Question about Camping, Backpacking & Hiking
Transformer is getting power, but the landscape lights are out. (one of the spotlight bulbs is out). The gardener cut one of the lead wires to one of the spotlights. Is there a way to re-boot?
brainyass
  • 242 Answers
SOURCE: Vector Sport Spot 1,000,000 candle power spotlight
6 Volts, here is info from site.
VEC127Y
VECTOR SPORT SPOT 1 MILLION CANDLE POWER CORDLESS-RECHARGEABLE SPOTLIGHT
  • HIGH CANDLE POWER QUARTZ HALOGEN BULB DELIVERS A BRIGHT AND TIGHT BEAM
  • AREA WORKLIGHT IN HANDLE PROVIDES UP TO 15 HOURS OF LIGHT WHEN FULLY CHARGED
  • PROVIDES CONTINUOUS SPOTLIGHT USE FOR UP TO 25 MINUTES WHEN FULLY CHARGED
  • HIGH IMPACT, BREAK RESISTANT ABS AND POLYCARBONATE HOUSING
  • TOUGH, WEATHER RESISTANT AND BUILT FOR RUGGED OUTDOOR USE
  • REPLACEABLE 6 VOLT, 6 AMP HOUR, NON-SPILLABLE, SEALED BATTERY
  • LOCKING TRIGGER FOR ON/OFF LIGHT CONTROL
  • INCLUDES AC AND DC CHARGING ADAPTERS
  • INCLUDES BUILT IN HANDS FREE WORKSTAND
Posted on Sep 17, 2008
  • 973 Answers
SOURCE: cyclops spotlight wont charge
It is indicating that your battery needs to be replaced, it will not hold a charge.
Posted on Jun 05, 2010
SOURCE: I need 3 light bulbs for a 3 million candle power
Hello! I have a marinepro, 12-volt, 3 million candle power spotlight (mpn #MPAT-996). I found out that the manufacturer is RoadPro (866) 622-7979. After contacting them, they said the replacement bulb is an "H3 12v (volt) 100w (watt) and can be found in the Walmart camping section or should be available at any car parts store. I'm going to go to Walmart to find mine. Hope this helps others!
Posted on Jul 13, 2010
c1apton15
  • 3400 Answers
SOURCE: wiring diagram for spotlights on
You can find factory wiring diagrams here (free RAVE Download) http://www.landroverresource.com/ And sure you can wire your spots into rear fog switch, depending on watts/draw of your lights you might want to "UP" the fuse rating
Posted on Mar 20, 2011
How do you program a da-150-12w-1?
150 Watt Transformer TDC Power DA-150-12W-1 - eBay
www.ebay.com > ... > Outdoor Lighting > Walkway & Path Lights
eBay150 Watt Transformer TDC Power DA-150-12W-1 in Home & Garden, Yard, Garden & Outdoor Living, Outdoor Lighting, Walkway & Path Lights ' eBay.
New Free SHIP TDC Power Da 150 12W 1 Low ... - eBay
www.ebay.com > ... > Outdoor Lighting > Other Outdoor Lighting
eBayNew, Free Ship, TDC Power DA-150-12W-1 Low Voltage Transformer, 12v 150watt Max in Home & Garden, Yard, Garden & Outdoor Living, Outdoor Lighting ...
[PDF]SECTION H - Etlin
www.etlin.com/pdfs/Outdoor_Transformers.pdf
1-800-661-9610 (Canada) 1-888-762-5384 (USA). OUTDOOR LOW ... DA-XX-12WSeries - 60 to 150VA Small Case Low Voltage Outdoor Transformers.
Da-150-12w-1 Manual ' downloadthingsfast.com
Dec 09, 2015 | Malibu Hardware & Accessories
Have Malibu ML300RTW Transformer...
Doesn't seem to me it could be the transformer/controller as it either puts out voltage and current or it doesn't. I can't think of any way it would selectively operate certain bulbs. You said wiring is fine, but you should check voltage at the end of the line to ensure it's getting close to 12 volts all the way down the wiring. If not, there may be a problem between transformer and misbehaving bulbs. Doesn't seem likely that 5 bulbs would go out a once, but that would be all that's left.
May 15, 2014 | Intermatic Malibu 300W Power Pack...
