Question about Cycling
Rear suspension on Carrera MTB
At the base of the rear suspension spring on the Carrera Hellcat, there is a small red adjustable lug with ''R + and -'' on it. What is it for? I've no handbook, or experience and was given the bike.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 48 Answers
I'm guessing from your description that this is the recoil adjustment for the spring. plus will be stiff, and -minus will be mushy.
Posted on Jul 25, 2009
Adjust rear shocks, 1 - 5, which is stiffer?
Hi, Kevin if you're talking about the shocks on your dune buggy I can't help you, however if you are talking about your motorcycle shocks you're in luck, the setting that compresses the spring the most will be the stiffest. For more information about your issue please click on the links below. Good luck and have a nice day.
https://forum.motorcyclenews.com/topic/50159/how-do-i-know-if-my-rear-shock-is-set-properly/3
How to Measure and Adjust Rear Preload Adjust Motorcycle Suspension
How to adjust rear suspension on motorcycle preload settings Kawasaki...
Motorcycle Maintenance Adjusting your Suspension
May 27, 2016 | Motorcycles
Tip
Susspension set up for Motorcross bikes
When I need to set up a motorcross bikes suspension I set all the settings (both rebound & compression) to the middle of the range on both the front suspension & the rear suspension
Now, measure the distance from the inside of the rear mudguard and the top of the rear tyre & note the distance.
Now repeat with the rider seated in position and note the difference,
This value should be 20mm. If not adjust rear spring pre-load to correct.
Now, measure the distance from the inside of the front mudguard and the top of the front tyre & note the distance.
This value should be 15mm. If not adjust front spring pre-load to correct.(if adjustable).
This gives you your starting point for the fine tuning with the dampening adjustments to suit the riders preferances.
Regards Andrew Porrelli
on Dec 05, 2009 | Motorcycles
When my envoy sits overnight my rearend drops down
There has been a service bulletin for that type of concern. Here is what it states.
Suspension - Rear Suspension Is Low/Sagging/Uneven
Notes
ENGINEERING INFORMATION
Bulletin No.: 06-03-09-006B
Date: December 15, 2008
Subject:
EI06006 - Rear Suspension Uneven, Sagging, Low (Recalibrate Air Spring Sensor)
Models:
2006-2007 Buick Rainier
2006-2007 Chevrolet TrailBlazer SS
2006-2007 GMC Envoy, Envoy XL
2006-2007 Saab 9-7X
with Suspension Pkg - Rear Load Leveling (RPO G67)
Supercede:
This bulletin is being revised to update the labor operation in the warranty information. Please discard Corporate Bulletin Number 06-03-09-006A (Section 03 - Suspension).
Condition
Some customers may comment on the rear suspension being uneven or sagging.
Correction
DO NOT REPLACE THE COMPRESSOR.
Based on technician feedback, engineering has determined that the customer's concern can be corrected by recalibrating the air spring sensor. Refer to the Trim Height Uneven or Low diagnostics and Air Spring Sensor Calibration procedure found in SI.
Nov 29, 2011 | 2004 GMC Envoy
On my ROAD bike could a Sram/Truvati XX or XO (crankset 42/28-cassette11/36) work smoothly with Sram red doubletap Thank you.
To use Sram Red Shifters with such a wide range rear cassette requires a Sram 10-speed MTB rear derailleur such as an XX or X.0, it will work without problems with your red shifter.
Because it is a road bike, i suggest leaving the road crankset and front derailleur in place. If you need low gearing I suggest a compact front crankset.
If you need to use a mtb crankset, attept to use the road front derailluer with it.
Mar 11, 2011 | Sram X-0 XO REAR DERAILLEUR MTB ATB LONG...
I'm having problem with my Toyota AE100 which when I drive, the rear suspension sounds like 'klak..klak'. For your info, I'm using a GAB adjustable suspension with 17 inch wheels. I'm trying to get rid of...
first of all, since you are using adjustable suspension you should make sure the spring is captive in the shock absorber. Lift the rear of the vehicle and support the car on the body, allowing the rear wheels to hang down. See if the spring can easily be moved. If it can. then likely the spring has sagged, or it is incorrect for the shock absorber. If not, while you are there check that the top hat of the strut is tight by lifting the wheel and strut assembly by hand. If you get any movement in the top of the strut, there will be a loud noise while going over bumps. Another area to check are the stabiliser arm/sway bar bushes. Mounted to the body you will see a bar that goes left to right, connecting to the struts with small link arms. Try to move this bar up and down against the body, paying attention to the rubber bushes where it meets the body. If there is movement in the bushes, there will be banging sounds when going over rough surfaces or bumps. Also check the small link arms for looseness or play.
