Question about Miele Dishwashers
I have a miele model g5220 dishwasher. The door will not stay open. how do i adjust the spring tension?
  • 209 Answers
SOURCE: Door Tension
just about the most difficult job to do on a dishwasher, not normally a job for the home mechanic, i am an appliance engineer of 20 years and often shy away from jobs like this,
there is often no adjustment, the hinges are sprained, more often that not by people either putting weight on the door to stand back up, or children climbing on to get higher
the only thing i think you can do is to check the springs are in place and nothing is broken or just come off that can be put back?? sorry
Posted on Oct 15, 2007
SOURCE: Dishwasher detergent door spring
I ordered and received the new Bosch dishwasher detergent door, but do not know how to repalce it!
Posted on May 15, 2008
aborcass
  • 2651 Answers
SOURCE: Door Tension Adjustment on Electrolux Dishwasher
you should be able to remove the lower acess panel, and the tension springs are on both sides, cant really picture how to adjust tension( font or back), but there should be enough room to get a flashlight and you hands under there to make the adjustment
Posted on Oct 26, 2008
  • 177 Answers
SOURCE: the door on my miele G481 built in dishwasher won'...
hi,
what you need to do is slack off the spring tension on the door hinges. each side of the unit at the base on the plinth there is a screw with a spring symbol next to it. turn this anti clockwise to reduce the spring tension.
Hope this helps
Posted on May 24, 2010
  • 177 Answers
SOURCE: 23 in. Novotronic G841 Built-In Dishwasher: the door on my miele G481 built in dishwasher won'...
hi,
you need to adjust the door tension springs which is by a screw each side of the hinges on the plinth of the unit at the front. There is a symbol of a spring to show you which screws to release. do them evenly and the door will not spring up,
Posted on Jun 13, 2010
How do I fix or replace the door spring in a Miele G6892 dishwasher?
Step 1: Get Access to the Door Spring Remove the lower panel under the door. Normally, two screws keep the panel in place. These screws are located on top of or below the panel. There are cases wherein you have to initially open the dishwasher door to be able to remove the screws. The door should then be closed in order to remove the panel.
Step 2: Remove Springs To remove the springs, the hook of the spring should be lifted from the anchor point. Use your fingers to do so. If there is a large amount of tension, it's best to use a screwdriver or pliars. Position the shaft under the hook and then pull it down. After pulling down, try lifting the anchor. To make things easier, try locating a leverage point. This should help the screwdriver force the spring out. Be certain to remove the spring from all of its anchor points.
Step 3: Installation of New Springs To install a new spring, you initially have to deal with the positioning of the lower spring hook. It should be placed within the first hole. Take note of the adjustment bracket when doing this. Follow the previous set up. If the spring needs more tension, try positioning the spring hook further towards the back of the adjustment bracket. The end of the spring for the counter balance of the door should be mounted on the door support. Find the slot on the support. Replace all covers and door panels. Test the door to check for any problems.
Jul 16, 2016 | Miele Dishwashers
How do you adjust the door spring on a miele dishwasher?
there are two screws behind the kick plate - one for the right side on fro the left - the screw have a little - and + above them to show which way to turn to increase or decrease the tension
Aug 10, 2014 | Miele G6100SCI 598 mm Clean Steel Built-In...
Miele dishwasher door not working properly
Try contacting Miele with the model & serial number of your appliance they will send you out a new spring.
they are in scoresby from memory fern tree gully rd.
Mar 29, 2014 | Miele Dishwashers
I've just installed a Miele 5500SCU Dishwasher and the springs that support the door cant be adjusted far enough to take the weight of the door, does anyone have any suggestions?
If the dishwasher is brand new, then there is an issue with the configuration of the springs, i.e not mounted correctly. A factory dishwasher door should not need to be adjusted. However if it is older, it is possible that the springs came off, in which case they can be seen from the underside of the dishwasher and by a panel that unscrews on the bottom of the door. Make sure the springs are there.
Dec 30, 2012 | Miele Dishwashers
G660 door falls open
Hi.
The problem is either because the spring supporting the door half way up is broken or because the spring must be adjusted.
First perform a door spring adjustment procedure as explained at page 28 in chapter 10 of the Installation Manual.
Here Miele installation manual for the G660. The file is in PDF format.
If the regulation procedure does not do the job, then the spring must be replaced.
This video shows how to replace the spring (model and manufacturer are different-operations are similar):
The spring is usually sold as part of the hinge assembly.
To get parts or to book a qualified technician call the Miele support number listed on the owners manual or use the Contact page on your local Miele website. Here UK website: Miele - Contact Us.
Regards.
Ginko
Nov 05, 2011 | Miele 24 in. G638 Plus Free-standing...
The door on my miele G481 built in dishwasher won't stay open it's really annoying that it keeps popping up when I'm trying to load.
hi,
Hope this helps
May 21, 2010 | Miele 23 in. Novotronic G841 Built-In...
hi,
May 18, 2010 | Miele 23 in. Novotronic G841 Built-In...
Door does not stay horizontal when opened. How do I adjust the door springs?
Hello Slosh,
The are four torx screws (Two on each side) of the door panel near the bottom. The top screw controls tension and the bottom allows you to position the door. Be careful when loosening the panel as the screws will come out completely and then you will need to remove the outer door panel and reattach the door springs
Sep 15, 2009 | Miele 24 in. G638 Plus Free-standing...
Adjusting the door on a neff dishwasher
I have the same problem with my newly installed Miele integrated dishwasher. The door does not stay open when you are trying to load dishes. I heard that there is an adjustable internal mechanism to adjust the tension on the door. But, I am still working on solving my problem.
Mar 16, 2008 | Neff 18 in. S5943 Slim-Line Built-in...
Dishwashers Logo
26 people viewed this question
Top Miele Dishwashers Experts
Mike
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
