Question about LG VX8350 Cellular Phone
Replace VX8350 front lcd screen
I need to replace my front lcd as well. Have you found any directions on how to do this?
How to replace LCD screen
To replace the the LCD screen of your laptop, You need to be very careful in replacing this screen. Please kindly follow the steps below to be able to guide You in replacing the screen.
  1. Shut down the Acer laptop, unplug the AC power adapter and all extensive devices.
  2. Remove the battery pack from the battery tray that is at the bottom of the screen.
  3. Open the display panel as far as You can open it.
  4. Pry the rubber screw covers from the display panel's front cover with a small, flat-head screwdriver.
  5. The front panel is the front plastic piece covering the LCD screen.
  6. Remove the Phillips-head screws fastening the front cover to the display panel.
  7. Remove the front cover from the laptop with your fingers.
  8. Remove the Phillips-head screws from each side of the LCD screen that fasten the screen to its metal frame inside the display panel.
  9. Tilt the screen forward, then disconnect the large ribbon cable from the connector on the back side of the screen.
  10. Peel away any tape securing the cable in place. Lift the screen out of the display panel.
  11. Place the new screen inside the display panel.
  12. Reconnect the LCD ribbon cable to the back of the new screen.
  13. Align the screw holes on each side of the screen with the screw holes on the metal framing inside the display panel.
  14. Replace the LCD screen's retaining screws.
  15. Replace the display panel's front cover, and its retaining Phillips-head screws.
  16. Then replace the rubber screw covers.
  17. Replace the battery pack, then reconnect all cables and devices to the laptop.
That is how to replace the screen of your phone.
Hope this was helpful. Thank You for using FixYa!!
Jan 12, 2011 | Acer Extensa 5620 Notebook PC
I have an LG VX8350 and the screen went white out of no where, it still works but i cant see anything
The problem with your phone is just flex problem, the flex on the screen of your phone is weak or worn out, this is a common problem among slide or flip phone.
What you need to do is to replace the flex on the screen of your phone, you can get this done by going to any local phone repairer within your vicinity to help get it fix or replace.
Once the flex is replace, your phone display problem is solve and the screen will start displaying.
Take care.
Aug 02, 2010 | LG VX8350 Cellular Phone
How do i replace the lcd screen
its cheaper to go on e bay and get another 1 camera i mean
Mar 12, 2010 | Canon PowerShot SD500 / IXUS 700 Digital...
Gatewy laptop screen
Replacing a screen is fairly easy, usually you will see some rubber bumpers at each corner of the screen, removed those and that will expose the screws, then you will need to gently pry apard the front bezzel from the back shell. after that you will need to remove any screws holding the LCD in place. Locate the model of the screen and find on on ebay or through your laptop manufacter. I just picked up a 15.4" lcd for a toshiba on ebay for 80$ with a 6 months warrenty.
Sep 09, 2009 | Computers & Internet
Right Hinge Broken
Here is the response that I got from Verizon customer service today via e-mail. I, too, have the broken hinge on a new LG VX8350:
"According to our records a limited number of LG VX8350 devices may exhibit a cracked hinge or stress cracks on the front housing from normal operation. LG determined hinge / stress cracking is due to a production issue with the hinge. LG has implemented corrective action to resolve issue in future production and devices repaired by LG."
They are replacing the phone with a certified LG. All in all, I am very pleased with their commitment to customer service. I would suggest contacting Verizon directly and letting them know that you are aware of the hinge problems.
Hope this helps.
Aug 03, 2009 | LG VX8350 Cellular Phone
Cracked screen LG vx8350
you will be able to just replace the lcd
thanks
erik
Feb 26, 2009 | LG VX8350 Cellular Phone
How to repair broken hinge of my Verizon LG Vx8350
I was able to take apart a VX8350 I have with a broken screen. I don't see any way to replace just the hinges with replacing the whole top part of the phone including the screen. The ribbon cable from the screen runs through the hinge part into the main assembly of the phone. It appears the cable can't be removed without cutting it.
Jan 11, 2009 | LG VX8350 Cellular Phone
REMOVAL OF FRONT LCD SCREEN TO REPLACE WITH NEW ONE
Flip open the phone and look for (4) rubber plugs at each corner of the inner LCD screen.
Using a very small flat-blade screwdriver, pry these rubber plugs out and you'll see the screws beneath them.
Remove the screw and you should then be able to take the flip part apart. Be sure to put the plugs and screws in a secure place so that you don't lose them.
Please let me know if I can be of further assistance to you.
- Jim
Feb 08, 2008 | Motorola Mobility RAZR V3i Cellular Phone
How do you replace the lcd on samsung t809
have you found out how to replace the screen yet?
If not post your message again. I can walk you through it.
Jan 09, 2008 | Samsung T809 Cellular Phone
Replacing cracked outter screen on my Razr V3i
A torx 5 screwdriver should do the trick as for the replacement try here: http://www.formymobile.co.uk/proddetail.php?prod=v3ilcd
Nov 24, 2007 | Motorola Mobility RAZR V3i Cellular Phone
LG VX8350 Cellular Phone Logo
120 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