Mar 09, 2011 | 1993 Toyota Corolla
How do you let some of the air out the rear suspension on a 2003 navigatore
FIRST YOU TURN OFF AIR SUSPENSION SYSTEM.YOU LOCATE THE AIR SUSPENSION SWITCH WHICH IS ON THE RIGHT KICK PANEL.WHEN YOU TURN OFF AIR SUSPENSION SYSTEM.YOU LOOSEN REAR LUG NUTS THEN SAFELY RAISE AND SUPPORT VECHICLE. REMOVE TIRE.REMOVE ELECTRICAL CONNECTOR FROM THE AIR SPRING SOLENOID.THEN SLOWLY DISCONNECT AIR LINE FROM SOLENOID SLOWLY BLEED AIR FROM SOLENOID.
Nov 22, 2010 | 2003 Lincoln Navigator
I need a diagram of the rear brakes of a 1997 Intrepid Chrysler-where can I get one>
If the following is not enough then maybe try Alldata.com which generally has more information, but it will cost: REMOVAL & INSTALLATION Chrysler Concorde, New Yorker, LHS Dodge Intrepid Eagle Vision
  1. Remove the rear wheels and brake drums.
  2. Remove the dust cap from the rear hub and bearing assembly.
  3. Remove the cotter pin, nut retainer and wave washer. Discard the old cotter pin.
  4. Remove the rear hub and bearing assembly retainer nut and washer. Remove the rear hub and bearing assembly from the spindle.
  5. Remove the automatic adjuster spring from the adjuster lever.
  6. Rotate the automatic adjuster starwheel enough so both shoes move out far enough to be free of the wheel cylinder boots.
  7. Disconnect the parking brake cable from the actuating lever. Disconnect parking brake cable one side at a time.
  8. Remove the both lower brake shoe to anchor springs.
  9. Remove the 2 brake shoe hold-down springs from the brake shoes.
  10. Remove the brake shoes, upper shoe-to-shoe return spring, automatic adjuster and automatic adjuster lever from the backing plate as an assembly.
  11. Separate the brake shoes from the automatic adjuster mechanism.
  12. Remove the brake shoe automatic adjuster lever from the leading brake shoe. To install:
  13. Thoroughly clean and dry the backing plate. To prepare the backing plate, lubricate the bosses, anchor pin and parking brake actuating lever pivot surface lightly with lithium based grease.
  14. Remove, clean and dry all parts still on the old shoes. Lubricate the starwheel shaft threads with anti-seize lubricant.
  15. Assemble both brake shoes, the top shoe to shoe return spring, automatic adjuster and automatic adjuster lever before mounting on vehicle. Make sure the ends of the automatic adjusters are positioned above the extruded pins in the webbing of the brake shoes prior to installation.
  16. Install the brake shoe assembly onto the brake support plate and install the hold-down springs.
  17. Install the lower anchor springs and reconnect the parking brake cable to the park brake lever of the trailing brake shoe.
  18. Rotate the serrated adjuster nut to remove the free-play from the adjuster assembly.
  19. Install the automatic adjuster lever spring on the lead brake shoe assembly and the automatic adjuster lever.
  20. Install the rear hub and bearing assembly. Install washer and retainer nut and torque to 124 ft. lbs. (168 Nm).
  21. Install the wave washer, nut retainer and a new cotter pin onto the spindle. Install dust cap.
  22. Adjust brake shoes so not to interfere with brake drum installation. Install the rear brake drum. NOTE: After installing the brake drums, pump the brake pedal several times to partially adjust the brake shoes. To verify proper operation of the self-adjusting parking brake, be sure that both rear brakes are not dragging when the parking brake pedal is released.
  23. Install the rear wheels and lug nuts. Torque the lug nuts, in a star pattern sequence, to 95 ft. lbs. (129 Nm).
  24. Road test the vehicle. The automatic adjusters will continue brake adjustment during the road test of the vehicle.
Sep 03, 2010 | 1997 Dodge Intrepid
How to adjust rear spring coil suspension on (from
turn the coil lock nut counter clockwise to loosten
May 14, 2010 | 1990 Suzuki GSX 600 F (Katana)
Rear shoker hight adjust and if i do will this
this site will show you the cloickers how you can adjuts the shock by these
http://hubpages.com/hub/How-To-Adjust-Stock-Suspension-On-A-Dirt-Bike
and to adjust the spring you need to look at the picture below and above the red spring there is 2 silver rings above the red spring rings unscrew the top ring this is just a locking rings and adjust the spring you can just twist the spring and the ring will follow it and thats it really buddy any more info get back to me.0a2e9eb.jpg
Oct 03, 2009 | 2003 Yamaha YZ 250 F
No power to rear bags its down but wont air up bags dont seem cracked unplugged connector no power I tried resetting still no power
is switch on?
The air suspension switch and bracket is mounted below the RH side of the instrument panel.
Dealer can run diagnostic test with scan tool for fault codes.
The air suspension system is designed to improve ride, handling and general vehicle performance for static, on-road and off-road driving conditions:
  • Ride is improved by using an air type spring (the soft ride is inherent).
  • Handling is improved by maintaining constant vehicle attitude.
