Question about Koss Audio Players & Recorders
My Koss CDR200 stops recording after about 15 or 20 minutes. Not sure why, or how to prevent this.
I'm importing music from an external source (tape player) into the Koss unit, but after maybe 3 songs (15-20 minutes) the Koss unit turns off. I can only figure that it might be due to an extended period of silence between songs, but this is frustrating and I don't know how to correct it, nor do I know this is actually the reason why.
SOURCE: KOSS CDR200
can I record from an outside source, like a casset player to cd, on the cdr200, if so, how, thankyou
Posted on Jan 09, 2008
  • 112 Answers
SOURCE: koss cdr200 dual burner
I had an issue similar to this - I found if I didn't try to record from the internal player it worked ok. Does it say 'recover' when you try to record anytime? If you open the unit,you might see some capacitors on the power supply on the left hand side have leakedand the power is cutting in and out. 'Recover' usually comes up when a recording is interupted if you switch the unit off during recording.
Posted on Jan 15, 2008
  • 112 Answers
SOURCE: Recording
Willthe b deck playback a normal cd? Sounds like your record laser is gone. It's a philips laser and they are known for it.
Posted on Jan 24, 2008
  • 329 Answers
SOURCE: Brother ML100 Lift-Off Correction Tape won't lift off
Correction tapes DO have a shelf life, Also make sure the ribbon is moving and very important and this may sound dumb, but I have seen it that the ribbon is not a correction ribon. Are the spool turns orange or yellow? should be. Blue is multistrike and will not correct. Don't know the shelf life of ribbons but they do loose the ability to correct.....Good luck try new supplies..
Posted on Aug 05, 2008
ginko
  • 19396 Answers
SOURCE: koss cdr200
Manual is not available for free download.
If you have the product code enter it here:Download Manuals
Or contact Koss: Contact PAGE
Posted on Dec 03, 2008
I have this 2-Disc CD Recorder but I don't have the manual on how to hook it up to my recevier. I'm not sure if I'm to hook it up to the Analog or to the Coaxial Digital. I did try to hook it...
No problem,You need to connect "CD" to" Receiver" in a regular way just to play ..
(output of CD-TO- input of Receiver) ..use either "RCA analog (red/white ) " or "optic " cable.(any standard optical cable )...optic is the best way to connect it..Remember your CD's "OUT" goes into" IN "
pls also remember,wherever you connect your CD on your Receiver,you should switch the source selector accordingly to correspond to the connection on the back...
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
Jun 30, 2011 | Koss CDR200 2-Disc CD Recorder
Can I record from a cassette player to the koss
should be able to go directly from tape out of cass deck to input of your koss, as long it has line level inputs (which it should). from there its play on the tape and record on the cd rcrdr. seems the simplest solution
Jan 30, 2010 | Koss CDR200 2-Disc CD Recorder
KOSS CDR 200 RECORDING
Yes, but you, like I could use an owners manual for this thing, as it isn't as easy to operate as the Philips Audio CD recorders. Owner's manual anyone?
You can just press input select for analog, press record, wait then press 'play' to start recording.
Aug 04, 2009 | Koss CDR200 2-Disc CD Recorder
Recording
Jan 23, 2008 | Koss CDR200 2-Disc CD Recorder
Cdr200 recording
Your CD recorder has 2 sets of phono (rca) sockets on the back. You probably have the outputs connected to your amplifier & speakers. All you need to do is connect your tape deck (or any source except for a turntable) to the inputs sockets on the back of the CD deck.
You might need to switch to external or analogue recording on the recorder.
If you are going to be doing a lot of this type of recording & want it set up more permanently, it might make sense to reconfigure your hi-fi. Shout if you want help with this!
Jan 09, 2008 | Koss CDR200 2-Disc CD Recorder
KOSS CDR200
Nov 25, 2007 | Koss CDR200 2-Disc CD Recorder
Recording
It will record any line level source (CD, MD, tape, tuner). You can only record vinyl records if you have a phono pre-amp.
The best way to use a CD recorder is to use the "tape loop" on your amp/receiver. Does your amp/receiver have a "tape in" and a "tape out"? If it does you should connect your CD recorder to these in/outputs. That way, whatever your amp or receiver is set to listen to, is what you'll be recording.
Shout if you need more help!
Sep 13, 2007 | Koss CDR200 2-Disc CD Recorder
Koss cdr200 dual burner
Aug 28, 2007 | Koss CDR200 2-Disc CD Recorder
29 people viewed this question
Top Koss Audio Players & Recorders Experts
Steven Wander
Steven Wander
Carlos L. Burgos
Carlos L. Burgos
Michael Galve
Michael Galve
Are you a Koss Audio Player and Recorder Expert? Answer questions, earn points and help others
