Question about Tablets & eReaders
My hp3025a says it can't find my phones or tablet to print wirelessly. How do I reset it?
How do I print off a Sd card, from my tablet?
Hello, Glenn -
First you need a WiFi printer.
Then, you need to have the printer driver software installed on your tablet.
Then, follow these steps:
-- Open the file you'd like to print
-- Tap the menu button in the top right of your screen
-- Tap Print
-- Tap the drop-down arrow.
-- Tap the printer you'd like to print from
-- Tap the print button
Best wishes.
Jan 08, 2018 | Tablets & eReaders
What brand wireless printer do i need for my samsung galexy tablet
Any brand wireless printer will work. The trick is getting the tablet to see it. I recommend setting your printer up as a Google Cloud Printer and printing from inside of google docs. If you are looking to print pictures from your tablet then just make sure the printer you are looking at has an Android app that will allow it to communicate with the tablet.
Dec 20, 2017 | Samsung Tablets & eReaders
Can a Brother MFC-470 DW used with this tablet it is wireless?
Yes. You can print from your tablet but first you have to make sure that your printer is connected wireless to your network, then on your tablet when you go to print something, choose the network printer.
Jan 11, 2016 | Tablets & eReaders
How do I clean my samsung galaxy tablet
You can try to delete unnecessary files go to Settings, select Apps then click on Program.Select the apps that you want then click Uninstall. To stop unnecessary programs running in your phones background go to Setting, choose Apps. Select Running then click on the program you want to stop then select Stop. Restart your phone. If you experience the same thing then you might need to reformat your mobile. Before you do the soft reset on your mobile be sure that you have a back up copy of your personal files because it will be deleted after the reset. Be sure also to fully charge your device. To soft reset your phone go to Settings. Select Privacy then choose Factory Data Reset then choose Reset Phone then click Reset Everything.
Dec 27, 2014 | Samsung Galaxy Tab 101 Tablet...
Cant get wi fi signal.
Solution 1.Check wireless connection.
The first step of diagnosis have to any other device connected to the same network, ensure the wireless connection is working fine, or verify the settings of your wireless router to correct it.
2.Check your Keep Wi-Fi on during sleep Settings.
Owing to Wi-Fi sleep policy your Wi-Fi connection may be going to get disconnected every now and then.
Tweak this policy to keep your Wi-Fi connection awake.
[Settings] >>[Wi-Fi]>>[Advanced]>> Check [Always] to keep the Wi-Fi on during sleep.
Save changes and exit all the screens. Your Wi-Fi will never get disconnected again due to this policy.
3.Check signal strength of wireless connection.
The performance of a wireless network connection depends in part on signal strength.
You have to connect the Wireless network where the signal strength is strong.
Check Wireless network signal strength icons in notification bar.
4.Try to turn off/on Wi-Fi on the device.
First to turn off Wi-Fi, [Settings]>>[Wi-Fi] >>[turn Wi-Fi to off].
And then to turn on Wi-Fi, [Settings]>>[Wi-Fi]>>[turn Wi-Fi to on].
5.Try to forget network on the device.
Forgetting wireless networks allow your tablet/phone to reset some settings.
[Settings]>>[Wi-Fi]>>Press & hold your[Net Work Name(SSID)]for 2 seconds.
>>Select[Forget Network]>>Re-Connect your wireless networks if it's disconnected.
6.Try to reboot your device.
7.Make sure your firmware is up-to-date.
>>Select[Settings]>>[About tablet]>>[System Firmware Update]>>[Check Update].
8.Try to reset your device.
Note: once RESET was performed, all data, apps, settings and personal information will be deleted after initialization.
Third-party programs might be the major probability of Tablet/Phone instable, suggested to have a full reset for the device if the situation persists.
[Settings]>>[Backup&reset]>>[Factory data reset]
9.Try to other wireless connections.
If steps above were not able to solve internet connection problem still, please try other wireless connections if available, otherwise contact your networking provider to technical support.
Oct 09, 2014 | Worryfree Gadgets 7inch Zeepad 7.0 Android...
How do I print from my ipad to konicaminolta MC 1690 printer
You will have to set up wireless printing from your iPad, but also your printer has to be able to print wireless aswell
Sep 03, 2014 | Apple iPad (16 GB) WiFi Tablet PC
I have this tablet and I have this HP E print app, but I still can't get anything to print on my printer. It hasn't searched or found my printer. I have a hp photosmart d110 wireless.
I assume it's an Android tablet. Try downloading and installing printershare, at <https://play.google.com/store/apps/details?id=com.dynamixsoftware.printershare>. Good luck!
May 30, 2014 | ASUS Eee Pad Transformer TF101A1 Tablet...
How can I print pages from the screen
Get the HP reprint app. Or other apps for printing wireless from tablet. You need a wireless printer to print from a wireless tablet.
Apr 09, 2014 | Mach Speed Trio Stealth G2 Tablet -...
My screen is froze?
Hold down the power button for about 20 seconds, this should hard reset the phone/tablet.
Nov 18, 2013 | Polaroid PMID1000B ARM Cortex-A8 1GHz...
Tablets & eReaders Logo
27 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
