Question about Kitchen Ranges
F&P 658EDS Multi function range,everything works except for clock,any ideas?
5 Suggested Answers
MicrowaveSvc
  • 9085 Answers
SOURCE: Maytag over the Range Microvave MMV5186AAS does not heat.
You have a bad secondary interlock (top door switch) or its mount is bad.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you only need a switch, you can order a universal type here for $5 postpaid.
Posted on Jan 01, 2009
  • 969 Answers
SOURCE: when I turned the range clock back to daylight
TRY PRESSING CLOCK SECOND TIME
Posted on Nov 12, 2009
miket756
  • 2702 Answers
SOURCE: Everything works except the microwave function
yes there are fuses inside it,,,but,,,there is also a lot of volts still in it too, "ie, 1000's" and they bite too,
bit like a police stun gun will,,but they may not just stun you,,they could very well kill you,, so be warned!
also the fuses are not the normal sizes you would have at home, and some of them are "slow blow" type and some are "fast blow" type,,, and one is at least 1 to 4 1000 volts type?
and my gess is a fuse has poped becouse the magnatron has given up the ghost and poped its clogs!!! like its dead! and a new magnatron would be dearer than a new microwave to have fitted,,
so,,,get a new unit,,dont tinker with it and stay alive!
Posted on Jun 06, 2010
BarrettDenCo
  • 1772 Answers
SOURCE: no fault errors the oven
Hello,Sorry to read about your problem
Their is a 80% chance you heat element is defective. and 10% your control knob is defective or a broken or worn wire.
I have tried to help you. Please help me by vote/rate the response. Thanks If you live in the Denver Area. I can help you out.
Posted on Jan 04, 2011
Testimonial: "wont know until I try the solution"
Clock does not display
time to have your clock replaced or repaired. Get the part number at appliancepartspros.com and check on rebuild options at corecentricsolutions.com, (usually half price or less than a new unit if even available.)
Aug 19, 2014 | Kitchen Ranges
Start button not working all other are
make sure proper electrical voltage and connections to machine.
Oct 10, 2009 | Whirlpool GY396 Electric Kitchen Range
11 yr old range/oven ; oven stopped working (clock is out and everything) : stove top is fine. Major expense ro fix ? Am I better off getting new one ?
your clock controls the oven functions. replace clock. probally a little cheaper than a new range but depends on service call fees and labor
Jun 22, 2009 | Kenmore 63792 Microwave Oven
Have GE JVM2050 over the range microwave, which stopped heating food and water since this morning. All other functions including light, key pad, clock, turntable work normal. The magnetron sound also
if everything works except the heating, it is most likely the mag tube is on its way out.........that is the most common reason for it not too cook.......since the microwave is a GE and it is 3.5 years old, i would say you are better off buying a new microwave, the mag tube starts at around $70.00 and up + the labor it costs too have a service person put it in........around another $60.00
May 02, 2009 | GE JVM2050 Microwave Oven
Cofee maker
Can I buy the coffee basket . It got thrown out with the paper filter. Do figure. I know it's old but it makes great coffee.
Mar 04, 2008 | Kitchen Ranges
970-686133 Bake and Broil Element not working
Typically what happens on on these models, when the bake element breaks, it sends a surge back to the oven control (or clock) and causes it to fail also. Sounds like this is what has happened here. If the overlay (touchpad) is a separate piece, you will need to buy it also. Let me know if you have any questions.
Feb 25, 2008 | Kenmore 95680 / 95681 / 95682 / 95684...
My clock stopped working on the display
The plug on your range may not be completely inserted into the outlet.
Clear all functions and see if the clock unfreezes
After all this, if the clock digits light up, and you still can't use any clock functions, it may be time for a new control panel.
Nov 27, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
