Question about Locks & Locksmithing
I forgot the lock combination - Locks & Locksmithing
Forgot my Presto Lock combination!
You cannot reset the lock unless you know the combination. You would need someone to pick the lock, like a locksmith and then once it's open you can reset the lock with a new combination.
Jan 25, 2013 | Locks & Locksmithing
I forgot the combo for my Kryptonite bike lock US PAT 593412/6422051, can you please help? Thank you
Another way is to pull apart the ends till you have tension on the tumblers. As you place tension try to turn the tumblers. As you feel each loose or tight tumbler is how you can find your combination. I open this type of combination lock like this all the time. First look for the tightest tumbler, turn it until it feels looser and next look or feel for the next tight tumbler. All the tumblers do not block the release at once. You are looking for the first tumbler to adjust, the tightest one, then the next, continuing until you find you have released all the tumblers. This has worked for me with any brand of inline tumbler release system out there. Good luck, usually takes me about 10-15 minutes to find the code. This method can be used on regular locks with a changeable combination as well. It will just take a little time to get to know how much tension to use as you go through each tumbler. Similar as to how you pick a regular lock system. Good luck, definitely doable.
Jan 24, 2013 | Kryptonite Cycling
I got the master lock speed dial combination lock but forgot my combination and it won't open. can somebody please tell me if i can reset the password?
1. Contact Masterlock.com and fill out the form, get it notarized and send it in for the combination to unlock it based on the S/N which is on the lock.(http://www.masterlock.com/faq/LostCombinations/). Good luck on this since Masterlock will end up finding something that will prevent them from giving you the combination. Its quite frustrating and NOT worth the trouble.
2. Go to home depot. Buy a 24in bolt cutter ($22) cut the stem of the lock. and replace with a new lock that you can buy from home depot for $ 29.00. If you have a key that is inside the lock box that you really need, You will now need to drill out the combinations piece by piece and the door will pop open or send the lock back to Masterlock. They will retrieve the key for you and send it back.
Aug 27, 2012 | Master Lock 5400d: Portable Select Access...
My ipod is lock and i forgot the combination can
if you mean the button lock where the safe-dial is on screen - just plug it into the computer and iTunes cancels the lock
Jan 17, 2010 | Apple iPod nano
Locks & Locksmithing Logo
99 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