The system consists of unique rear air springs, the air compressor, air lines, air spring solenoids, height sensor, air suspension control module, attachments and associated signals derived from both driver and road inputs. With these components and signals, the air suspension control module commands changes in vehicle height that are necessary for the load leveling features.
The load leveling feature rear air suspension (RAS) systems shall automatically make adjustments in vehicle height so that the vehicle is always at trim height and constant front-to-rear vehicle attitudes are maintained over the expected load range of the vehicle. Adjustments in height that are necessary to correct height differences between the vehicle's left and right sides for the RAS system shall be restricted to what can be reliably achieved with one air suspension height sensor.
The system uses one air suspension height sensor, a steering sensor, generic electronic module (GEM) and other vehicle sensors to measure driver and road inputs. The system changes vehicle height using an air compressor, two air lines and the use of air springs with air spring solenoids.
The air suspension system holds vehicle height when the rear hatch or any door is opened. The system stores rear vehicle height the moment any open door is detected. The system then maintains this height regardless of the addition or removal of a load. The system will return to its commanded height when all doors are closed or the vehicle speed exceeds 16 km/h (10 mph).
Air Spring
RAS vehicles use air springs in the rear. The air springs provide a varying spring rate proportional to the systems air pressure and volume. The air suspension system regulates the air pressure in each air spring by compressing and venting the system air. Increasing air pressure (compressing) raises the rear of the vehicle while decreasing air pressure (venting) lowers the rear of the vehicle. Vehicle height is maintained by the addition and removal of air in each air spring through an air spring solenoid installed in the upper spring cap and energized through the air suspension control module.
The two air springs support the conventional rear leaf coil springs.
Air Suspension Height Sensor
One air suspension height sensor is mounted on the vehicle. The air suspension height sensor sends a voltage signal to the air suspension control module. The output ranges from approximately 4.75 volts at minimum height (when the vehicle is low or in full jounce), to 0.25 volts at maximum height (when the vehicle is high or in full rebound). The air suspension height sensor has a useable range of 80 mm (3.2 in) compared to total suspension travel of 200-250 mm (8 to 10 in) at the wheel. Therefore, the air suspension height sensor is mounted to the suspension at a point where full rear suspension travel at the wheel is relative to 80 mm (3.2 in) of travel at the air suspension height sensor. The air suspension height sensor is attached between the No. 5 frame crossmember (upper socket) and the panhard rod (lower socket).
When the air suspension height sensor indicates that the rear of the vehicle is lower than trim under normal driving conditions, the air compressor will turn on and pump compressed air to the air springs. When the sensor indicates that the rear of the vehicle is raised above trim under normal driving conditions, this will cause the air to be vented from the air springs to lower the vehicle back to its trim height level.
Compressor Relay
The compressor relay is energized by the air suspension control module to allow high current to flow from the battery to the compressor motor.
  • A solid state relay is used in the air suspension system for air compressor control. The relay incorporates a custom power metal oxide semi-conductor field effect transistor (MOSFET) and ceramic hybrid circuitry. The relay switches high current loads in response to low power signals and is controlled by the logic of the air suspension control module.
Air Suspension Control Module
NOTE: The 4WAS air suspension control module is used for the RAS system. The internal processor recognizes external circuitry to determine if it is installed in a 4WAS or a RAS equipped vehicle.
NOTE: The air suspension control module is calibrated with information from the air suspension height sensor. A new or exchanged air suspension control module requires a ride height adjustment calibration process to be performed.
The air suspension control module controls the air compressor motor (through a solid state relay), and the air spring solenoids. The air suspension control module also provides power to the air suspension height sensor. The air suspension control module controls vehicle height adjustments by monitoring the air suspension height sensor, vehicle speed, a steering sensor, acceleration input, the door ajar signal, transfer case signals, and the brake pedal position (BPP) switch. The air suspension control module also conducts all fail-safe and diagnostic strategies and contains self-test and communication software for testing the vehicle and related components.
The air suspension control module monitors and controls the air suspension system through a 32-pin two-way connector. The air suspension control module is keyed so that the air suspension control module cannot be plugged into an incorrect harness. There are two sides of the harness connection to the air suspension control module. Each is uniquely colored and keyed to prevent reversing the connections.
Visual Inspection Chart Mechanical Electrical
  • Restricted suspension movement
  • Excessive vehicle load
  • Cut, severed or crimped air line(s)
  • Unmounted height sensor
  • Damaged air spring(s)
  • Open fuses:
    • Central junction box (CJB) Fuse 4 (15A), 6 (5A) and 20 (5A)
    • Battery junction box (BJB) Fuse 109 (50A)
  • Loose, corroded or disconnected connectors
  • Air suspension switch is in the OFF position
  • Damaged solenoid valve(s)
  • The compressor is inoperative
  • BJB Fuse 109 (50A).
  • Air compressor assembly.
  • Circuitry.
  • Air suspension relay.
Apr 30, 2009 | 2000 Ford Expedition
Cycling Logo
122 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
