Question about Power Computers & Internet
My stick vaccum is not charging ,it is flashing green at the power outlet when switched on ,tried ringing your 1800 number was put on wait for 2 hours then got disconnected not happy ?
    Top Expert:
  • Power Master
  • 48,191 Answers
You called the manufacturer number not fixya site
what you should do is find the local authorized repair agent and take it to them for a warranty fix
Posted on Apr 18, 2017
My Dyson stick is not charging. The charger has a green light that is flashing but the stick will not charge.
Hi Lawrence, it's Jack at Dyson.
A flashing charger light indicates a fault that's preventing the machine from charging, but the speed at which the light flashes provides further information on exactly what the issue is.
I would encourage you to contact our experts directly when you have your Dyson cordless vacuum and the charger easily to hand, so we can talk you through some simple diagnostic checks to pinpoint the problem. It may be something very simple, such as the machine being outside it's optimum temperature range - in which case allowing it to cool down could resolve the issue.
You can reach the Dyson Customer Helpline by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
We'll look forward to speaking with you.
Jul 05, 2015 | Dyson Dc25 Animal Ball Upright Vaccum With...
My dc59 doesnt work green light flashes when you press start button
Hi there, it's Jack at Dyson.
A green light flashing when you try to use your DC59 could mean the battery has no power. If you're confident it's been allowed to charge for at least 3.5 hours, it's possible that the charger cord isn't connecting correctly with the machine itself, so no power is reaching the battery. This is more likely to occur if you're recharging the machine in the docking station, and the charger cord isn't correctly positioned.
We're happy to help you check for and resolve this - if a replacement part is needed we can also confirm if this is covered under our 2-year parts and labour guarantee. When you have your machine to hand, please give our experts a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Aug 27, 2014 | Dyson DC59 Animal Bagless Cordless Stick...
My kobo wont turn on
How to Fix Kobo eReader Locked up Frozen or Not Responding
1)Slide power switch to right and hold for 15 seconds and release
    2)Slide power switch to right again and hold till green/blue button near switch lights up.
Dec 05, 2017 | iPhone Apps
Volitation 9053 flashing green light when charging brand new out the box
I have the same problem. I watched the video on and it shows it off while charging, but mine blinks for like 3 hours then turns solid green so I guess it is done. Anyone care to comment???
Nov 17, 2011 | xheli 9053 Outdoor Volitation Metal...
No caller ID. TP company says I have service.
  • Did you fully charge your phone? - Make sure you fully charge for 16-24 hours .
  • Is the battery old? - Replace the battery.
  • Is the electrical outlet switch turned on? - If you are using AC (electrical) power, make sure that the unit is connected to a non-switched electrical outlet.
  • Are the connecting wires tight - Unplug the AC power converter from the unit and plug it back in.
  • Do you have Caller ID service with your telephone company - In order to receive Caller ID records, you must subscribe to the standard name and number Caller ID service available through your local telephone company. If the Caller ID works for normal calls but not on Call waiting calls, then you must contact your phone company to get the combined CID/CW service.
  • Caller ID shows up after second ring - Be sure to wait until the second ring before answering. Caller ID signals comes through after the first ring, if caller pick ups phone too soon Caller ID signal will not be transmitted to the handset.
  • Confirm that caller ID is still working on that particular line by checking another phone on the same line - If Caller ID is not coming through contact your phone company provider.
If this does not fix your problem, contact your authorized Service Center.*
Oct 16, 2010 | Uniden DECT 6.0 Cordless Phone ID
Immobiliser is not turning off and not allowing the engine to start
is it a stick immobiliser?
If your vehicle does not start and the LED continues to flash while the Ignition is 'ON', this means that the Immobiliser system has not recognised the transponder stick.
Simply turn the Ignition 'OFF' then back 'ON' again. If the Status LED continues to flash, move the transponder stick closer to the key barrel until the LED stops flashing and turns 'OFF'.
