Only have limited sound from Behind speakers, all sound coming from soundbar itself
My new Vizion tv has a vizion sound bar, the sound comes out with an echo, how do I correct?
Your TV speakers should be turned all the way down or off when you use a separate sound system such as a soundbar. Using them with the soundbar may cause echoes and the TV speakers do nothing to improve the sound.
Look at your TV's audio menu. If you can, turn the TV speakers off completely at the menu. Also see if you can set the analog audio output to "variable." This will allow you to control the soundbar's volume with the TV remote.
Jul 08, 2017 | Echo Computers & Internet
How do I get the new laptop soundbar to function on my Acer Aspire 5749 laptop?
IN THE LOWER LEFT HAND BAR IS SPEAKER ICON, CLICK ON IT AND SET ITS LOUDNESS.
Jun 18, 2015 | Acer Aspire Computers & Internet
Harmon karmon sb15 soundbar sound shuts off
A capacitor on the power board has blown. Take it to a shop or warranty replace if available
Apr 12, 2014 | Harman Kardon SB 16 Main / Stereo Speaker
My Dell AX510 Soundbar Speaker isn't working, although the blue light is on, indicating it has power. I'm using a Dell monitor that is set up primarily for Playstation usage.
Ensure that the sound is actually supposed to be coming through the speakers. Just because the power is on doesn't mean that audio information is actually on it's way to the actual speakers. Maybe the television volume is low or muted, maybe the output volume is being routed somewhere else, or maybe the soundbar is broken. You should investigate and follow the signal to find the problem.
Sep 29, 2013 | Dell Ax510 Ax510pa Soundbar Sound Bar...
No sound coming from soundbar
You Should follow the correct optical cable and try fit
Feb 16, 2013 | Yamaha YAS-201
VIZIO VHT510. soundbar and subwoofer work. No sound from satellite speakers
Do you have them connected to the sub? Those satellite speakers pick up the fainter sounds and work best in movies with 5.1 surround sound. Make sure they are behind the primary listening position. And try them with a 5.1 surround movie. If all speakers are up front switch to front listen mode. Good luck.
Mar 06, 2011 | Vizio VHT510 Theater System
26 people viewed this question
 Grubhead
Grubhead
