Question about Power Computers & Internet
Power fault When plugged in to 220volt supply initially the saw would start up ,but now there is no power but the lazer light comes on.
  • Power Master
  • 10,291 Answers
Check for a tripped circuit breaker in your power panel. When a 220 breaker partially trips internally , one side of the 220 line is lost leaving 120 left. That's why the laser light still works. Replace the breaker.
Posted on Aug 06, 2017
  • 10865 Answers
SOURCE: I have recently purchased a used DW125 radial arm
Hello. Since the saw doesn't sound like it had a ground attached, I would begin by checking the motor to be sure that it is ok. here is an excellent link that explains exactly how to do just that:
http://www.ehow.com/how_4464121_test-troubleshoot-electric-motors.html
Joe
Posted on Mar 18, 2010
sean32601
  • 508 Answers
SOURCE: i do see that the
Yes you need a new laser. The red beam should come on and go off only if its a blu ray disc or ps3 game then the laser will go to a blue beam and from there it should read the ps3 game or blu ray. If a dvd movie is in it the laser should light up red beam and read the dvd.
Posted on Nov 21, 2010
  • 2567 Answers
SOURCE: Have a Acer Aspire 3680-2682.
Please refer to the following article for some tips to fix this problem:
http://www.fixya.com/support/r6395191-troubleshooting_laptop_power_failures_ac
Posted on Feb 01, 2011
vonstar8
SOURCE: My Singer Quantum 9960 machine was accidentally
this happen to me exactly - i checked and the fuse is blown, which is a good thing because it will hopefully have saved the rest of the machine from being toasted. I will find out soon once i get a new fuse.
Posted on Apr 19, 2012
  • 15427 Answers
SOURCE: I plugged my Toahiba LCD TV into a 220volt electric outlet. I replaced the blown fuse but I still don't get a picture. What's next step? New power supply? Buy a new TV?
unless you can check all the circuit boards /cards then i would say its more than likely fried and would cost more to fix than replace
Posted on Jun 29, 2016
I don't have a harness how do i power to it just to see if it comes on. just take a ground wire and a positive wire and put it to whatever prongs it would be on the back that the harness plugs into
Dryers are generally 220v. There are 2 110v supplies. You would have to connect to a 220volt outlet.get the correct cors. Way safer
Oct 27, 2016 | Dryers
I have a sansui 14" tv.14 yrs old.there is showing 220volt supply at antenna & audio video receiver point.what's the fault.how I will rectify it.thanks
The antenna & Audio Video receiver point should not have mains power getting to it. Especially the antenna which is the aerial. If the aerial has 220 volts on it you would get a lethal electric shock every time you plugged in the aerial lead!
There is clearly something wrong with the units power supply if 220 volts is getting to that part of the unit.
Aug 31, 2016 | Sansui Audio Players & Recorders
Hi, in Antec 300watt power supply there is 3 cables or input or current 220volt. The cables are Black, Green and white. Which one is earth, which on is live(positive) and which one is negative?
For 120 volt operation use
black for the hot, White for the natural, Green for earth ground.
For 240 volt operation use;
Black and White for the 240 volt and Green for earth ground.
Black is generally designated as the "Hot" or "positive" .
You must make sure the switch on the power supply is set for the voltage you are using. ie: 120/240
Dec 15, 2014 | Antec Computers & Internet
Polaroid tv
Most likely you have a fault with the power supply board or main board. I would start with the power supply board. Does the power light come on when you plug in the set?
May 04, 2013 | Polaroid FLM-2625 26 in. HD-Ready LCD...
My Singer Quantum 9960 machine was accidentally plugged into a 220volt supply as I am currently in a country that uses 220volt. The LCD screen lights up for less than one sec and then went off. I...
Apr 22, 2011 | Singer Sewing Machines
I do see that the lazer does light momentarily but does not apear to be deep blue. there is initially a red lazer that lights and goes out after which the blue lazer lights and goes out. Is this the sign...
Nov 20, 2010 | Sony Playstation 3 (PS3) Console
I have recently purchased a used DW125 radial arm saw which initially worked OK,but after changing the saw blade it has now died,i have changed the 240v plug & fuse (noticed the earth pole was'nt...
Joe
Mar 18, 2010 | Saws
Cant switch it on!
Sounds very much like a main power supply that needs a 'kick' to start up. This is often caused by the loss of value of a capacitor in the power supply, one that handles feedback to start the supply initially and carries the signal to shut it down in case of a circuit fault in one of the areas the supply services. Inadequate feedback will make the supply unable to start properly and more likely to shut down even though no fault condition exists. If I'm right, it will get worse and searching for the problem requires an instrument not found in the average home; a capacitance meter with loss measuring capabilities.
Sep 11, 2008 | Hyundai ImageQuest DPD4210 42 in. HD-Ready...
Computers & Internet Logo
Top Power Computers & Internet Experts
john smith
vince
Sattech
Level 1 Expert
Are you a Power Computer and Internet Expert? Answer questions, earn points and help others
