Question about Home Security
How to install a utiliech motion activated light 0458903
It is put up all the wires are in and yet the light will not turn on the red light on the motion sensor is working
SOURCE: Motion Light doesn't work on switch
it sounds like you may have the switch and the motion sensor wired is series , in which case the motion sensor will only function if the switch is in the on position and give you no way to keep the light in a constant on position. if you where to wire the sensor in parallel with the switch the switch would act as a bypass to the sensor , which sounds to me like what you are trying to achieve .
Posted on Mar 17, 2009
  • 188 Answers
SOURCE: Have Cooper lighting outdoor motion detected flood
Sounds like the relay in motion sensor. Change the bulb. Rechargeable batteries are no good after 3-4 years also.
Posted on Jul 23, 2009
  • 188 Answers
SOURCE: The motion sensor part of the light has three
Motion sensor will not be powered from 120vac directly. They usually run on 6-12vdc.
Posted on Aug 08, 2009
  • 250 Answers
SOURCE: need to wire motion sensor to light, have three
The black wire goes with the black house supply wire, and the red wire goes with the black wire from the lighting fixture. The white wires all connect together.
Posted on Feb 22, 2010
SOURCE: I installed the motion sensor
Leviton manuals:
http://www.leviton.com/OA_HTML/ibeCCtpSctDspRte.jsp?section=17219&minisite=10022
A quick peek inside a sample Leviton manual confirms that your wires are connect correct - BUT...
http://waterheatertimer.org/pdf/Leviton-motion-Instructions.pdf
The remaining 3-way switch needs a jumper wire.
See if your instruction manual shows the same thing as image below.
Let's go through this.
The yellow wire connects to a traveler ... and that traveler connects to one of the brass screws on 3-way switch.
The black wire from Motion sensor also connects to a traveler wire ... BUT you have to identify which traveler wire and which brass screw that traveler wire connects to. And then, put a jumper wire (a short piece of wire) from that brass screw to the dark-colored screw.
I think that will do it.
Add a comment if your device is different.
Some of these electronic devices are reversed when two of their wires are connected together.
That's what the jumper wire is doing. So the 3-way switch is just connecting and disconnecting the black and yellow wires, and that action reverses the circuit in the motion device.
Posted on Nov 23, 2010
Just installed a motion activated light (model 021746). The light will not turn off; there is no switch.
in the installation notes , it probably reads to this effect
to run the light all the time --switch of power supply and switch on
to run a light sensor - turn the power off , back on back off back on
one action changes the internal program to leaving the light on , the other activates the sensor mode
the switch is the light switch that controls power to the unit
Oct 26, 2016 | Home Security
My flood lights have a manual function so that I can wire a light switch to them and use them with switch as well as a motion detector. However the users manual does not provide instructions or diagra
you need to either break the circuit going to the light, so find the wire that powers the light & cut it where you want the switch, then join the black wires together & put the reds in each end of the switch.
or the way you asked about, which will depend on what your light has in the of terminals in the conection box.
ill do you a drawing..........
flood-lights-manual-function-wire-light-kh0zpbanw2f22f2jnqn4pytl-4-0.jpg so take the red out of its terminal in the back of the light, put it in its own conector or a spare one thats already in the light, might be labeled (manual function) then run one 2 core/ twin & earth wire to where you want your switch to be, & then wire it up like the picture, red in com black in either l1 or l2..
go back to the light & take the red of your new wire & put it in the same terminal as the one i just told you to take out, then put the black from your new wire & put it where the red wire was to start with.
your live could be either red or brown depends on the cable used.
check your swith aswell b4 screwing it to the back box, to make sure you put it the right way up,nothing more anoying than an upside down switch.......lol
good luck!
Sep 26, 2014 | Defiant Flood Lights. 180 Degree Outdoor...
Flood Lights. 180 Degree Motion Activated Solar Powered Floodlight -
Sounds like the batteries are not getting charged. Check to see if there was some packing material in place to keep the batteries disconnected for shipping.
Dec 05, 2013 | Cooper Lighting Flood Lights. 180 Degree...
We have a motion sensored light with two lights and the motion box. 1 black wire and one white per light but the middle has 1 black, 1 white and 1 red. We are hooking it to the porch light and dont know...
You are replacing porch light with light fixture with motion sensor device.
Each light has 1 black and 1 white wire.
The motion sensor has 1 black 1 red 1 white:
Copy following link for motions sensor wiring illustration:
http://waterheatertimer.org/How-to-wire-switches.html#motion
Oct 17, 2012 | Hardware & Accessories
Motion sensor light not tripping off
If new, then it could be faulty. If old, then may have water damage.
POSSIBLE CAUSE
1. Light switch is turned off.
2. Flood lamp is loose or burned out.
3. Fuse is blown or circuit breaker is turned off.
4. Daylight turn-off is in effect.
5. Incorrect circuit wiring, if this is a new installation.
6. Light control aimed in wrong direction.
SOLUTION
1. Turn light switch on.
2. Check flood lamp and replace if burned out.
3. Replace fuse or turn circuit breaker on.
4. Recheck after dark.
5. Verify wiring is correct.
6. Re-aim light control to cover desired area.
Sep 04, 2011 | Heath Zenith Secure Home Motion Activated...
I installed the motion sensor on a 3way switch. Connected the red lead to the common and the yellow w/red strip lead to a traveler and the black lead to the other traveler. No matter how i switch the...
Leviton manuals:
Nov 23, 2010 | Leviton R01-PR180-1LI Decora 180 Degree...
Jul 18, 2009 | Desa International 240 Deg. White Twin 150...
Dual Master Wiring
hzsupport.com shows the wiring diagram, the red wires go together.
May 13, 2009 | Electronics - Others
Try turning the switch on and off and back on again this usually will bypass the motion detector. when you are finished you can turn the switch off for a few seconds and back on and it will resume its normal function
tom
Dec 11, 2008 | Electrical Supplies
Home Security Logo
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
