Was getting e6 so i cleaned the tubes now getting e4. Can't find what e4 means
Golden glp26r washing machine
MNTECH
  • 1543 Answers
SOURCE: I have a LG washing
Kinked inlet hose. Screened hose washer in inlet hose plugged. Frozen water supply pipe(s). No power to washer inlet valve(s). Old inlet hoses with separated layers, blocking water flow under pressure.
Turn off valves, remove from machine end, put in bucket and turn on valves to make sure you have water up to machine. Now work back to find why you are not getting water into machine.
Posted on Jan 03, 2009
  • 5 Answers
SOURCE: My washing machine is SANYO ASW-90WRTP. showes E4
Check on the machine there is a schamatic and it has error codes on it. it may be on the in side panel.
Posted on Oct 11, 2009
Testimonial: "cool thanks for that just empty the tub then will check for skidmatics"
Daniel S
  • 4323 Answers
SOURCE: Washing machine WA3773 shows 'E6'
Hi
Error code E6 means the water is not draining due to suds or due to kinked drain hose. Check if the drain hose is plugged. If the hose is fine then you'll need to check the drain pump and drain filter. Access the drain pump and drain filter by removing the back panel or front kick panel. Trace the drain hose to the bottom of the tub, you would now see the drain pump, disconnect the hose from the pump and clean the pump and filter. Please be aware that there would be lot of water when you'll remove hose from the drain pump. Hope this helps... If it does please do not forget to accept the solution or post back for assistance.
Daniel
Posted on Sep 05, 2010
SOURCE: i have a stirling washing machine xqb90-701clps
my machines not washing properly i think.. The wash is complete but theres still powder on the clothes.. What do i do to solve it?????
Posted on Sep 06, 2010
  • 1746 Answers
SOURCE: E4 means on akita washing machine
Hi, Try this out it may be similar to your machine.
http://www.samsung.com/ae/support/skp/faq/442142
Good luck
Posted on Jan 07, 2016
Samsung front load washing machine model wf42h5000a. During rinse cycle machine stops and displays error code e4 and Cannot be reset.explain error code. What are possible solutions ?
hi Judi.
this is what i found.
If your Samsung washing machine is displaying a E4/error code on the control panel after completing the spin cycle and the clothes are still wet, we've got the solution for you. This fault is most commonly caused by an unbalanced washing machine load.
Samsung Washing Machine E4/UE Error Code ' eSpares
https://www.espares.co.uk/advice/symptom/samsung-washing-machine-e4ue-error-code
What does 4e mean on my Samsung washing machine?This is essentially a fill timeout error which will normally mean that either the water isn't on or that an inlet valve has failed or pressure switch problem check pipes as well. Water fill time out: The washing machine has failed to fill with water in a reasonable time.24 Nov 2015Samsung washing machine error code 4E and E1 Fault Not filling in ...https://www.youtube.com/watch?v=cFlnxeB0P0gSearch for: What does 4e mean on my Samsung washing machine?
or try this link.
Samsung front load washing machine error code e4 Google Search
Nov 27, 2017 | Samsung Washing Machines
I get code e06 on a samsung p1005j Ken
Hi there
Here are all the error codes and what you should do:
General Error Codes
E1: Water Supply Error
-Display Shows 'E1'
-Water Supply Error occurs when water level frequency does not show changes more than 100Hz or water is not supplied up to the water level presetting for 20 minutes or more at the time of initial water supply.
-To help fix this problem please check the Hot and Cold water intakes, there is a filter screen in each input valve, remove and clean these filters. ** Make sure you replace the filters, they are very important for the operation of the Washing Machine.**
-The error status can be cleared by turning POWER S/W OFF and resuming the POWER ON initial status.
E2: Water Drain Error
- Display shows E2
- In case the water level frequency is 25.5Hz or less in the initial phase of UNB-detecting cycle.
- Water Drain error can be cleared by turning POWER S/W OFF and resuming the POWER ON status.
