Question about Autopage Vehicle Parts & Accessories
Autopage RS-600 on Chervolet express 2005 the car works fine with key, turn on and of with no problem, but when I try to turn on with remote transmitter starts and stop with security light pulsing,
    Master:
  • 604 Answers
You cant use a remote starter with that car,you cant program the security feature to start without a key.
Posted on Apr 18, 2017
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
  • 373 Answers
SOURCE: 2005 ford taurus. Remote entry wont work theft light keeps blinking when key is engaged
HI, I'm reading your problem,
Let me explain something about your car.
2005 Ford Taurus, The key on that car has Chip inside of the key and receiver on the ignition switch,
Check if the key you are trying to use is Black and has a plastic head.
If not you need a key with that characteristics.
But if you have the right key, Remenber if you had drop on the floor, or hit with something,
Because some times they come damaged, with insignificat thins.
Remenber if you left the key close to a magnets like speakers.
If nothing aply at your case, you need to call a place Aloha Smith, they have the computer to program or reprogarm your key. IF not you can't start your car.
OK.. I hope this information work for you.
Thank's for submit yous question on fixya.com
Posted on Jul 10, 2008
SOURCE: no power to transmitter rs 110
it powers only when there is sound input
Posted on Aug 01, 2008
SOURCE: my keyless remote doesn't work...whenever
I disconnected the battery then hook it back up and all was okay again, that simple!!
I wonder what they would of charged me for that at the dealer?
Posted on Sep 09, 2008
jwyatt816
  • 3 Answers
SOURCE: 2001 Cadillac Deville Security System
Check engine to chassis ground I had same prob
Posted on Oct 03, 2008
doin12volt
  • 233 Answers
SOURCE: car starter not working
look under the dash for a small silver toggle switch....this is a disable switch for the remote start portion of the system..you may have kicked it / bumped it with your foot, causing the remote start portion to be deactivated. Just flip the switch the opposite way and try again..
Also, there may have been a pin style switch installed under the hood...Check to see if it is bent or broken, if it is, simply disconnect it and insulate the wire that was going to it.
This wire is used as a safety to keep the vehicle from remote starting while the hood is up..to keep people from being injured if the remote start is activated while the engine is being worked on.
Have whatever shop installed the system replace your pinswitch if that is the problem.
Posted on Dec 19, 2008
Does anyone have an installation manual for an Autopage RS-610 Plus? I need to program a new remote.
Note: This system can keep up to 4 remote transmitter in its memory. If
more than 4 transmitters programmed, the system will keep only the last
4 transmitters.
PROGRAMMING THE REMOTE TRANSMITTER
Enter:
1. Turn the Ignition 'switch 'OFF/ON' 3 TIMES and stay in the 'ON'
position. Within 15 seconds.
2. Push the Valet switch 2 times (Holding in on the 2nd push) until you
hear a long chirp. The transmitter is ready to program.
Program:
1. Press any button on transmitter until the siren responds with a
confirming chirp the first transmitter is now programmed.
2. Press button on the second transmitter until the siren responds with a
confirming chirp, the second transmitter is now programmed.
3. Apply the same procedure to program 3rd and 4th .
Exit: Turn Ignition to 'OFF' position, or leave it for 15 seconds. A 3 long
chirps & 3 parking light flashes to confirm exit.
Apr 12, 2017 | Autopage Vehicle Parts & Accessories
I have an autopage remote starter that worked just fine until I replaced the battery in my vehicle. The remote still works, everything still works except it runs for about a minute, shuts off, restarts,...
sounds like security system is keeping it from running. try this. disconnect the battery again. lock the drivers door with the key. reconnect battery, unlock drivers door with the key and try and start the car with the key. does this work?? ok now shut car off and lock it and try remote starter. hope it works it just might
Dec 03, 2017 | Cars & Trucks
RS 915 says ot of range
the antenna could be loose either on the transmitter from your vehicle or the antenna on your remote.
Mar 21, 2014 | C3RS915 SST Remote Car Start Vehicle...
My autopage rs 727 lcd is not starting in remote start, it is only cranking
what kind of vehicle? it is most likely a transponder or theft system bypass problem, since it is trying to crank.
Feb 12, 2011 | C3RS727LCD 4Channel Alarm with Remote Car...
I need the manual to tell me how to activate Autopage XT-42 LCD remote starter
The Autopage XT-42LCD is used to operate two systems, the RF-420LCD and RS-622. Since you state that you need to activate a remote start that narrows it down to the RS-622. You can download the manual for this unit at the following link:
http://www.autopageusa.com/resources/RS622operationManual.pdf
Jan 21, 2011 | Viking - VT73 - 4 Button Random Code Mini...
I have the normal alarm Autopage AutoPage C3RS603
Nothing is hard to hookup just time consuming andf it all depends on how good you R with wiring how good R you..?
Jul 16, 2010 | C3RS603 2Channel Remote Start Module with...
Vehicle Parts & Accessories Logo
49 people viewed this question
Top Autopage Vehicle Parts & Accessories Experts
John
John
Charles Osborn
Are you an Autopage Vehicle Part and Accessory Expert? Answer questions, earn points and help others
