I don't want to stabilise my name in public, - Computers & Internet
Can I include a research publication on my graduate school application if my name was not included in the publication?
Site your work exactly as you did it. Do not site the publication, but you can tell them it was published and give them the name of the publication
Jan 04, 2017 | Higher Education (University)
What to do when the power on the mother board is not stable
Hi Don, best practice is to get a 600VA UPS Device which will stabilise and filter the power
Regards
Aug 13, 2016 | Computers & Internet
Hi I'm Vinoth... I have windows 8 laptop. when i connect public WiFi its asking a Administrator user name password. pls help... thank you
That is because the public wifi is not secure. Set up a password if you are the owner/administrator.
Nov 18, 2015 | Computers & Internet
I can start my Primavera P6 with OS windows 7, I use P6 stand alone. database configuration said ''Bad public user name or...
The standalone DB Configuration seems simple but can be tricky When you configure the DB you have to use a Coded Username for the AdminSuperuser permissions "admprm$pm"! this user name makes your actual Log in username "Admin" you cannot use the admprm$pm at the Log in screen. Same with the Public User Permissions "pubprm$pm" gives read permissions but log in user name is "Public" Try the "Admin/Public" usernames if this does not work you may have to Uninstall and Reinstall. If you uninstall remember there are 2 peices of software to remove... P6 and the Oracle Database 10G
Refer to: http://www.tensixconsulting.com/2013/03/primavera-p6-database-connection-configuration-details/ For further DB Config Issues.
Mar 25, 2013 | Primavera Contractor 6.1 Full Version for...
Not getting wi Fi
  1. From the Homescreen, tap Settings.
  2. In Settings, tap Wi-Fi.
  3. Slide the slider to "on" to start your device looking for Wi-Fi networks. In a few seconds, you will see a list of all available networks (if you don't see the list, there may not be any within range).
  4. There are two kinds of networks: public and private. Private networks have a lock icon next to them. Public don't. The bars next to each network name indicate the strength of the connection - the more bars, the faster connection you'll get.
    To join a public network, just tap the network's name and you'll join it.
  5. If it's a private network, you'll need a password. Tap the network name and you'll be prompted for a password. Enter it and tap the join button in the bottom right-hand corner. If your password is correct, you'll join the network and be surfing the web. If not, you can try entering it again (assuming you know it, of course).
  6. More advanced users can click the arrow at the right of the network name to enter more specific settings, but the everyday user won't need this.
Oct 08, 2012 | Cell Phones
Need User Manual for Electrolux Model Number N520J-R, Freezer is cold, but fridge section is not.
The right bottom corner of my fridge is broken and I need the part. Please let me know if it is available. The specification is as follows: model code: N520J-R, and name is Electrolux, Kelvinator, please let me know because I do not have any other option to fix it. I have financial problem to buy a new now but only I can buy a door to replace it. Thank you. My contact: razaqanwari@yahoo.com, my mobile is 0406266401
Jan 03, 2012 | Refrigerators
My bike coughs and splutters and backfires constantly. It's unrideable. It also has an engine knock under load. I use BP ultimate and have tried fuel stabiliser. Any ideas?
Make sure you don't have water in your fuel. Also try a different brand of fuel, some bikes don't like certain types of fuel.
Sep 11, 2011 | 2008 Husqvarna TE 510
Screen message: Camera Stabiliser is not
my ex-v7 camera will not take photos screen says camera stabiliser not available
thank you phil
Apr 22, 2010 | Casio Exilim EX-V7 Digital Camera
Embroidery arm misaligns design, but not on a regular basis. One stitch-out will be off and the next of the same design stitches just fine. Just returned it from service where it was calibrated, cleaned....
