Question about Kyocera Office Equipment & Supplies
My kyocera TASKalfa180 ask me to call service C6000... diplay show 000 and C-6.. how can fix this error
    Master:
  • 604 Answers
Call service
Posted on Apr 18, 2017
5 Suggested Answers
  • 40 Answers
SOURCE: Error C6000 is showing, can you tell me if I can fix myself or call for service.
In some cases you can reset the C 6000 - when is a false error.
try this:
1. Go to Menu/System and browse till you see
"Service".
press and hold: # START ENTER
The "Service" will go away and browse to "Maintenance".
2. Press ENTER to go in maintenace mode - the display change to Maintenance mode.
3. browse to 0163 and press ENTER - reset fuser
4. pick EXECUTE and press ENTER
5. turn the copier OFF, wait 20 seconds and power up the machine.
If C 6000 goes away it was a false error if NO ...try again and if the C6000 persist means the thermal fuse it is blown so you have to replace the fuse = call for service.
Posted on Jan 12, 2009
SOURCE: Kyocera Mita 1500 Error code 6000
This C6000 error code is triggered by a few things all having to do with the fixing heater wire. Ask your technician to check the thermistor, the thermal cutout and the connection between the thermistor and the power supply board. My guess would be that the power surge overloaded the power supply board. This is not something that can be reset and may require new parts.
The manuals that describe the error codes are only available to Kyocera technicians, sorry.
Henry
Posted on May 26, 2009
  • 525 Answers
SOURCE: kyocera km-1820 error occured call service person
Contents: Broken fusing heater wire
• In fusing warm-up, the time to reach
50 °C/122 °F exceeds 13.5 s, the
time to reach 100 °C/212 °F exceeds
10 s, the time to reach the primary
stabilization exceeds 10 s or the time
to reach the secondary stabilization
exceeds 24 s.
Causes: Poor contact in
the thermistor
connector terminals.
Thermistor installed
incorrectly.
Thermal cutout
triggered.
Heater lamp installed
incorrectly.
Broken heater
lamp wire.
Check procedures/corrective measures: Check the connection of connector YC4 on
the power supply PWB and the continuity
across the connector terminals. Repair or
replace if necessary.
Check and reinstall if necessary.
Check for continuity. If none, replace the
thermal cutout.
heater lamp
Posted on Mar 06, 2011
SOURCE: j'ai un probleme avec mon
KYOCERA KM 1505 . CODE PANNE C 610 DE
Posted on Mar 13, 2011
My kyocera TASKalfa180 ask me to call service C6000 how to make it
try 1087 1087 enter 163 then enter or reset if that don't work you need new fuser
Apr 18, 2017 | Kyocera Office Equipment & Supplies
My kyocera taskalfa 180 asking me to call service C6000. How can fix this error?
It is fuser error try resetting it by running mode 163, otherwise replace the fuser unit.
Feb 26, 2016 | Copystar Kyocera Taskalfa 181 Copier
How do I reset xerox C6000?
C6000 km-1820.3gp - YouTube
? 0:55
www.youtube.com/watch?v=Ef0WwaTXgtQ
Oct 6, 2010 - Uploaded by natasmanda01 Cancelamento dos codigos de erros c6000, c6400 e c6020 da kyocera ... HOW TO RESET AND HARD RESET KYOCERA HYDRO XTRM ...
Printer Resetter: Solving error C6000 on Kyocera Mita printers
pritner.blogspot.com/2013/08/solving-error-c6000-on-kyocera-mita.html
Aug 8, 2013 - c6000. error. Error Message Check Ink U041 · Xerox WorkCentre C2424 DADF Error ... SSC Service Utility Software to reset Epson printers.
Oct 19, 2015 | Xerox Phaser Office Equipment & Supplies
1087 1087 then 163 reset it may prompt to turn off and on again,
if that does not reset copier replace the fuser assy
Mar 03, 2015 | Kyocera Office Equipment & Supplies
Have error: C6000 on call for service c6000
The error code(C6000) Maybe the broken fixing heater wire. In fixing warm-up, the time to reach 50 degree(C)/122 F exceeds 10s, the time to reach the primary stabilization exceeds 10s or the time to reach secondary stabilization exceeds 24s. Or the Fixing heater M or s installed incorrectly. Check and re-install if necessary or replace the fixing heater M or S
Aug 23, 2014 | Kyocera Mita KM-2050 Printer
KYOCERA FS 1118 MFP SHOW ERROR CODE C6000 WHAT B I CAN DO
replace the fuser will fix that. Or if you want to stip it down check the lamps and if their ok change the thermistor and thermostat. But your better off just replacing the whole unit
May 04, 2014 | Kyocera FS-1118 Printer
My kyocera taskalfa 180 shows an error.call service c6000.what should i do
Jun 30, 2012 | Kyocera TASKalfa 180 Copier
Henry
May 26, 2009 | Kyocera KM-1505 Copier
C6000 Error message on Kyocera Mita KM-C3232 Printer
the c6000 error may be resettable.
the password will be 3200 or 6482.
once inside you need to be in copy mode and do the following
punch into the keybord 1087 1087
once you see 000 on the screen punch in 163 and hit the green button
you will then see the reset sequence, follow this and it should work.
please report if this works
Mar 20, 2009 | Kyocera Mita Office Equipment & Supplies
try this:
"Service".
Sep 25, 2008 | Kyocera FS-1118MFP Laser Printer
27 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
