Question about The Office Equipment & Supplies
Teco window aircon code error f2 showing on the display what does that mean and also the ligths are blinking
SOURCE: Error message
A2 is announcement only, no recorded message possible.
Posted on Feb 22, 2008
  • 148 Answers
SOURCE: F2-02 error on Sharp AR-M237
on this code you may have to clean out the developing unit and start with fresh developer. Make sure the developer unit is not leaking from one of the bearings. You may need a tech for this one...
Posted on May 26, 2008
fixyourboard
  • 310 Answers
SOURCE: e6 F2 error on Whirlpool double self cleaning oven.
I wrote a blog on this topic recently, perhaps this will help you:
appliancejunk.com/blog/2009/11/11/whirlpool-oven-e6-f2-error-code-failure-andor-blank-display-board-not-available/
Best Regards,
Bruce
www.fixyourboard.com
Posted on Mar 05, 2010
technic_7117
  • 38 Answers
SOURCE: F2 error code in onida window ac means what
pipe thermistor replace it
Posted on May 07, 2010
hvac1960
  • 2133 Answers
SOURCE: indoor unit flashes 5 times. error code meaning?
E-5 -Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
Posted on Jan 03, 2011
What does E2 mean on a Teco washing machine
Check to be sure the drain hose on your TECO washer is not crimped or bent thus preventing water from exiting. Check that the drain pump is not jammed or obstructed in any way as this will cause the washer to not drain and the error code will occur. Washing Machine Error Codes Front Load and Top Load Washers l
Teco is not listed but the comments include the answer.
Jun 05, 2017 | Washing Machines
The oven beeped, the screen said F3, now the oven is locked. It smells like a hot wire
What does F3 mean on my Frigidaire stove when it sounds ...
www.shopyourway.com > Manage My Life > Questions
My Frigidaire range beeps and flashes F3. ... 790.92413202 and when I turn on bake or broil it just shows an F3 code on the screen what does this mean?
What does fault codes "F2" and "F3" mean on a Kenmore ...
I have a Kenmore wall oven model 911.41059591 that beeps and flashes F2 or F3 and shuts off. ... The "F2" and "F3" fault codes is most likely indicating an open oven ... Next, the control panel will need to be taken off in order to measure the ...
Oven error code "F2" and how to fix it ' AskGene.com
www.askgene.com/.../oven.../what-means-the-error-code-"f2"-on-your-o...
Mar 26, 2007 - The error code "F2" will be displayed along with a beeping sound if the
Jan 27, 2016 | Kitchen Ranges
My midea aircon is showing F3 code?
Display = E2
Malfunction or Protection = Communication error between indoor units and outdoor unit.
This is the meaning of the error code. If you need any more AC Cleaning & Repair help contact the professionals.
Apr 07, 2015 | Midea Heating & Cooling
Teco air conditioner LS1826H fault code F2
F2 on this model means that the indoor unit pipe sensor has failed. You would probably need someone who is at least a licences electrician or preferably an Air con tech to repair this. You will need a new pipe sensor. Contact Teco Australia who can put you in touch with your nearest service Agent.
Sep 09, 2013 | Electronics - Others
How to reset pre-def red light blinking on teco aircon unit
You have to try resetting the system. First turn the breaker off for the condenser and wait about 20 seconds. After you turn it back on the system should reset.
Air Conditioning Tamarac
Jun 10, 2013 | Heating & Cooling
Hi have a Teco aircon not cutting in and out in the cooling mode
please more information about the problem you mean by in and out (on and off)
Sep 04, 2009 | Heating & Cooling
Sharp AR-150N displaying F2 Error code.
Hello sir; I can't find this error code in my manu please check your code again.
Aug 12, 2009 | Sharp Office Equipment & Supplies
Error F 2 (Blinking mode) appears in Display of Sharp AR5316,
Hello sir; F2 have a sub code, press print key to read the sub code, if the sub code is 04,then it means wrong cartridge,wrong country, you can try to reset it;
1, press "#", "interrupt", "c", "interrupt" keys.
2, enter 14 press start.
3, if it work, don't forget give me a good rating.
Feb 12, 2009 | Sharp AR-5316 Advanced Digital Imager...
Top The Office Equipment & Supplies Experts
Adam
Level 1 Expert
obsteiner
Dudeman321
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
