Question about Car Audio & Video
I need to obtain high level input terminal and power terminal connectors for rockford fosgate 3 sixty 1. Where can I pucrhase these? Thank you.
    Sergeant:
    Champion:
  • 253 Answers
At any radio installer shop or just go on line.
Posted on Jul 24, 2009
Bridging two12" subs and one 15" sub to my Rockford fosgate T 1500bd amp
assuming all 3 subs are 3-4 ohms, running all 3 in parallel (the 3 positive leads all attach to the amp positive terminal, and all 3 speaker negative leads connect to the amp negative terminal) will bring you at or above 1 ohm, which the amp is capable of handling. With 1500 watts, you will want to use 8 gague power leads for the amp, 12 gague speaker cables, and an inline 120 amp fuse between the amp and the battery, within 1 foot of the battery.
Jan 11, 2017 | Rockford Fosgate Car Audio & Video
High level input question
High level input is used when no RCA output are present on the head unit. You would wire the head unit speaker wires to the high level input.
Mar 18, 2014 | Rockford Fosgate Punch 301S Car Audio...
Hi i just got a ava1202 boss eq it didnt have instructions this eq has rca inputs and high level speaker inputs can i use this eq with out an amp can smeone plz help me thnk u
Yes you can use the equalizer without an amplifier. That is what the high level speaker inputs are for. You simply take the positive and negative from a speaker and hook it up to the positive and negative high level speaker inputs on the equalizer.
Jun 04, 2011 | Boss AVA-1404 7-Band Car Equalizer
Where is the power input cable on my x6 rockford fosgate amp
RF uses some pretty funky cases in order to hide the wiring.
usually a screw or 2 on the top will allow its removal and expose the wiring terminals
May 08, 2011 | Rockford Fosgate X6 Type RF 1-Channel...
How to connect amp to stock radio in a 2002 volvo. hi low input.
You can buy a decent hi to low crossover box from any stereo shop, peripheral makes em, so does rockford fosgate, even scoshe at walmart. The new rockford fosgate 3 sixty is pretty neat but I don't know the price.
May 30, 2010 | Car Audio & Video
Rockford Fosgate T15004 The Amp still powers up with the
Check you inputs to verify you have a signal coming in, if signal then check outputs try a speaker that you know is working and plug it in if that speaker plays then the subs/ or speaker wiring is bad, if it doens't play then you probably have a blown output transistor on the amp or possibly a terminal ground/positive has come loose on the inside..
Oct 27, 2009 | Rockford Fosgate T15004 Car Audio...
Rockford Fosgate Punch 301X not runing
You should verify some other way (with a multimeter or another amp/device) that your 12V is working at the amp. Then to troubleshoot the Remote wire, take a short lead of scrap wire and run it from the 12V power input of the amp over to the Remote input like a jumper. If the amp still doesn't power up, then look for and check the fuse on the amp. If there's good power at the amp, the remote input has good power, and the amp doesn't turn on, and the fuse isn't blown, then the amp is probably toast. Good luck!
Jun 17, 2009 | Rockford Fosgate Punch 301X Car Audio...
Not a problem just a question
  • 100 watts RMS x 2 at 4 ohms
  • 200 watts RMS x 2 at 2 ohms
  • 400 watts RMS x 1 at 4 ohms in bridged mode
  • stereo or bridged mono output
  • 4-ohm stable in bridged mode
  • Tri-Way capable
  • requires 8-gauge power and ground leads — wiring and hardware not included with amplifier
  • 50-250 Hz high-pass/low-pass (12 dB/octave) crossovers
  • wired remote included for fingertip control of Punch Bass (0-18 dB boost at 45 Hz)
  • MOSFET power supply and output devices
  • MEHSA mounting technology increases the heat transfer from the MOSFET output devices to the heat sink, for higher power output, lower operating temperatures, and greater reliability
  • TOPAZ — noise-killing differential inputs that eliminate 80% of ground loop noise
  • Trans•ana circuitry keeps preamp voltages low and signal paths simple for outstanding audio quality
  • NOMAD — advanced protection circuitry for "intelligent" shutdown protection
  • speaker- and preamp-level inputs
  • 11-1/8"W x 2-3/8"H x 9-7/8"D
  • Wire your sub in bridged mode (4 ohm mono)
    + to + on amplifier
    - to - on amplifier
    (using bridging terminals)
    Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
    Apr 25, 2009 | Rockford Fosgate Punch 401S Car Audio...
    Fosgate 201s amp, high level inputs... where do i hook these wires....
    Hello mhjoubert,
    On the Punch 201s, the high-level inputs are located just below the gain control. When used to power a sub, most commonly these are connected to the rear speaker wires of your receiver. If the amp is used to power a set of normal speakers, you would connect them to whichever set of speaker wires you intend to power.
    Actually, it's probably a better idea to install a low-level converter on the receiver speaker wires and then use the RCA connections for input. This way, you have better control on the input signal, lessen the possibility of induced noise, and do not need to worry about an impedance mismatch causing problems.
    You can download a copy of the Rockford-Fosgate manual here:
    http://www.rockfordfosgate.com/scripts/rightnow.cfg/php.exe/enduser/std_adp.php?p_sid=ZLxer3vj&p_lva=&p_faqid=303&p_created=1083264761&p_sp=cF9zcmNoPTEmcF9ncmlkc29ydD0mcF9yb3dfY250PTEmcF9zZWFyY2hfdGV4dD0yMDFzJnBfc2VhcmNoX3R5cGU9MyZwX3Byb2RfbHZsMT1_YW55fiZwX3Byb2RfbHZsMj1_YW55fiZwX2NhdF9sdmwxPX5hbnl_JnBfY2F0X2x2bDI9fmFueX4mcF9zb3J0X2J5PWRmbHQmcF9wYWdlPTE*&p_li=
    Hope this helps.
    Apr 11, 2009 | Stingpro ST444 1850 Watts Complete...
    Car Audio & Video Logo
    42 people viewed this question
    Top Car Audio & Video Experts
    xxxxxx xxx
    Are you a Car Audio and Video Expert? Answer questions, earn points and help others