I have 3 landscape lights that were working but quit working in a system with about a dozen other lights that continue to work. I presumed the bulbs needed replacement but that didn't help. I verified...
My experience has shown that this is nearly always a connection and/or wire corrosion issue. Be certain that all connections are clean-if not clean with fine grit sandpaper or replace. Remember these devices are exposed to the weather on a continuous basis.
Nov 04, 2013 | Intermatic Malibu 300W Power Pack...
Landscape lighting transformer hums only when controlled thru photo-cell, and not when powered directly.
1) Copy following link for Intermatic/Malibu power pack photo-eye instructions, general troubleshoot, manuals, replacement trippers, and tips to prolong life of power pack:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
2) Brand and model of transformer and photo eye are unknown.
Wiring changes are unknown.
Volt rating of photo eye is unknown.
Wiring of photo eye is unknown.
3) Add a comment including details, and attach photo, after reading information on link above, for live response Jan 2013
Jan 01, 2013 | Home
We have a SV168n-36 Spagna Vetro Range Hood and it works well but the lights are having problems now. They only come on intermittently and when they do come on once they heat up they shut back off.
I had the exact same problem with my Spagna Vetro hood. The fan worked fine, but the lights started working intermittently and then stopped working altogether. The problem in my case was a failed transformer, which sits between the power switch and the lights and is necessary to step-down the voltage from conventional 120v to 12v to support the halogen bulbs in the unit. Although there are several steps to resolving the problem (replacing the transformer), it's really not difficult. Here's what I did to solve the problem:
1) Shut off the circuit at the breaker (always very important :^) )
2) Removed the glass arch from the top of the hood. Four screws hold it in place and are accessed from above the unit.
3) Removed the access panel above the fan and light switches. This panel is visible underneath the glass arch, when the glass arch is removed. I slid the lower section of the decorative stainless chimney cover upward to gain complete access to the back two screws of this panel.
4) I unplugged the original transformer from the light on/off switch (connected with two yellow wires on my unit). Remove the wire-nuts and disconnect the 12v leads from black and white wires that connect the transformer to the halogen bulb fixtures.
5) Using a flat-head screwdriver, I pried the transformer off the metal surface to which it was adhered with double-stick tape. This was strongly adhered and took a bit of prying.
6) Found a replacement step-down electronic transformer at the hardware store. My hood takes only two 10 to 20 watt bulbs, so only a small transformer is required. The original one I removed was rated to 70 watts max. I replaced it with a transformer rated to 60 watts max. Either was more than sufficient to cover the 20 watt load produced by my two 10 watt bulbs. Cost of the replacement was about $15.
7) Connected the replacement transformer to the hood power switch. Here, I had to be a little careful to maintain the original polarity of the wires from the switch. This is because the original transformer, though it had one white and one black wire on its 120v side, was attached to the switch via two identical-looking yellow wires, using a non-standard plastic connector. The new transformer did not have one of these connectors on its 120v input wires (black and white), and I wanted to make sure that the I wired the replacement exactly as the original had been wired. Fortunately, the original plastic connector ensured a consistent polarity. When I looked at the end of the connector, one lead was square and one lead was round and noted that the square lead had been attached to the White wire on the original transformer. The replacement transformer also had a white and black wire for its 120v side. So, I marked the yellow wire from switch that attached to the white wire through the square lead. Then, I cut off the plastic connector from the yellow wires, stripped the sheathing from them about 1/4 inch, and attached the white wire from the new transformer to the previously marked yellow wire, using a small wire nut. I then connected the black wire from the transformer to the remaining yellow wire in the same way.
8) On the 12v side of the transformer, the wires are the same color and I did not pay close attention to polarity, simply connecting each to the spliced wires leading to the halogen bulbs (that I exposed when I removed the wire nuts from them in step 4, above) using fresh wire nuts.
9) The double-stick tape that attached the original transformer to the hood remained firmly attached to the metal surface of the hood and it was still very tacky on the surface that had been attached to the original transformer. So, after I tidied up the wires in the space, I positioned the new transformer over the tape and pressed it down firmly, which seemed to adhere the new transformer to the hood pretty well.
10) With the connections completed, and power restored to the circuit at the breaker, the lights worked fine, and the fan continued to work fine. I reversed the steps I used to expose the switch and transformer.
