Question about Samsung SGH-d807 Cellular Phone
Dropped phone and now it won't slide correctly
I dropped my Samsung D-807 and, although it works correctly, it won't slide smoothly and doesn't seem to be closed completely when it ought to be. Anyone else had this problem? Can anyone help? I love this phone and want my smooth sliding back!! Thanks.
  • Anonymous Sep 04, 2008
    I'm having the same problem. I can see exactly what needs to be fixed, but I just can't get the darn piece to budge.
    Problem Solver:
  • 5 Answers
You probably have a chip inside the center of the slider. Try taking a vac to it and sucking out any fragments that might make it rough. Otherwise you have damaged your phone and most likely your provider will not replace the phone due to normal wear and tear damage.
Posted on Dec 09, 2007
Samsung corby pro B5310 - Touch screen is working partially left side is not responding????? Although the keypad is working fine there seems to b some software problem????
I have had 2 phone that did that and its because I dropped it in liquid. The only way to fix that is a new board.. unless u know how to find and replace components on the board.
May 31, 2012 | Samsung GT-B5310 Corby Pro GSM Slider...
Dropped phone and now doesn't work
Try any of the below combination.
  1. Hold Volume Up + Volume Down + Power.
  2. Hold Volume Up + Home + Power.
  3. Hold Home + Power.
  4. Hold Volume Up + Camera
Dec 12, 2017 | Samsung Cell Phones
My samsung TL220 i dropped it won't power on or anything
Things to check first for a camera that won't turn on (no power, no lights, no noise, nothing) are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
But if there is some electrical activity, then you're more likely experiencing a lens error. In that case, see this article.
and this video:
Nov 21, 2011 | Samsung DualView TL220 Digital Camera
I dropped my iphone and it said no sim, i put it back in but now the home button doesn't work and it won't charge a and my computer is not registering it when I plug it into the usb port, is there...
its seems like you have loose connection inside of phone. because home button and charger port have same pin connection.
My advice is you have to take your phone to technician.
thank you.
Sep 07, 2011 | Apple iPhone Smartphone
I dropped my iphone 3g and cracked the screen....I replaced the screen and now the bottom half won't says slide to unlock...and it won't slide...but the top that says slide to turn off...
Check the 2 pins connected on the home button if touch the interface of the board,might not hitting that is why the slide unlock not working.
Jul 21, 2011 | Apple iPhone Smartphone
Some stupid person has dropped and then kicked my brand new Samsung camera and now it won't turn on and the lens is stuck out :( When I try to turn it on it makes a weird beep and won't turn on and...
You should try to get that stupid person to buy you a new camera if the following doesn't help. Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Here are some troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them.
Jul 09, 2011 | Samsung Digimax S730 Digital Camera
My touchscreen doesn't work,
Usually when touch screen doesn't work, it's a sign of water damage. It's also possible that you dropped it at some point and ruined the sensors inside. But it's PROBABLY water damage. What you can do is bring it to your phone carrier's closest store and ask them to check if your phone suffered water damage. They'll open the phone up and look. If it is water damage, you'll probably have to pay for a new one...If you're insured, it probably won't be that expensive.
The good news is, if you bring it there and it ISN'T water damage, you probably won't have to pay anything at all for them to replace it. Hope this helps!
Please rate my solution!
- Frankie
May 06, 2011 | Samsung Star GT-S5233 Cell Phone
Dropped phone, screen black
Replacing it is not too much trouble for an experienced cell phone technician. But, it's not for anyone who doesn't like to tinker with small things. Here's a video demonstrating the entire process:
Jul 21, 2010 | Samsung Eternity Cell Phone
Iphohe dropped in clean water. Slide will not
inspect this mechanical slider for proper seating.... it may be slightly ascew in the grooves .....also look to see it the nub button it acuates is popped past the slider push it down and slide the slider past it to reseat
Nov 22, 2009 | Apple iPhone Smartphone
Samsung g600,dropped,buttons,sound not working and screen blanks
Hi, I have a Samsung G600 Service Manual PDF if you want it, and it will tell you all the disassembly and reassembly instructions!
Let me know Harvie
May 17, 2009 | Samsung SGH-G600 Cellular Phone
Samsung SGH-d807 Cellular Phone Logo
56 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
