Question about JBL Audio Players & Recorders
I have a JBL SB150 sound bar and subwoofer after setup I noticed that there is all most no bass on the subwoofer, the woofer is paired with sound bar
4 Suggested Answers
hack124x768
  • 33 Answers
SOURCE: jbl bass pro volume
Bandpass box calculator. Have fun.
http://www.colomar.com/Shavano/4thorder_info.html
Posted on Mar 17, 2009
fkuk
  • 311 Answers
SOURCE: Can I replace the sub woofer in my home stereo
if the impedance of the new speaker matches the impedance of the old one then i dont see why it wont work
Posted on Jan 01, 2010
will-raven
  • 83 Answers
SOURCE: no sound from subwoofer
Are you using the Creative speaker test program? It usually has a picture of a generic layout of a pc system, with the speakers around it, showing a speaker for each that you should have plugged in. There should be a test button that will play a sound through each speaker. If a sound plays from your center speaker when the subwoofer picture is lit up then you may have a cord plugged in incorrectly on either the subwoofer or on the back of the soundcard. I've ran into this many times.
The best way to set up surround sound is to get your speakers placed or mounted on the wall, then run one wire at a time into the subwoofer, to ensure that the front left is hooked into the subwoofer in the front left, front right into front right, etc. Then once the speakers are hooked into the subwoofer start running the outputs from the subwooofer one at a time into the sound card. After each connection run the test program and watch the pictures light up as the sound plays, and make sure that the speaker playing sound in your place is the same speaker that is lit up on the test program.
I hope that helps, otherwise the amp is probably bad. Let me know if you need more help.
Posted on Apr 30, 2010
What is a sound bar woofer and function
A woofer is a device that producers low frequency bass sounds. Often in a form of Sub Woofer. Bass sounds are not directional. So once set up it will give the rumble and vibration needed to the sound system.
Dec 27, 2016 | Audio Players & Recorders
My JBL cinema SB350 sound bar keeps cutting out during movies. Also, I can't sync the sub woofer with the sound bar even after pressing the pairing button within 30 seconds of each other. Help?
Just visit the site linked here; only and if you're technically qualified. If not, contact any service technician to repair this set.
https://electronicshelponline.blogspot.com/
If you're aware, you'll get something. If not nothing. OK?
Dec 16, 2016 | JBL Audio Players & Recorders
I have a 2004 Avalon, all of the speakers (except the subwoofer) work, I noticed there is no bass and then found out the subwoofer makes no sound, does anyone know what might be the problem?
Toyota Avalon JBL Speaker Subwoofer Foam Repair 86160 ...
? 18:34
https://www.youtube.com/watch?v=vDHEbiyBt9I
Jul 16, 2012 - Uploaded by Simply Speakers
Toyota Avalon JBL Speaker Subwoofer Foam Repair 86160-AC180 .... Luckily you don't have to remove the rear deck to get at the subwoofer, ...
Removing rear subwoofer / rear deck - Toyota Nation Forum : Toy
Nov 19, 2015 | 2004 Toyota Avalon XLS
Can't sync my JBL SB400 subwoofer to the soundbar??....it flashes blue and goes back to orange. Sound bar works but can't pair sub!..HELP!!
PAIRING THE JBL SB400 FOR WIRELESS OPERATION
After turning the soundbar and subwoofer on for the first time, you will need to "pair" the subwoofer and soundbar so they both operate at the same wireless frequency. To pair the units, press the Wireless Pairing switches on both units within 30 seconds of each other. The units will communicate with each other and operate at the same frequency.
May 21, 2015 | JBL Audio Players & Recorders
Find a JBL n24aw replacement speaker
Looks like the woofer is a 4" Polyplas shielded driver, part #NS-W4SS, 4 ohms. If JBL can't supply a replacement try looking at Madisound or Partsexpress. Find a 4" 4 ohm woofer or mid-bass driver with a round frame. Check the actual measurements against your driver because not all "4 inch" drivers are the same size or bolt pattern. Make sure the depth will fit. You don't need "shielded" unless the speakers will be right up against a CRT (and nobody uses CRTs these days). Get a pair and replace both because the new driver certainly won't match the old.
Take a look at the Dayton Audio RS100-4 from Parts Express (or Amazon). The Hi-Vi M4N from Madisound "may" work but it is 8 ohms. http://www.jbl.com/resources/Brands/jbl/Products/ProductRelatedDocuments/en-US/TechnicalSheet/NSP1%20SAT%20ts.pdf
Sep 05, 2014 | JBL Audio Players & Recorders
Sound drivers samsung laptop
Sounds like a problem in the setup.
Oct 18, 2013 | Audio Players & Recorders
The bass of my jbl speaker just broke, can i still fix it?
Need model number.... could be a bad woofer, amp, wiring or power supply. Need more info.
Jul 31, 2013 | JBL Audio Players & Recorders
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
