Question about Whirlpool Washing Machines
How to reset whirlpool duet dryer model WED9200SQ0
F01 code. Some say control board and some say thermal fuse. Any way to know before ordering new parts?
  • Official Brand Answer
  • 408 Answers
Hello, sorry that you are experiencing a problem. To reset the Dryer we would recommend unplugging the unit of turning off the breaker for 2-3 minutes. If this does not correct the issue we would recommend having a certified technician out to correctly diagnose the issue. If you would like further assistance you can send us your name, address, phone number, model/serial number and the date of which you purchased the appliance to Whirlpool_Reviews@Whirlpool.com. Thank you.
Posted on Apr 18, 2017
Whirlpool dryer duet quit during drying cycle everything lights up works is normal except it will not turn on when you push the start button it just makes a click sound in the back of the machine
Whirlpool Duet Dryer - turns on, clicks, won't run
you may need a technician if you are not savy with electrical testing but here is your route to fixing and by all means unplugg first
  • #1Alwckw4
    Premium Member Join Date Sep 2013 Location Florida Posts Whirlpool Duet Dryer - turns on, clicks, won't run
    Model Number: GEW9250PW1
    Brand: Whirlpool
    Age: 6-10 years
    My dryer turns on but when I click start, it simply clicks, but doesn't run. Any ideas would be greatly appreciated.
  • September 10th, 2013, 12:14 AM#2 Jake
    Appliance Tech - Admin Join Date Aug 2004 Location McMullen Valley, Arizona Posts
    Ok, lets first check your thermal fuse.
    You would need to take off the lower front access panel under your door, then take off the duct assembly#45, by removing the two #11 screws as shown in your parts diagram here: Bulkhead parts for Whirlpool GEW9250PW1
    Unplug or turn the breaker off to your dryer first before opening it up and ohm testing.
    Then you will need a multimeter to ohm your thermal fuse. Its #59 in that parts diagram, take both wires off the thermal fuse first.
    Here's the thermal fuse for your model you can order here if needed:
    Thermal Fuse WP3392519
    This video shows how to test it:
    Let us know what you find.
    If the thermal fuse tests good, We've had a few members report door switch problems.
    You can check it for continuity with a multimeter to make sure.
    Here's that door switch you can order:
    Door Switch WP8283288
    It shows on Page 4-6 in your repair manual I posted a link to below how to access it to check/change it. Make sure your dryer is unplugged!
    Push the button in on the door switch with one meter probe on COM and the other meter probe on NO and see if it reads. Normal ohms is 0-1.
    If the thermal fuse and door switch check fine, then its the control board.
    Here's the control board for your model you can order here:
    Main Control Board WP8546219
    I'm attaching the repair manual pdf for the Whirlpool Duet dryer below.
    It shows how to get access to the control board on page 4-2 through 4-4.
    Unplug or turn the breaker off to your dryer first.
    below is a link to the manual
https://www.applianceblog.com/mainforums/attachment.php?attachmentid=12424&d=1378793669
Feb 03, 2018 | Whirlpool Dryers
Whirlpool Duet dryer model WED9200SQ0 shows error code F01 what does this mean and how do i fix it
F01 is a main board fault...
https://youtu.be/n_e7CcpfCNk
If the main board is good then there is also a fuse which may have blown.
https://youtu.be/HGegabpM3jM
You will need a soldering iron... if you feel capable then proceed of find someone who is..
It's actually quite easy to do...
Apr 17, 2017 | Whirlpool Dryers
I am getting a F01 code on my whirlpool duet steam Dryer. MOD: WGD9600TWO
The F01 error indicates a primary failure of the control board. Try unplugging the dryer for a while (20-30 minutes); this will reset the control board if the problem was caused by a power surge. This will reset the internal breaker on the dryer. If the error recurs, the main control board needs to be replaced. However, you should inspect the wiring and the motor just to make sure that no other parts have been damaged by whatever caused the board failure.
If the model number of your dryer is WGD9600TW0, then the control unit is part w10141671. See http://www.searspartsdirect.com/part-number/w10141671/0026/110.html . Sometimes, you can repair the old control board by soldering a jumper wire (16 AWG) across a damaged solder connection for one of the relays. However, if you aren't careful, other parts on the board may be damaged beyond repair.
I hope this helps.
Jul 23, 2015 | Whirlpool Dryers
What is fault code F01 What does this code relate to?
either that or f51 is a thermal shutoff fuse issue
Aug 18, 2014 | Whirlpool Dryers
MAYTAG 3000 F01 CODE
It's probably a weak or failed component on the board. It's a common issue on those machines and the Whirlpool Duets. It's usually burned at the motor relay or heater relay.
F01 error code flashes when there is a primary control failure.
The only thing which will solve an F01 error code is a new machine control board. These is a catastrophic control board failure. Nothing can correct it. The part number you require is W10205977.
Dec 17, 2013 | Maytag Dryers
Error code F01 on Whirlpool Duet gas dryer
this is the main control board error,if you send the model number i can look it up for you.also have you tried unplugging it for like 15 to 30 minutes,i've seen the reset themselves just like rebooting your house computer.
Sep 21, 2013 | Whirlpool Dryers
I have a Whirlpool Duet dryer and it cut off and there is a flashing error code on the panel F01 and it will not respond to any of the buttons
F01 - There may be an internal problem with the control, attempt a Hard Reset.
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
The F01 generally indicates a failed electronic machine control board.
This error code can sometimes be caused by a glitch or power surge through the electrical lines.
You may be able to clear this code by unplugging the washer for 5 minutes.
If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
The procedure for accessing and replacing this control board is shown in this image...
http://media.fotki.com/1_p,wkwdftgtbkdgfrwxgtqsskgwtqkq,vi/ksrttqdqrxkssrqtgsd/1/1303472/5961857/image12917img-or.jpg
Be sure to unplug the washer before accessing internal components.
When you access the control board, I recommend transferring the wires from the old control board to the new replacement control board one connection at a time.
Once you have all of the wires transferred, remove the old control board and mount the new control board in the washer.
Reassemble and test the washer.
The "F01" error code indicates a communication error between the Central Control Unit (CCU) and the EEPROM onboard the CCU.
The "F01" can also be displayed if the onboard "Pump Driver" fails to activate.
Generally in order to correct this failure will require replacing the CCU.
There is no way to test and verify if the control board has failed.
The technical data sheet basically states to replace the CCU.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 07, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpool Duet Sport Model WFW8300SW00 stops after spin cycle
May 27, 2010 | Whirlpool WFW8300S
Washing Machines Logo
313 people viewed this question
Dan Webster
Dan Webster
Sal De
