Question about Home
How to replace shower tap in jay or 2006 Westport caravan
2 Suggested Answers
gary1121
  • 332 Answers
SOURCE: no stop tap. cold water coming through cold taps
your pipes are clogged, what if you were to not turn on the cold and turn on the hot does any water come out at all, with just the hot side turned on,, if not there could be a valve that has been turned off, or the pipes are clogged
Posted on Jun 24, 2009
Water temperature has reduced even on maximum setting
check tap had a shower myself that would start hot then 3 minutes later hot was cold! then hot after 5 minutes.
I turned off main tap on meter, Undid tap fitting on shower found the washer was worn but also the tap fitting was seized could not turn it for full movement. You could soak the tap screw fitting in CLR and pull apart and use a tap grease on the screw thread or just buy another tap fitting. I discovered most of my tap fittings had calcium build up in them. But I replaced the shower tap valve thingy as it was really seized up.
Nov 22, 2015 | Home
Vanquish shower goes hot and cold sometimes
Are the pressure ballance taps? If the shower is on and someone flushes the toilet the water will get hot in the shower,if they are not pressure ballance taps,or if they are the cartridge needs to be replaced in the tap.
Apr 18, 2013 | Home
2006 Dodge Caravan engine will not turn over
i know you have checked everything .chech 1solinoid on top of starter.2netural wire from battery to starter.if this fails check small red wire from ign to solinoid.[small].adrian,,,
Jul 26, 2010 | 2006 Dodge Grand Caravan
2006 3.8 dodge grand caravan is not getting gas. fuel pump and egr valve have been replaced. after the fuel pump was replaced it worked for 4 days until i was sitting on an upgrade (hill) at a stop light...
You have a fuel pump relay that sends power to the fuel pump. Do you hear the fuel pump turn on when you start the van? If not then check the relay. sometimes you can have someone tap the top of the relay while the key is being turned. If it starts then change the relay. about 10$ from rockauto.com.
May 25, 2010 | 2006 Dodge Grand Caravan
The shower no longer cuts off completely leaving a constant drip from the shower head. I disassembled the valve body and discovered an unusual plastic split plate gate valve system inside. It appears to...
If the Shower or any tap keeps dripping then its from were the cut off of water comes from and if 2 taps then its either the seal and the seat needs recutting so the answer is to get the plumber out to recut the seat
If a mixer tap then you will have to get a replacement unit.....sorry
Sep 24, 2009 | Home
SHower noise
Loose washer in hot or cold tap. Replace or tighten.
Sep 10, 2009 | Water Pik Shower Head
No cold water from bathroom tap
Sounds like you need to replace your shower valve, especially if this is the only fixture in the house being affected. You could try to replace the cold water cartridge first. Hope this helps
Jul 06, 2009 | American Terminal Etc B 100 T Taps
Caravan water heater not letting hot water through
pipes are rusted and cloggen from the inside of them
Jun 17, 2009 | Sport & Outdoor - Others
No stop tap. cold water coming through cold taps in caravan but no hot water the carver cascade water heater is getting the water hot but it just wont come through the taps in the shower room or kitchen in...
Jun 17, 2009 | Reliance & 40 Gal Mobile Home Water Heater...
Home Logo
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