So that's all there was to it. The cost of parts was about $20 for the transformer and a bag of wire nuts. Investigating the problem probably took more time than the actual repair, which took about 20 minutes from start to finish.
Aug 03, 2011 | Euro-Kitchen SPAGNA VETRO 198D-36...
My malibu landscape 300w transformer does not want to come on
Check that power pack is getting electricity.
Power pack should make a small humming sound when on.
Scratch a wire across both terminal screws and see if there is spark.
If a bulb burns out, and is not replaced, additional voltage can burn out other bulbs.
Power pack should be unplugged if bulbs are not burning since that can burn out power pack.
Change out a couple bulbs and then plug-in power pack.
Check connections where lights tie into wire.
My power pack was doing same thing, I bought another power pack from Home Depot to check my lights. All but 2 bulbs were burned out. I replaced bulbs and returned new power pack.. and then power pack quit for good a month later.
I found tips to preserve power packs:
1) Match wattage of bulbs with wattage of power pack
-15 each X 20 watt bulbs = 300 watts, so install 300Watt power pack
2) Installing a 500W power pack on 300W of bulbs will burn out bulbs and power pack.
3) Replace bulbs as soon as they burn out or other bulbs will burn out and power pack will burn out.
4) When working on bulbs, unplug power pack or it may burn out.
http://www.malibulights.com/guides_support/low_voltage_planning_guide/select_your_power_pack
Nov 22, 2010 | Intermatic Malibu 300W Power Pack...
We are adding a light and need to know how to put in this wire into the transformer box? We do not have the box or instructions for our Hadco Landscape Transformer 30600. A diagram and instructions would...
Could not find that exact transformer number, but if you go to this URL you will see transformers that are most likely similar to yours or you can contact Hadco/Phillips.
http://www.hadco.com/Hadco/Public/SearchVisual.aspx?FamId=24
As long as you are using the proper voltage bulb, you should not have a lot of difficulty hooking it up.
Feel free to contact me in the event you run into problems.
Sep 14, 2010 | Garden
I just purchased some spotlights to add to my already installed malibu landscaping lights. I upgraded my transformer to 300 watts since the total wattage used comes out to 220. The lights on the end of...
Yes, using a larger wire will help, as will using more than one run. If you want too, you can leave the 16 gauge wire in place, then run the new 12 gauge wire and transfer most of the lights to the new run.
The fewer lights on a run, the less dimming will occur, so put more lights on the 12 gauge run.
Also, the longer the run, the more dimming will occur.
You may want to reconsider the location of the transformer, if possible. In your case, it would be better to locate the transformer in the middle of the current run, and just split the run in half to make a run in each direction. Of course, that depends if you have a 120 volt outlet available in that area.
Jan 03, 2010 | Malibu ML600TW - Low Voltage Power Pack -...
My low voltage landscape lights are constantly going on and off once the timer activates them initially. I suspect there is a short somewhere, but is there a good way to locate the short besides pulling up...
Your transformer must have output greater of the total wattage required of the entire system. Example: Putting lights that draw a total of 250 watts with only a 180 watt transformer will result some lights not working, or dimming and flickering, or intermittent power outtages. I learned this from experience. Always go with a transformer that has more wattage available than what is needed. Also, using the incorrect gauge of wire can cause the same issue. Wire creates resistance. Distance the power must travel through the wire creates more resistance at the end of your run than the beginning.
Mar 29, 2009 | Garden
Landscape ligthing Transformer
Yes ican. They are made to be split into two 300 watt circuits. So it's ideal to place it at a location in the middle of you lights . Basically to go each direction from the transformer. Now you need to find out what wattage bulbs are in each light.(different fixtures can have different watt bulbs.) Lets say you have 8 lights going one direction and 8 going the other way and each light has a 20 watt bulb. That adds up to 160 watts on each side. So you are well below the 300 watt rating per side. By the way I wouldn't go anymore than 250 watts on a 300 watt circuit. Next you look on the bottom of the transformer and you will see the screws where you hook up the wire. You will need to strip the end of the wires about a half inch. Hook one set under the A & B for one side then do the same for the otherside. Plug in the transformer and set the timer to whatever tme of day and night you prefer. Hope this helps. If you have more questions just ask. Thaks and remember to rate me.
Oct 21, 2008 | Garden
Camping, Backpacking & Hiking Logo
1,119 people viewed this question
Top Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
