I have a Zanussi Aquacycle 1100 xc, when I switch it on the the start/pause button keeps flashing constantly, the door light is on, as tho it was locked and there is a clicking sound, as if the door was trying to lock or open. It's as though it is on constant pause and when you shut the door it is constantly locked. It wont open until you switch off the machine. What could the problem be? Do you think it is the door lock mechanism or the pcb board?
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 17 Answers
It could be the door lock , it is locking but contact are still open
Posted on Jun 23, 2017
  • 54 Answers
SOURCE: zanussi aquacycle 1000 xc washer
faulty fill valve. or tap not switched on correctly if it has the blue tap remove the top of the tap and use pliers to switch it on
Posted on Feb 14, 2008
  • 101 Answers
SOURCE: where can I but a
try ebay.
Posted on Apr 23, 2008
  • 1462 Answers
SOURCE: My zanussi Aquacycle 1100 wont
door interlock is easy to replace.
undo the plastic clamp that holds door gasket to cabinet. peel back in area of door lock. door lock is held by 2 screws on outside. undo these ans lock comes off. there may also be a small diameter hose as well to door lock which take off as well.
reassembly is just the reverse
Posted on Jun 30, 2008
  • 1462 Answers
SOURCE: WHERE IS THE PRESSURE SWITCH
as i remember, it is located underneath the crossbar on the top of the machine, visible when you remove the worktop
Posted on Jul 04, 2008
mumma_1
  • 903 Answers
SOURCE: I need to know what
if you look on the back of the machine there should be a label there with the model number. (Or inside the users manual)
http://www.zanussi.co.uk/ or go here and click on 'Contact Us' to find out directly fron Zanussi.
Posted on Nov 08, 2008
Zanussi aquacycle 1200
Turn the machine to the off position. Unplug it and then plug it back in. Now try to restart the cycle. If this does not help find a local washer and dryer repair shop
Jan 24, 2014 | Washing Machines
Machine won't restart after reset, 'start/pause' button flashing.
When you put it to drain/spin does the pump make any attempt to drain,if not it could be that there is something stuck in the pump,needs draining manually.Another thing to try is to find the fault code.If you hold down the 2 buttons on the far right of panel then press on/off button till lights start chasing,then release the 2 buttons on right hand side.Now the first function button by the on/off button you will need to press until the light above the button reaches the 9th or 10th position this will give you a read out in the display.
E10 = low water press.
E20 = pump or filter.
E30 = press. switch or heater faults.
E40 = Door swich.
E50 = motor.
Some of these numbers can vary there are more but those are the most common.After checking codes switch off machine then back on twice to reset.
Hope this helps.
Jan 26, 2010 | Zanussi FLE1416W Front Load Washer
I HAVE A ZANUSSI XC AQUACYCLE 1000 FRONT DOOR
broken circuit in printed circuit board
Aug 11, 2009 | Zanussi Washing Machines
I need instructions for zanussi aquacycle 1400 XC
My washing machine dials won't light up and strait but the power is switched on
Jul 03, 2009 | Zanussi F1245W Front Load Washer
Zanussi aquacycle 1000 start pause button
Try some WD40 on the door lock on machine (not on the door) & open and close a few times. Of course the mains plug should be off the wall socket.
Feb 28, 2009 | Zanussi IZ12 Front Load Washer
investigate the water inlet cold water inlet valve
Feb 28, 2009 | Washing Machines
Zanussi electrolux aquacycle 1400 xc 6 fx1465 w
i have a problem with my zanussi aquacycle 1400 xtra capacity. some times it works ans some times not like there is a problem with the power the alternater? should i change this part? please help as my wife is driving me crazy.
Mar 20, 2007 | Zanussi F1245W Front Load Washer
assuming you had correct value fuse, fuse blowing may have been caused by a machine fault.after power outage, cycle should resume.
Washing Machines Logo
621 people viewed this question
Top Washing Machines Experts
