Water Heaters Logo
c
can pham Posted on Apr 18, 2017
My Kinetico 60 k?p over fow water from the tank. What is the problem and how to fix it
1 Related Answer
Anonymous
  • 332 Answers
  • Posted on May 30, 2009
SOURCE: Water softner dirty water
you might also want to check into the piping in your house is it gavinized, cpvc or copper, this could also make a diffrence, you could also be pulling mud from the bottom of your well, the anoid rod in the water heater will keep you from seeing this in the hot side lines,suggest to have a test done on the water take a jar with a lid and take it to your local plumbing supply house and see if they can't have it tested then you will have all your answers, the test i'm in md. it cost us aprox 40.00 to have the complete water test,
What could be the problem causing the rotten egg smell in the water? We have changed the anode rod.shocked the well.no sulfur. We have kinetico softener. Use iron out salt. Water heater 2 yrs old.
Some water softeners you can increase the back wash time on the unit to clear out a smell or bad taste , rotten egg smell can be sulfur. You may need a well flush but seek a well company on that for there advice as its not cheap .
1helpful
Found water in the pan under bottom of my 60 gal Rheem Marathon model CMR 75245 electric hotter tank. There is no other source of water goes in the pan. Tank is only 4 yrs old. Is the tank leaking?
Is it sitting in the pan or is it elevated over the pan? It is hard to see the leaking if it is sitting flat in the pan. Check all the connections, top and bottom. Wipe them dry and then run your hand over the connections and feel for water. Also check under the heating element covers for leaks. Good luck!
How long to heat water in tank
Depending on the size (volume) of the tank, you should feel the water rise above ambient temperature in as little as 10 - 30 minutes. Hot water should be available in 20 - 60 minutes for electric water heaters - and slightly less for LP / Gas fired heaters.
2answers
Water only stays hot for about 5 min or
Gas or electric?
Electric water heater ... then test for crossover, check for water leak, replace thermostats, test elements
Gas water heater ... test for crossover, check for water leak
http://waterheatertimer.org/Crossover.html
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
http://waterheatertimer.org/How-to-test-water-heater-element.html
water leak: turn off all taps and put ear against pipe and listen for water leak... check if water meter advances when all water taps are off.
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Water leaking out of the top of the hot water furnace
1) Copy following linkL
http://waterheatertimer.org/Leaking-water-heater.html
2) Add comment and include brand and type of water heater for possible additional help
Water heater leaks
You have to replace water heater.
But you can buy-time if leak is small by turning heater off except when you need hot water. This will give you 30-60 days to shop and find best heater.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
To prevent tank from rusting in this manner, inspect and replace anode rod each 2-4 years, and keep water pressure below 80psi.
http://waterheatertimer.org/How-to-maintain-water-heater.html
How do you set tempature to make the water stay hotter longer? I have a Rheem 82v66 2 (65 gal) and cant fill my bath tub with out running out of hot water.
65 gallon water heater should fill more than 1 bathtub since typical bath only uses 12-14 gallons hot water. First hour delivery on your tank should be greater than 60 gallons.
http://waterheatertimer.org/Hot-water-use-chart.html
Since you have such a small amount of hot water, it sounds like bottom element is burned out, or one of the thermostats is bad. There are two thermostats, and two 4500 Watt elements on 65 gallon tank.
If upper element was burned out, or water heater was not getting 240V electricity, then you would have NO hot water. So we know upper element is good and circuit is good.
Ordinary tank-type electric water heater is fully repairable by homeowner and parts are available at hardware or home center.
I suggest taking 30 minutes and doing troubleshoot before replacing any parts.
Buy cheap multimeter from home center.
When testing voltage, rotate multimeter dial to 240-250-277 VAC
When testing elements or continuity, rotate dial to Ohms.
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Add a comment for more free help. I can answer questions as you fix the water heater.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on heater.
Top Water Heaters Experts
vince
Steve Sweetleaf
Steve Sweetleaf
Are you a Water Heater Expert? Answer questions, earn points and help others
