.
ernesto cuadra
managua, nicaragua.
Posted on Mar 12, 2012
How to remove error 2 on a cybex trotter treadmill
Hi There,
This error leads to excessive current according to this .pdf.....
http://gymstore.info/manuals/upload/Cybex/cybex_error_codes.pdf
This mentions checking the motor, and certainly could be generated from the lower control board. I recall these controllers as quite large with maybe 4 to 8 large storage capacitors on them, which do fail over the years, and could cause this. Does the tread run at all? Error right away or move the belt then error? You can contact jatinah@rocketmail.com for more help if needed. Good Luck.
Apr 18, 2017 | Exercise & Fitness
Cybex 520t error 6
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Error 6 is a motor over voltage error. Motor voltage exceeded 200 VDC for 200 milliseconds. This can be caused by a worn deck and belt due to a lack of routine maintenance. AKA adding wax between your deck an belt. You might be able to wax your machine and make the error go away. More than likely a new deck and belt will be needed. Using the link below and your model and serial number, you can find the needed items. In worse case scenario, you may also need a new motor control board.
Repair Parts for Trotter Cybex Treadmill 400T 410T 500 Series SPORTSMITH...
Apr 07, 2014 | RTO Cybex 520T Remanufactured Treadmill
Key pad enter + numbers not working trotter 685
adjust the reed switch, test for open or faulty, clean it, and tight the connector fery weel , see the diagram attached
2) replace the batteries old by new ones, and clean the contacts batteries.
3) tight the ribbon cables for keypads, clean it too.
God bless you
Feb 22, 2013 | Treadmill Doctor Cybex Trotter685 900t By...
Error 3
Test the speed sensor by continuity with DVOM and replace, and RUN the software calibration.
see the block diagram.
God bless you
Nov 26, 2012 | Treadmill Doctor Trotter Cybex 450t Deck...
Dear Sir:
ernesto cuadra
managua, nicaragua.
Mar 10, 2012 | Exercise & Fitness
I have a Trotter 535 treadmill. I need to turn
visit wefixfitnessequipment.com and I will tell you how to flip the deck, tighten the belt and where to get lube. If you are planning on flipping the deck make sure you lube it with the right kind of lube!
B. Clark
Trotter/Cybex certified technician
15 years exp.
Dec 12, 2009 | Endurance T3 Treadmill
Exercise & Fitness Logo
Top Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