Firstly check that the embroidery arm is not hitting against something as it travels around. Even a very slight bump and put things off. However, most registration problems are caused by incorrect hooping or insufficient stabilising, or a combination of both. Even using the same fabric and same stabiliser you will not necessarily get the exact same sew-out results if there is slight variation in the amount of tension on the stabiliser. There are lots of tips out there for better hooping and stabilising, but my favourite is to hoop the stabiliser firmly then turn the hoop over and put 1" or 3/4" wide masking tape half-and-half over the edge of the hoop and onto the stabiliser on all four sides. This stops the stabiliser from moving about at all. Try it and see how it goes.
Dec 06, 2009 | Husqvarna Designer I
I need a complete workingsource code written in
This is a simple source code for Simple calculator in Java using RMI
//mathServer//
import java.rmi.*;
import java.rmi.Naming.*;
import java.rmi.server.*;
import java.rmi.registry.*;
import java.net.*;
import java.util.*;
interface mathInterface extends Remote
public int add(int a,int b) throws RemoteException;
public int subt(int a,int b) throws RemoteException;
public int mult(int a,int b) throws RemoteException;
public int div(int a,int b) throws RemoteException;
public class mathServer extends UnicastRemoteObject implements
mathInterface
public mathServer() throws RemoteException
System.out.println("Initializing Server");
return(a+b);
return(a-b);
return(a*b);
return(a/b);
public static void main(String args[])
try
mathServer ms=new mathServer();
java.rmi.Naming.rebind("MathServ",ms);
System.out.println("Server Ready");
catch(RemoteException RE)
System.out.println("Remote Server Error:"+ RE.getMessage());
System.exit(0);
catch(MalformedURLException ME)
System.out.println("Invalid URL!!");
//mathClient//
import java.rmi.*;
import java.awt.*;
import java.awt.event.*;
public class mathClient extends Frame implements ActionListener
Button B1=new Button("Sum");
Button B2=new Button("Subtract");
Button B3=new Button("Multiply");
Button B4=new Button("Divide");
Label l1=new Label("Number 1");
Label l2=new Label("Number 2");
Label l3=new Label("Result");
TextField t1=new TextField(20);
TextField t2=new TextField(20);
TextField t3=new TextField(20);
public mathClient()
super("Calculator");
setLayout(null);
l1.setBounds(20,50,55,25);
add(l1);
l2.setBounds(20,100,55,25);
add(l2);
l3.setBounds(20,150,55,25);
add(l3);
t1.setBounds(150,50,100,25);
add(t1);
t2.setBounds(150,100,100,25);
add(t2);
t3.setBounds(150,150,100,25);
add(t3);
B1.setBounds(20,200,80,25);
add(B1);
B2.setBounds(100,200,80,25);
add(B2);
B3.setBounds(180,200,80,25);
add(B3);
B4.setBounds(260,200,80,25);
add(B4);
B1.addActionListener(this);
B2.addActionListener(this);
B3.addActionListener(this);
B4.addActionListener(this);
addWindowListener(
new WindowAdapter()
public void windowClosing(WindowEvent e)
System.exit(0);
public void actionPerformed(ActionEvent AE)
if(AE.getSource()==B1)
sum();
else if(AE.getSource()==B2)
subt();
else if(AE.getSource()==B3)
mult();
else if(AE.getSource()==B4)
div();
public void sum()
int i=Integer.parseInt(t1.getText());
int j=Integer.parseInt(t2.getText());
int val;
try
String ServerURL="MathServ";
mathInterface MI=(mathInterface)Naming.lookup(ServerURL);
val=MI.add(i,j);
t3.setText(""+val);
catch(Exception ex)
System.out.println("Exception:"+ex);
public void subt()
int val;
try
val=MI.subt(i,j);
t3.setText(""+val);
catch(Exception ex)
public void mult()
int val;
try
val=MI.mult(i,j);
t3.setText(""+val);
catch(Exception ex)
public void div()
int val;
try
val=MI.div(i,j);
t3.setText(""+val);
catch(Exception ex)
mathClient MC=new mathClient();
MC.setVisible(true);
MC.setSize(600,500);
Jul 03, 2009 | Microsoft Computers & Internet
Computers & Internet Logo
David Payne
David Payne