If the transponder stick on the key ring does not disarm the immobiliser or the
transponder stick is misplaced, you can override the system by entering a 5-digit override number. Each vehicle has a unique 5-digit override number. This number is recorded on the
customer’s owner’s manual. If the customer loses their owner’s manual / override number, the number can be found by locating the vehicle’s Daewoo Stock Number (D.S.N). The customers override number is the last 5 digits of their D.S.N.
Overriding the system using the example 5 digit code 2,1,0,6,2
Important Note: 10 flashes of the Status LED represent the number ‘0’.
1. Remove the Transponder from the Key Ring.
2. With the system armed (LED flashing slowly) Turn the ignition ON/OFF 5 times, with the final position being off.
3. The LED will turn solid red for 2 seconds and then begin to flash.
4. When the LED flashes twice (2), turn the ignition ON. (number 2 was entered)
5. Turn the ignition OFF and wait for the LED to flash once (1) and then turn the ignition ON. (number 1 was entered)
6. Turn the ignition OFF and wait for the LED to flash ten (10) times and then turn the ignition ON. (number 0 was entered)
7. Turn the ignition OFF and wait for the LED to flash six (6) times and then turn the ignition ON. (number 6 was entered)
8. Turn the ignition OFF and wait for the LED to twice (2) and then turn the ignition ON.(number 2 was entered) The LED will turn solid red, which means the system is now overridden and the vehicle can be started. If an incorrect number is entered in, wait 11 flashes then start the procedure again.
NOTE: This is a one-event override. Once the ignition is turned off, the vehicle will passively immobilise after 30 seconds. If your 5 digit override number does not override the system, the chances are that you entered the wrong number. If this is the case, you’ll need to re-enter the override number
and try it again.
Jul 13, 2009 | 1999 Daewoo Lanos
No Power to outlets, Power light flashes green
Let it charge without anything plugged in to the outlets for at least 8 hours. Then, test the battery voltage again. If you still get less than 11.5 volts on either of the batteries, it's time for a new set. It's recommended that you replace both as the other one, even with a reading of 12 volts, is going to fail very soon. The UPS is trying to charge the batteries to get both batteries, as a pair, to 24 volts. It will continously charge them until it gets there (which won't happen if it's a bad battery) and you'll burn out the new one you just replaced. You can new batteries at for a fraction of the cost of a new UPS. Hope this helps.
Jun 10, 2009 | Tripp Lite Lite OmniSmart 725...
Flashing green light and hour glass - performs no functions
Please perform the steps given below and check the functionality.
Bypass the surge protector
If the all-in-one is plugged into a power strip, remove it from the power strip and plug it directly into a wall outlet and see if the message still appears.
Power Cycling
1. Verify that the unit is switched on. Unplug the all-in-one from power and disconnect the connection port.
2. Wait 30 seconds.
3. Plug in the power only.
4. Repeat steps 2-4 two more times.
5. On the third time after plugging the unit into power, reconnect the connection port from the all-in-one to your computer.
6. Restart your computer and check the functionality.
May 26, 2009 | HP Photosmart 2410 All-In-One InkJet...
LC 32D43U power and OPC green light flashing set does not come on
hey i have had the same problem but i unplugged the tv for awhile about a half hour and then plug your tv into a different wall outlet if you can and should work. It worked for me, i had it plugged into a surge protector then i unplugged it from there, let it sit of half hour then plugged into different wall outlet and worked. so try that and see if it works.
Dec 29, 2007 | Televison & Video
Wont boot up
Make sure the battery pack is charged. The power indicator LED should light red or green depending on how much charge is in the battery. ? Turn the power off. Wait a few moments, then turn the power on. ? Turn the power off. Remove game and reinsert it, then turn the power on. ? If you are using the AC Adapter, make sure it is securely connected to both the Nintendo DS and the wall outlet.
Aug 13, 2007 | Nintendo DS Console
Computers & Internet Logo
Top Power Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Power Computer and Internet Expert? Answer questions, earn points and help others
