Question about Home
Ridgeway Mdl 149 movement E, keeps stopping, moved but took right precautions, does clock have a verge does it have to be adjusted and how do we do that, can you advise?
2 Suggested Answers
  • 36498 Answers
SOURCE: Ridgeway MDL 149 movement E keeps stopping moved but took right precautions does clock have a verge does it have to be adjusted and is there a video giving info?
Check YouTube for something similar
Posted on Apr 22, 2017
My Howard Miller Grandfather floor clock 610-808 chimes constantly
Hello Shirley Haas,
Leave the weight fully extended (stop the clock)
and start checking your local area for clock-smith
that make house calls (run on hour strikes are much more common... but whatever you say... "CHIMES" the cause
is likely the same: Little or no maintenance).
http://www.ebay.com/itm/Howard-Miller-Grandfather-Clock-Movement-with-Dial-Model-610-309-serviced-/282379781809?hash=item41bf2586b1:g:UO4AAOSwMmBVjdo-
These clocks need to be lubed and serviced and it is work
best left to the serious professionals.
You can probably get away with another 35 years...
Remember we have time on our side...
As for me...
I bought a junk clock to EXAMINE & fix (did)
I purchased synthetic clock oil (LIBERTY noted below)
and lubed ALL the obvious spots...
wiping excess away with Q-Tips.
Then I assaulted my own RIDGEWAY...
Got it running & regulated (was NOT my problem)...
My pendulum only needed to be centered correctly
(oh well).
I could NOT pull up YOUR 610-808 movement... but on the movements I have done you can see the hour strikes & the lever that triggers that motion (HOURS are each a spike on
the gear wheel... from one (^), 2 (^^) to 12 (^^^^^^^^^^^^)
progressively (pretty obvious if you are looking).
Go there... look... lube..!! Be gentle... VERY GENTLE...
or better ... call in a QUALIFIED SERVICE PERSON.
Carnac the Magnificent
Mar 24, 2017 | Home
I purchased a Howard Miller grandfather clock and the clock is keeping time but pendulum is barely moving. What's the problem?
Hi Pam,
I have a Howard Miller Grandfather clock and the pendulum swings very slowly and from far left to far right travels only about three inches at best. It doesn't need to move any more than that to make the "Verge" move the "Escape Wheel" to rotate the gears to keep the hands moving at the correct tick.
Howard Miller Grandfather Clock
Dec 06, 2016 | The Watches
I purchased an older Howard Miller clock and the clock is keeping time but pendulum is barely moving. What do I do?
Hi Pam,
I have a Howard Miller Grandfather clock and the pendulum swings very slowly and from far left to far right travels only about three inches at best. It doesn't need to move any more than that to make the "Verge" move the "Escape Wheel" to rotate the gears to keep the hands moving at the correct tick. Howard Miller Grandfather Clock
Dec 06, 2016 | Home
Where can I get information and pendulum for Ridgeway spring driven clock serial number 374221?
You need to determine what type of movement it is first. Ridgeway used movements from Hermle and other manufacturers. Once you have identified the movement we can sort out the pendulum. The following article will show you how to determine the pendulum length: How To Determine Clocks Pendulum Length
Tim
UsedClockParts.com
May 03, 2016 | Home
It wont chime on the hour
Basic assumption... The chimes know what time it is...!!
FORCE NOTHING...!!
From page 10 of owners manual below (MINUTES):
EXAMPLE: Clock chimes at 1:10 but should chime at 1:15.
Step 1: When clock chimes at 1:10 stop the pendulum and record the time of 1:10.
Step 2: Carefully remove the small nut....
(Hour procedure is on the SAME PAGE (10).
WARRANTY INSTRUCTION MANUALS
Apr 19, 2016 | RIDGEWAY GRANDFATHER CLOCKS Ridgeway...
I need parts for my seth thomas westminister ave marie clock I need the swinging mechanism the clock is a mantel clock, the bar and head is missing a parts list would help
Howard Miller Clock Parts ' eBay
www.ebay.com/bhp/howard-miller-clock-parts
eBayHermle 2115 Ave Maria Westminster 2 Chime Quartz Clock Movement ... hermle hamilton ridgeway howard miller seth thomas, clock winding key #7/4.00. $9.99.
Clock Repair & Replacement Parts - Movements, Motors ...
timesavers.com/c-325738.3-clock-repair-replacement-parts-movements-...
Items 121 - 180 of 249 - Front Plate - Seth Thomas #2, #77 Movement ... of #2, 77 movement parts that have been in storage since the 1970s. ... Hermle #2115Westminster/Ava Maria Quartz Movement ..... My Account; Login/Register ยท My Cart.
Jan 27, 2016 | Westminister Time Warp Shelf Clock
How do I fix the westminster chimes on my grandfather clock
Grandfather Clocks Manual - theclockdepot
www.theclockdepot.com/grandfather_clocks_manual.html
Howard Miller Grandfather Clock Manual by The Clock Depot offering discountGrandfather Clocks. ... The movement controls the hour strike, time keeping, andchime. ..... the hour without the Westminster melody if the other Westminster melody lever is turned to Silent. .... My Grandfather Clock has Stopped, Can I Fix It?
Owner's Manual - Master Clock Repair
www.masterclockrepair.com/ownersmanual.html
Note: The following information will apply to almost all grandfather clocks made after ...(See my article on Clock Myths) It is best if the chains are not pulled so far that the top of .... Some play the Westminster chime only and cannot be changed.
Nov 23, 2015 | RIDGEWAY GRANDFATHER CLOCKS Ridgeway...
Ridgeway clock continues to chime continusoly
Time for a professional service. It sounds like a lever is stuck, or a pin could be broken or bent. A clock needs to be serviced at least once every 3 - 5 years depending on the clocks location, and surrounding situation. Like a car the clock has to stay lubed up or it will eat itself up. Search for clock repair in your local area. You may want to call more than one to compare prices for service calls.
If your clock isn't more than say five years old, don't let yourself get talked into replacing an expensive movement unless you can be showed why the movement needs to be replaced. If you were in the area I'd say bring it by the shop, and let me take a quick look. I don't charge to look. Good Luck
Dec 29, 2014 | Home
Coaster model 900723 grandfather clock doesn't keep time
Everybody should know that the coaster clocks discussed here run on batteries. The timing mechanisms, the chimes as well as the pendulum all are powered by a battery. Changing the speed of the pendulum is impossible because there is no adjustment. Besides, it wouldn't matter anyway. The pendulum has now affect on the clock's ability to keep accurate time. It is purely aesthetic. This is a pretty cool looking clock and even has weights, but those are also purely aesthetic and do not move the way a classic grandfather clock weight would move. The moments with these clocks are not designed to be worked on. These clocks are relatively inexpensive (approximately $300) but do add a nice look to your home. Grandfather clocks snobs would say though; this is not a true timepiece. They're right... Sorry._1513.jpg
Nov 20, 2010 | Watches
Home Logo
37 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
