Question about Samsung Audio Players & Recorders
How do I plug in my Wii and Bose 321 to a Samsung TV model pn42e450a1f
Siliconchip
  • 52 Answers
SOURCE: bose 321 cd/dvd tray stuck closed
Please kindly check if this is d model of your 321
Posted on Jan 03, 2008
djSilver
  • 10 Answers
SOURCE: BOSE 321
Have u tryed other disc ? if so your Bose system my have read a corrupted disc u may want to change out your IDE cable and if that doesn't work then corrupted files has made its way to one of your main broads.
Posted on Apr 24, 2008
  • 623 Answers
SOURCE: hooking up bose 321 to my tv
I am about to go through the same process. I have a Bose 321, and am on the verge of getting a HDTV. From what I can figure, the Bose can play a dvd and input it to the HDTV via video and audio output plugs off the back of the Bose to the audio/video input jacks on the back of the new HDTV. I think individual cables will have to be run for each. They usually are red or white, sometimes green or blue. I am sure everyone has seen these in their life. The Bose 321 technology only had what was called an S-Video cable output for the best picture, which is how my current tv gets it's Bose signal, but now HDMI seems to have superceded S-Video. Therein lies an obstacle to be overcome.
Posted on Jan 29, 2009
  • 8 Answers
SOURCE: connecting bose 321 system to lg hd flat screen,bose receiver plays fm am ok threw speakers.tv will not play threw bose speakers.bose dvd plays sound ,but no picture
You will need a Component Video Cable
Connect the Red Green and Blue Connections from the TV to the Bose.
if your audio is coming from the TV, also connect stereo audio from the TV's audio out to the "TV" input on the bose.
if you want to hook up other devices (VCR, BluRay, etc) the video will go directly to the TV and audio will go directly to the Bose
Posted on Sep 12, 2009
SOURCE: My Bose 321 series II is not responding to the
Replace the batteries from the remote control. Press and hold the TV button on remote for 5 seconds. If the red light shines bright, your remote is OK since it is showing it's programmable side. If unit still won't go on using the remote, reboot the whole system by unplugging the power cord and other wire from the Subwoofer. Wait one minute, then replug all and see if the system displays BOSE 321 in front when re-connected. If so, try the remote and if that doesn't work, your dead, the Infra red communication device from the unit to the remote is busted inside the unit and needs to be returned to the company like mine!!!!!
Posted on Dec 15, 2009
Bose 321 device code for Kogan UHD TV
Your Bose remote may not work with your Kogan TV.
Aug 12, 2016 | Bose 321 GS series II
Trying to hook up Bose AV 321 media system to Samsung LED TV model
You can use a Optical to Analog audio adaptor (found all over the internet for under $30). You'll also need an optical cable that goes between the adaptor and TV. Be sure to set the audio output on the TV settings to PCM audio output, otherwise there will be no output.
Jan 22, 2014 | Samsung Televison & Video
Have a Bose 3-2-1 Series III. When I put in a DVD, I get sound through the Bose but no picture on my Pioneer TV. This is the second time it has happened. The first time it, we managed to get it going...
Here are 3 things to try and an if all else fails at the end.
1) Make sure the TV is set to the correct Video Input to see the video from DVDs on the Bose system.
• Make sure a DVD is in the disc tray.
• If the TV is connected to the media center using the HDMI cable:
Switch from one Video Input to another and then back to the original input.
2) Turn everything off, then:
Turn on the TV and set the TV Video Input for the Bose system video.
Turn on the Bose system and press DVD.
3) Turn off both the TV and the Bose system and then:
Unplug the HDMI cable from both ends.
Disconnect the power cables from both your TV and the Bose 321 system.
Re-connect power to the TV and to the Bose 321 system.
When the Bose 321 system startup message disappears from the display,
re-connect the HDMI cable to the TV then Bose 321 system.
Turn on the TV first, then turn on the Bose 321 system.
If all the above fail then disconnect the HDMI cable that connects the TV to the Bose 321 system and reconnect the two using a Component cable, an S-Video cable, or the Composite cable provided with the system.
Please leave feedback
Cheers
Andy
Apr 28, 2011 | Bose 3·2·1 II System
Faint sound when watching TV with Bose GSX 321 System
I connected my surround sound to the audio output on my samsung tv and it works fine. Of course I don't have an hdmi input on my surround sound system because its an older model, but it works great. Just got to put the surround sound to audio instead of dvd or tuner setting
May 07, 2009 | Bose 3 2 1 GSX System
Communicating with your tv message on bose 321 series 2
Well, it seems that this may be a common issue with this BOSE unit. My 321 GSIII was working fine as well for about a week. After a full frustrating day of switching, disconnecting, reconnecting cables and resetting the unit and TV several times, I was forced to call the BOSE Technical. They tried to help with the situation over the phone by directing me to do just about everything I did before I ever called them. After about an hour of their unsuccessful help, they left me in saying that I will now have to run Composite cables because my TV will not connect for some reason through HDMI even though it was working for a short time. AHHHHH...I custom prepared the walls in my new office to accommodate non-exposed cables and wires and now BOSE is saying to expose Composite cables. Tomorrow, I am going to connect the Composite cables to confirm if the 321 will now work that way (for curiousty). I will then call BOSE back and demand a replacement unit. I will keep all in the loop with my progress of this situation.
Apr 01, 2009 | Bose 3·2·1 II System
Bose 3-2-1 connection
Connect the 360 and wii to the tv. Then connect the tv to the 321 using analog coaxials (red/white) or digital optical through the tv's audio out ports in the back. Then set the 321 to TV and you should be all set. Sound may not be quite as dynamic as if you went straight from the gaming systems to the 321, but should still work well.
Jan 14, 2009 | Audio Players & Recorders
Hooking up bose 321 to my tv
Dec 14, 2008 | Bose 321GS Series II System
Bose 321
You probably blew up several components in the power
supply circuit, but yes it can be fixed.
Just take it down to your local TV repair shop.
Oh wait, those don't exist anymore.
-John
Nov 10, 2007 | Bose Lifestyle 30 System
51 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