E3: Over-Flow Error
- Display shows E3
- Over-Flow error occurs when the water level is too high. It can be cleared by turning POWER S/W OFF, turn POWER S/W ON and then run the drain cycle for 2 minutes. Water is drained prior to POWER S/W OFF and it is forced to be drained for 2 min if a frequency of more than 25.24 KHz is detected
Door Open Error:
- Display shows door
- This can fixed by closing the door
E4: Unbalance Error
- Display shows E4
- Laundry load is unbalanced; loosen any tangled laundry.
- If only one item of clothing needs washing, the final spin result might be unsatisfactory and an E4 error message will be shown in the display window.
- Unbalanced error is cleared by POWER S/W OFF and by resuming the POWER ON initial status
E6: Please see "Eb" at end of list.
E7: Pressure S/W Error
- Display shows E7
E9: Water Leakage Error
EA: Tacho Error
- Display shows EA
- This is error can be cleared by turning the power off and then on again.
Eb: Motor Triac Short Error
- Display shows Eb
E6-EB can only be corrected through Service. Please contact Customer Service Department at 1-800-SAMSUNG (option 1-1-2) to schedule an on-site service call for english service.
Thank you for using FixYa. Have a nice day and please remember to rate this solution as 356ebb3.png if it helps you.
Kind regards
Dustin Ellse
Jul 03, 2008 | Samsung Washing Machines
I need a new circuit board for my Golden portable washing machine GLP26R, 20014 as it no longer works after Hurricane Matthew. I'd need instructions to install it. Thanks!
fixya doesnt sell products you can try the manufacturer for part and instructional manual or request for distributor in area --do online search for appliance parts
Oct 26, 2016 | Washing Machines
E4 error code on electrolux washing machine ewt 854s
E4 is the pump is blocked {not running} pehaps a hair pin or clothing wires get stuck
fully drain it and take the filter out
and clean it
these error codes are similar to candy
youll get an idea from this video
https://www.youtube.com/watch?v=kzhlvB2LjXg
Nov 28, 2014 | Electrolux EW1000i Front Load Washer
What are WFL 2060 fault codes
Bosch WFF washing machine error codes:
E1
- The door is not closed and cannot therefore lock.
E2 - Washer will not fill with water.
E3 - Washing machine not heating.
E4 - Washing machine won't empty.
E5 - Fault in the motor drive circuit.
E6 - Unexpected heating.
E7 - NTC thermistor open or short circuit.
Please note that the codes for the WFF range of Bosch machines differs from other ranges.
Sep 04, 2014 | Bosch Axxis WFL 2060 Front Load Washer
Keep getting a E4 Code
This E4 Phenomena means "no water":
No or slow water fill (not
reaching the full level in 15 min),
therby computer sends display message "E4"
Reasons:
1) The house water tap is not open, or
2) This is the most common E4 reason- The water inlet valve (that the hose is connected to) is blocked.
3) The water pressure is too low and the flow is too weak.
Solutions;
1) Open the water tap, then push the START/PAUSE button again.
2) Clean the water inlet valve. Shut off house water supply on the wall then, unscrew (lefty loosy) each hose from the house and the machine and look for a screen and clean the junk away from the screens. You may have 1 or 2 screens depending on the hose there may be 1 screen where the hose connects to the house and another screen inside the machine valve. Then, return hoses and turn on the water pressure again, Then push the START/PAUSE button again.
3) Wait for the normal water pressure to return to the house before use.
Oct 08, 2013 | Haier HLP23E Top Load Washer
What does error message E6 mean on a prompt set spa #jl017108?
I am having the same problem, not E4 but E6 error code and have to keep resetting it and about 15 min later it start beeping the error code again? Please help
May 21, 2012 | Pool & Spa
What does malfunction code E6 mean in a koppel super inverter airconditioner
WHAT IS THE MEANING OF E4 code in koppel inverter split type
May 01, 2012 | Heating & Cooling
The washeer machine give a error code E4
A code of E4 means that there is to much suds or the pump is blocked. use less detergent and get detergent with he in the title. turn to off and try to restart the drain to correct problem.
You will find the code in the manual. If you do not have let me know I will send you one here.
Good Luck And Please Rate FixYa!
Dec 19, 2008 | Washing Machines
Washing Machines Logo
50 people viewed this question
Top Washing Machines Experts
