Question about GE Refrigerators
My GE refrigerator model GFSS6KKYSS will no take ice. What could be wrong ?
5 Suggested Answers
  • 358 Answers
SOURCE: the ice maker on our GE refrigerator does not make ice
1 -Ice maker arm must be down(on position)2-Make sure the water supply line is connected to the fridge3Check if the ice maker is plugged in4The freezer must be working fine for the ice maker to produce ice. After the ice maker stars and calls for water and doesn't get any , the water valve is bad.And if everything above is ok the ice maker needs to be replaced.
Posted on Apr 26, 2009
  • 22 Answers
SOURCE: GE refrigerator is the worst product I have even
Well, i have to jump right in here and agree with you. I have been working on appliances since 1971 and GE is the most frustrating, highest priced replacement parts ( for the most part ) of all brands. Of all the brands, Whirlpool and Maytag have been the longest lasting, best priced and easiest to work on. I truly feel sorry for you....really.
Posted on May 12, 2009
SOURCE: I have the GE Gss 25qsta ss model refrigerator and
Your main board most likely needs to be replaced. Located in the back of the unit.
GE refrigerator repair in orange county, ca
appliance repair orange county, ca
Posted on Feb 07, 2010
MNTECH
  • 1543 Answers
SOURCE: I have a GE refrigerator
This is a rather unique refrigerator in that there is a seperate evaportator (cooling coil) for the refrigerator section and the freezer section, where as almost all other refrigerators only have coils in the freezer section and use a fan to blow some of the cold air into the refrigerator section. This design will prevent cross contamination of odors between fresh foods and freezer sections, and allow lower humidity freezer at the same time as higher humidity fresh foods. All good things.
That said,..... you need to take the cover off the back wall from inside the fresh foods section and thaw out the defrost drain locted at the bottom of those cooling coils. If I remember correctly, there are a couple hidden screws, and the back panel needs to be pryed off using a putty knife, I think you will find 4 small arrows / pointers for the spots to pry at. With cover removed, use a turkey baster with warm water until the water flows out the drain.
Posted on Apr 03, 2011
Resale value of my GE refridgerator
SORRY we do not do that here on FIXYA
Dec 13, 2016 | GE Refrigerators
Refrigerator model ge GFSs6KKYSS refrigerator is not cold like it should be where is the evaporator fan located
This fan you seek is located above the evaporator. I would need a correct model number to give you more information as to its accurate location.
Aug 01, 2014 | Refrigerators
Ice not dropping
The bar on the ice maker that ensures there is a catch basin underneath needs to be in the up position, after that you might check the drive motor on the dumper.
Jun 11, 2014 | GE GFSS6KKYSS (259 cu ft) Bottom Freezer...
I do not get ice or water
Without water you will not get ice anyway, my suggestion is to check the water line into the unit & make sure it hasn't kinked anywhere.
Nov 21, 2013 | GE GFSS6KKYSS
No water or ice
check to make sure water to valve in back lower section and be sure no water line is crimped if water at valve check voltage when pushing the water dispenser if there is voltage , bad water valve if not swith at dispenser
I have a GE refrigerator GFSS6KKYSS Model. Serial #: LS900091 It appears that there is ice on the back of the refrigerator and water is collecting on the floor of the compartment. What is the problem and...
Apr 03, 2011 | GE GFSS6KKYSS
Brand new GE Profile GFSF6KKYCBB French Door with external ice and water dispenser. After filling a glass of water, pull the glass out and water turns completely off as expected. Two seconds later, the...
Sorry to read about your problem, I hope this helps you out.
factory defective, call in warranty service
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 22, 2010 | GE GFSS6KKYSS (259 cu ft) Bottom Freezer...
Open Questions:
GE Spacemaker JVM1339ww002 - looking for photo of plugs in control board plugs for reassembly or a wiring diagram? Disassembled without noting locations and now start & clear buttons do not work. I have a very old model GE spacemaker XL microwave, model# JVM1339ww002. I repaired the #1 key by cleaning contacts and reinserting the ribbon connector to the control panel. However, I did not photograph the connections. Some plugs have only 1 location where they fit. However, 2 pairs of plugs are the same size and I do not know the correct place to reinsert them. I took a guess & reassembled the microwave and it worked except for the start/clear buttons. If you press a number 2 shortcut for example, it will cook 2 minutes and the food is heated. However, start and clear do not work at all. These buttons DID work before I repaired the numbers. I contacted GE and they gave me a hard time about providing the wiring diagram which was removed or not inside my microwave. I am not sure if I reassembled the plugs wrong OR if I broke something else when I was repairing the numbers. Can anyone help me with the right locations for the 2 pairs of plugs listed below? And/Or tell me if it sounds like start & clear are a new problem or will be resolved by getting the plugs correct? These are the 2 sets of plugs that can be inserted in either location: 1) a pair of matching white plugs that snap in place along the bottom (1 has white wires only and the other has 1 white/1 black wire) 2) a pair of red and white plugs of equal size in the middle of the board. They are similar (but smaller) to plugs in wall outlet with 2 prongs. Similar to a wall outlet, you can rotate the plug 180 degrees and they still fit. In other words besides asking which plug is upper or lower, do I need to worry if the plug is upside down or this doesn't matter? The red plug has black wires, while the white plug has blue and white wires.
Apr 19, 2018 | GE Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
