Question about Elna Sewing Machines
How to changes the stitches on the Elna 3210 , I can't seem to change from straight stitch to over edge stitch
SOURCE: Sewing machine straight stitch is not straight
Hey. It's full out possible that you have it on the right setting...but concider this - the switcher inside the sewing machine could be broken (ie. It's moving to different stitches - but not the one you have the outside set for)
It happened to me (pc o crap singer model)
Posted on Jan 24, 2008
Trifect7
  • 57 Answers
SOURCE: How do I change the stiches?
You can do all of these stitches by using different combinations of your stitch selector, stitch width and stitch feed knobs, for instance, on the panel I can see on your machine:
http://www.jo-ann.com/joann/product/images/52659.jsp?CATID=cat3122&PRODID=prd11333
Stitches 1, 2 & 3 are straight stitches, centered, left and right. Really basic stuff, not different stitches at all. 4,5,6,7 & 8 are zig-zag stitches of different widths. 9 is the widest zig-zag (no. 8) on a finer stitch length, etc...
I think you should try and get an instruction manual for your machine. After a lengthy search of my usual manual sources, I've determined that that this may not be so easy. I think you should contact White on their 800 number and let them try and help you... 1-800-331-3164.
If you found this helpful, please vote generously as I receive nothing other than acknowledgement for my time.
Posted on Mar 08, 2008
  • 50 Answers
SOURCE: Elna 7000 - Mislaid manual. How do i use program B (letters)?
Hi jennymalibu! The best thing for you to do would be to download a new manual (free) from the Elnal site. It's in a .pdf format, so you need to have Adobe Acrobat Reader installed on your computer (also free at Adobe.com) Below is a link to your manual. Just click on it, or if it doesn't work, copy and paste it into your browser window. Good Luck! Hope this helps! Hal http://elna.us/files/File/service_manuals/7000_service_manual.pdf
Posted on Jun 10, 2009
  • 136 Answers
SOURCE: Elna machanical sewing machine
50 year old elnas made stitches by cams. look to see if the machine has a cam in it. you can see this by opening lid on top of machine. cams are black with red or white showing the pattern of the cam. could also have broken cam stack gear. That would require technician with elna experience
Posted on Jul 12, 2009
  • 46 Answers
SOURCE: only does zig zag stitches, no straight stitches,
make sure the pattern selector is set for straight stitch first. If it is set correct then the machine may be "stuck" is zig zag mode. May need to be de greased and then re lubricated.
Posted on Jul 27, 2009
Can u do normal straight stiching with ovetlocker model 686 elna?
No. A serger is not made to do straight stitching. However, you can accomplish the look of straight stitching as long as it is on the edge of fabric. The serger trims fabric from the edge and encloses the raw edge with thread.
If you want straight stitching, you need a sewing machine. Go to a sewing machine repair shop and ask if they have an inexpensive old mechanical sewing machine...like an old Singer, White, Necchi, Kenmore--the old metal kind.
Jun 20, 2017 | Sewing Machines
Set zig zag stitch on Elna Elina 40
I have looked but can't see a manual, but looks like push button stitch selection on front of machine, often it will be same as straight stitch, but need to take stitch width from 0 to 4
Feb 27, 2015 | Elna Sewing Machines
Elna 3210 raw-edge zig-zag stitch bunching
Zigzagging on the raw edge of a lightweight fabric will pull up, because the needle is swinging to the right side off the fabric, bet solution is to use the three step zigzag to overcast the raw edge, it looks like a zigzag mad of dots in the stitch icon. Dont know your model well, but its late model so should have this stitch.
Sep 26, 2014 | Elna 3210 Mechanical Sewing Machine
When zig-zagging on raw edge stitches bunch
Use a different stitch, use the triple zig zag or serpentine stitch so he needle is going through the fabric three or four times as it swings left to right.ma plain zigzag, because thread is tensioned, will pull lightweight fabric up. Try another raw edge finish, such as french seams, pinking shears or overcasting stitch. Of course for professional looking seams an overlocker (serger) is the answer as it has blades that trim the fabric edge and neaten with 2, 3 or 4 thread seam, encasing the raw edge.
Raw edge zig zag stitch bunching underneath
When zig zagging over a raw edge, the tension on the thread will pull in the fabric, especially in lightweight cottons or even lighter organza. Its not the best edging method for very light weight fabrics. You can try using a smaller zig zag, loosening off the top tension a little bit. Or if your machine has it, use the triple zig zag or serpentine stitch, where the needle goes through the fabric three times to make up each zig stitch, this stitch is better for edging most fabrics and is my preferred stitch.
I have an Elna 3210 and my feed dog won't raise anymore. How do I fix this?
When you drop the feed dogs they drop instantly. When you raise them it takes 1-2 stitches for them to com back up. Move the switch on the back to the up position and sew a couple of stitches.
Jun 07, 2014 | Elna 3210 Mechanical Sewing Machine
I've got an Elna 634 overlocker, and want to turn
Just trim the fabric to the desired hem length plus one inch, then overlock around this raw edge with thread close colour match to the fabric.
You then have the choice of either stitching around with a stretch stitch on your sewing machine, or hand sewing.
Being lycra shouldn't change how you hem them unless the trouser leg is extremely close fitting and the hem seam is going to be under tension.
My first choice would be using a twin needle in straight stitch from top side but this finish can pop/break if the hem is under tension. But perfect for most knit hems.
If you hand sew then you can turn up hem allowance and put a length of fusible hemming web inside the hem allowance and press it to hold. Then do a back stitch hand sew around to hold hem in place.
If you sew with the regular sewing machine, then use either the stretch stitch or a very small zig zag, and a ball point or stretch needle.
On ready to wear you would see a coverstitch hem but your overlocker doens't have this stitch.
Jun 12, 2011 | Elna Sewing Machines
Jul 05, 2008 | Elna 2007 Mechanical Sewing Machine
Sewing Machines Logo
26 people viewed this question
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
